  1. Sep 14, 2017 at 6:46 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Aftermarket UCA's are not used to correct tire wear problems. It's to add caster which you lose when you lift a vehicle. Also with larger tires you generally want more caster than stock so the truck tracks better rather than being twitchy and feeling like a shopping cart.
  2. Sep 14, 2017 at 9:08 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I need to call you instead of these off road guys
  3. Sep 14, 2017 at 9:30 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    Just need to call a reputable shop who actually knows what they are doing and has been doing it right for a while.
  4. Sep 14, 2017 at 9:34 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    You done with that 2018, yet? We're waiting to see final masterpiece :)
    Jsena likes this.
  5. Sep 14, 2017 at 9:34 AM
    TheBeast The Beach
    :spy::spy::spy: about to go down !
  6. Sep 14, 2017 at 9:39 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Oh hell yea
    Jsena and TheBeast[QUOTED] like this.
  7. Sep 14, 2017 at 9:43 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Rad. :headbang:
    Jsena likes this.
  8. Sep 14, 2017 at 9:43 AM
    TheBeast The Beach
    you are a bad influence...Icon wheels and Grapplers will follow shortly next year :)
    csuviper[QUOTED] and Jsena like this.
  9. Sep 14, 2017 at 10:10 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
  10. Sep 14, 2017 at 11:51 AM
    Spvrtan
    Kris
    San Diego, CA
    Testing "export" feature on Buildprint..
    Mods
    Method Double Standards (5)
    17x8.5 and painted dark gray
    Method Double Standards (0)
    18x9 and painted white with blue accents
    2
    Mickey Thompson MTZ P3s (5)
    40x13.5
    BFGoodrich KM2s (0)
    My first set lasted over 40k miles!
    Goodyear Wrangler MT/R w/ Kevlar (1)
    42x14.5
    3
    Relentless Fab front bumper (5)
    Defender version; steel
    White Knuckle Off Road sliders (5)
    3/16"-walled outer tube
    BudBuilt gas tank skid (5)
    Made of 3/16" stainless steel
    ARB rear diff breather (5)
    Relocated stock breather up behind taillight
    SDHQ ABS skids (5)
    4
    ARB air compressor (5)
    Twin motor high-performance portable air compressor
    Warn winch (5)
    ZEON Platinum 12k with synthetic line
    TRED Pro (5)
    ARB static rope (5)
    2-3/8" x 30' strap (17,500lbs capacity)
    ARB tree saver (5)
    3" x 10' strap (26,500lbs capacity)
    5
    Spyder projector headlights (black) (5)
    Spyder LED taillights (black) (5)
    2 x Baja Designs Squadron XL Pro (5)
    Mounted on the A-pillar
    4 x Rigid Industries Duallys (5)
    6 x KC HiLiTES Daylighter (LEDs) (5)
    Mounted on the roof rack
    6
    Custom bed rack (5)
    Aluminum material (~45lbs); built by Pelfreybilt
    Gobi Ranger roof rack (5)
    24-gallon water system (3)
    Dee Zee "heavyweight" bed mat (5)
    Bed & tailgate Line-X'd (5)
    Cooler/fridge tray (4)
    Replaced the short seat in the rear!
    7
    Artec battery tray (5)
    9
    BDS 7" bracket lift (5)
    Atlas 4.5" leaf packs (5)
    Expedition-style
    ICON front coilovers (5)
    Large-lifted application variation with remote reservoirs and CDC valves
    ICON rear shocks (5)
    Large-lifted application variation with piggybacks and bypasses
    Coachbuilder tie-rod ends (5)
    These help to correct some of the angles the bracket lift pushes on the steering rack
    Coachbuilder +3 shackles (0)
    About 3" longer from bolt-to-bolt, which increases the rear height about 1.65"
    KING coilover springs (5)
    Rated at 800lb
    Custom +5 shackles (5)
    10
    Lock'er Down center console box (5)
    12
    Debadged OEM chrome emblems (5)
    17
    EAG Viscious grill (5)
    Matte black
    RKSport ram air hood (5)
    Fiberglass construction with functional scoop and heat vents
    18
    TRD supercharger (5)
    Got this installed a few months before Toyota announced they were discontinuing the supercharger program (even though they were always made by Magnusson).
