  1. Jun 13, 2023 at 12:24 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    I was going to suggest dramamine too. That is what we gave our dogs on road trips so they wouldn't get sick, but also made them super drowsy.
    Blue Thunder and T-Rex266 like this.
  2. Jun 13, 2023 at 12:24 PM
    Ya I prefer both of our dogs just sleep through it all
  3. Jun 13, 2023 at 12:28 PM
    Blue Thunder
    Washington
    We give our dog CBD edibles for thing like the 4th of July and when he gets his nails trimmed. He doesn’t act stoned but definitely is more relaxed.
  4. Jun 13, 2023 at 12:30 PM
    Knock them down pretty good for the night? Link for any good ones?
  5. Jun 13, 2023 at 12:31 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Did you test them at all?
  6. Jun 13, 2023 at 1:05 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    There's been some newer things come out recently to calm nerves that I've personally found to be ineffective and highly expensive (like you had to buy 3-4 tubes of the shit to get through a weekend for a larger dog @a couple of hundred dollars)....
    We've used diazepam or trazadone a few times w/ok success, but side affects (stomach issues, etc. after for a couple of days sucks)
    I've had really good luck w/Gabapentin; it's cheap and generally speaking, it's very safe, w/little side affects. It was designed to be an anti-seizure drug, but is kinda becoming main stream for pain management (usually before moving to narcotic strength pain killers)...
    It has also been found to have a sedating affect, but my guess it because it deals w/seizures it's running a different path to its process of sedation. They would probably give you 300mg capsules, and I'd start w/2 (600mg 1.5-2.0 prior to the event)...
    *** It's very important to get the meds on board (in the dog) prior to the stressful event starting if possible to maximize effectiveness. ***
    You should see the dog sleepy and highly relaxed, but not completely out of it; He'll probably just lay down and chill somewhere comfortable...
    Depending on the duration of the event, a single dose may be sufficient; if it carries on for a while you can add another capsule in a couple of hours if you need to. Always follow vet recommendations, but I've found that the recommendation of 1 hour prior usually isn't long enough for the dose to set in and sometimes, depending on the vet, they may be conservative on dosing...
    Best bet is once you get the pills, take a quiet evening w/nothing else going on and give him one. Time how long it takes for the dosing to really take affect. If you don't see an adequate sedation level. Wait for a few days and start another trial w/2 capsules (600mg) and test for timing on the sedation of that dose. This way, on the day(s)/weekend of the event you'll know when to start dosing.
  7. Jun 13, 2023 at 1:09 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
  8. Jun 13, 2023 at 1:10 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  9. Jun 13, 2023 at 1:12 PM
    Tripleconpanna
    Is that freakin' kiwi??? What else do you have on there?? The wife and I were making pizzas 2 nights ago, and I looked over and saw a few kiwis in the fruit bowl... I was joking w/her about throwing one on a pizza, but we decided not to that night. How was it???
    Taco-Spike, 20GR8 Super and T-Rex266 like this.
  10. Jun 13, 2023 at 1:14 PM
    GravityGear
    Aurora, CO
    Oh, that's not my pizza. It is an actual pizza that was sold as a limited time special though. I think the shop WAS in the Netherlands. It has kind of gotten more traction though. The story behind that kiwi pizza is pretty sad though.
  11. Jun 13, 2023 at 1:14 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  12. Jun 13, 2023 at 1:18 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  13. Jun 13, 2023 at 1:30 PM
    GravityGear
    Aurora, CO
  14. Jun 13, 2023 at 1:38 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Is that pizza or a dip? Lol
  15. Jun 13, 2023 at 1:48 PM
    20GR8 Super
    Corey
    PNW Outskirts
  16. Jun 13, 2023 at 2:39 PM
    SwitchThrottle
    SwitchThrottle Living in Idiocracy
    2021 Barcelona CrewMax
    Diazepam or trazadone doesn't do shit for our Boxer. He went to the vet today for his annual checkup, and they gave him some sort of tranquilizers, and he looks stoned as shit, but they still couldn't trim his nails.
    :boom:
  17. Jun 13, 2023 at 2:39 PM
    Tripleconpanna
    That there is some southern AZ shit....
  18. Jun 13, 2023 at 2:40 PM
    Tripleconpanna
    You can't show me a pic; then tell me 'it wasn't mine'; then tell me there's some sad story behind it; and then not tell me the story....
  19. Jun 13, 2023 at 2:43 PM
    Tripleconpanna
    There you go w/the gang signs again..
  20. Jun 13, 2023 at 2:45 PM
    Tripleconpanna
    Order one of these and do it yourself at home...
    https://doggielift.com/
    20GR8 Super, Taco-Spike and T-Rex266 like this.
  21. Jun 13, 2023 at 2:47 PM
    SwitchThrottle
    That's a hard no. He's a total spaz about his feet. What I need to do is walk him more, but our other dog goes mental on walks and th Boxer feeds off her, so walks are very few and far between.
  22. Jun 13, 2023 at 2:52 PM
    SwitchThrottle
    The vet gave use Gabapentin 600mg and Trazodone 100mg and said to give both at the same time 2hrs before and it might work.
    T-Rex266 and Tripleconpanna like this.
  23. Jun 13, 2023 at 2:58 PM
    Tripleconpanna
    You'd be surprised about the whole lift thing; most will still pull their leg back a little once they are lifted as you are manipulating feet, but you just block the joint (knee or elbow from moving) and you can get it done fairly easy.
    Dogs don't have good depth perception, so when they are elevated off all 4 they will generally dangle their legs straight down and not fight so hard; especially when the chest and rest of the body is supported by the harness.
    Even dogs that flip around and thrash about as you lift them by hand, are generally pretty passive in the lift... FWIW
    Safety note: If you are dealing w/a dog that will bite or get highly defensive, definitely muzzle w/a good agitation style muzzle to prevent getting hurt, since your face and neck are accessible :thumbsup:
  24. Jun 13, 2023 at 3:07 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Some more national geographic
    20230613_134415~2.jpg 20230613_134526~2.jpg 20230613_134604~2.jpg 20230613_144716~2.jpg 20230613_144722~2.jpg
    Also have videos from today but ain't nobody got time fo dat
  25. Jun 13, 2023 at 3:22 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
  26. Jun 13, 2023 at 3:44 PM
    Tripleconpanna
    Sweet.... at least you caught that one like you were suppose to :D
  27. Jun 13, 2023 at 3:46 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    :p
  28. Jun 13, 2023 at 3:46 PM
    FrenchToasty
    Mo
    Bone stock
    Super jump!
  29. Jun 13, 2023 at 4:20 PM
    Taco-Spike
    Two Trucks
    Not eating pizza for a while…..
  30. Jun 13, 2023 at 4:26 PM
    Pizza these nuts!