    TRD performance dual exhaust system (5)
    SDHQ secondary air injection pump i (5)
    20
    Spidertrax wheel spacers (5)
    Adds 1.25" at each corner
    4.88 gears (1)
    Probably going to go with Nitro's ring and pinion for both differentials
    Air locker (1)
    Going with an air-actuated locker for the rear differential
    21
    Fire extinguisher (5)
    Drake Offroad extinguisher mount (5)
    Build info exported via Buildprint
    edwin729 and T-Rex266 like this.
  11. Sep 14, 2017 at 12:00 PM
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Looks like toe build is turning out pretty decently, the truck and the site both :thumbsup:
  12. Sep 14, 2017 at 3:50 PM
    TheBeast The Beach
  13. Sep 14, 2017 at 3:59 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    :thumbsup:
  14. Sep 14, 2017 at 4:33 PM
    Sooo jelly... awesome sauce... wish i could do
  15. Sep 14, 2017 at 4:49 PM
    edwin729
    edwin729 Tundra Life
    Edwin
    Arizona
    2023 Silver Tundra Crew 4x4 Plat
    @TheBeast
    What size lift is that?
  16. Sep 14, 2017 at 4:57 PM
    TRDFaux
    TRDFaux Irresponsible Adult
    2014 Tundra SR5 Crewmax 4X4
    Toytec level and diff drop, Cooper STT Pro Tires, TRD Pro Grill, blacked out, debadged.
    Framed out the walls and floor for our new shed today. Today I'm thankful for framing nailers.
  17. Sep 14, 2017 at 6:08 PM
    Areith762
    Areith762 Go Avs!!!
    39.944182, -104.760113
    2017 Blazing Blue 5.7L CM SR5 4X4
    DAP Tune, Katskin interior leather, ESP rear under seat storage, door sill protector, door edge protector, TRD Pro shift knob, heated seats, all weather Tundra floor mats, driver side a-frame handle, Tundra trucks center console emblem, clear bra protection, Bushwacker fender flares, paint match front bumper caps, paint match rear bumper caps, paint match mirror caps, ProComp 3/1 lift, 20" Fuel wheels, 33-11.50/R20 Falcon tires, black TRD Pro badge's, black Tundra tailgate badge insert, TRD Pro headlights, Recon smoked tail lights, Recon smoked 3rd brake light, Roll N Lock tonneau cover, Line-X bed liner, Tundra bed mat, Cobra led remote alarm/remote start, N-fab tube steps, factory match window tint, TRD Pro grille -paint matched, paint matched hood bulge, TRD dual exhaust, Black out exhaust tips, led interior lights, led plate lights, Spyder smoked fog lights, TRD Cold Air Intake
    blue16, JC303, NewImprovedRon and 5 others like this.
  18. Sep 14, 2017 at 7:43 PM
    TheBeast The Beach
    enough to level with rear...for now ;)
    Eclipsed & Floating likes this.
  19. Sep 14, 2017 at 7:58 PM
    TheBeast The Beach
  20. Sep 15, 2017 at 9:39 AM
    sdhq_offroad
    GILBERT, AZ
    Our blog side of the website got a new update that went live yesterday. Let us know what you think! Our store side is in process of update along with adding new products, taking off old products and stream lining the search aspects.
    http://sdhqoffroad.com/
  21. Sep 15, 2017 at 10:53 AM
    KIMG0219.jpg How many of us forget that our bed light is on???? :eek:
  22. Sep 15, 2017 at 12:54 PM
    1505505184701-138874054.jpg What tha shit!!! Ughhh!!! Why oh why couldn't it be an MGM
    TXMiamiFan likes this.
  23. Sep 15, 2017 at 1:10 PM
    #whitetrucklife
  24. Sep 15, 2017 at 1:12 PM
    I got ur hashtag for you lol
  25. Sep 15, 2017 at 1:13 PM
    #deeznutss
  26. Sep 15, 2017 at 1:14 PM
    :confused:
    T-Rex266[QUOTED] likes this.
  27. Sep 15, 2017 at 3:06 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    Found our Halloween decoration...
    blue16 and TheBeast like this.
  28. Sep 15, 2017 at 3:08 PM
    TheBeast The Beach
    I like that time of the year :)
  29. Sep 15, 2017 at 7:47 PM
  30. Sep 15, 2017 at 7:49 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    wish i could've made it. have fun.
