    1 vote(s)
    2.9%
  2. Yes - roll/swipe on
    30 vote(s)
    88.2%
  3. Yes - areosol
    3 vote(s)
    8.8%
  1. Jul 23, 2025 at 11:49 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Keep grinding. Dividends will come.
  2. Jul 23, 2025 at 12:04 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Good luck brother, it’ll all work out!
  3. Jul 23, 2025 at 12:47 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    perfect workout conditions:bananadead:
  4. Jul 23, 2025 at 1:12 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    No
  5. Jul 23, 2025 at 1:24 PM
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    If you don't mind me asking, where did you find that temperature display?
    Edit: nevermind, I think I found it on Amazon.
  6. Jul 23, 2025 at 1:30 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
  7. Jul 23, 2025 at 1:35 PM
    they need to let the military know about this torture device thing
  8. Jul 23, 2025 at 1:36 PM
    Humidifier didnt do shit for my nose bleeds.
  9. Jul 23, 2025 at 1:37 PM
    :( Hang in there man!
  10. Jul 23, 2025 at 1:39 PM
    Know whats wild?
    walking around with vaseline in ur nose
  11. Jul 23, 2025 at 2:04 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I have a Marmot tent that's only 4 years old. The zippers stopped functioning so I reached out to them via their warranty claims link on their website. It's taken a few weeks to get everything sorted out via an email chain they started in response to my claim, but I just received a final response from them asking what color I'd like in the current version of the same model tent. Mind you I was only asking for them to replace the zipper but apparently it's cheaper to just replace my old tent with a brand new one. I'd call that a win.
  12. Jul 23, 2025 at 2:06 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I'm pretty sure they have some methods already. But I'll forward your request up the chain of command.
  13. Jul 23, 2025 at 2:25 PM
    NWPirate
    Zach
    WA
    I think that's what i had.. burned like a MF!
  14. Jul 23, 2025 at 2:35 PM
    SAGE63
    San Diego County
    Damn that sucks.... good luck
  15. Jul 23, 2025 at 2:35 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    But it's a dry heat??:crapstorm:
  16. Jul 23, 2025 at 2:42 PM
    SAGE63
    San Diego County
    REI used to be great like that with lifetime repair or replace.... not anymore. You are now lucky to get 1 year.... Needless to say I dont shop there anymore after they wanted me to pay $85 to replace a tent zipper. F'n A holes...
    I wont even step in their stores.
  17. Jul 23, 2025 at 3:04 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I have 4 old clocks in my garage and bought one of those for the outside temp.
    I couldn't find a decent spot to put the outside sensor to where it wouldn't read 5 to 10 degrees over the actual temp.
    I sent it back to Amazon.
    The digital clock looked stupid with the old dial clocks anyway.
    Same goes for the bedroom clock, I mounted it up under the roof eave.
    It reads 105, but it is only 97 outside.
    But I kept it, it projects the time and temp on the ceiling..
  18. Jul 23, 2025 at 3:09 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Yes, I'm bored.
    I cleaned the dryer vent today.
    It vents out of the roof from the laundry room.
    Had quite a bit of lint in it, considering I did it last year.
    It's about a 20-foot reach to the rooftop vent outlet.
    I had to order a wifi extender for the new garage TV.
    The signal was barely fair and would disconnect at times.
    Now it is excellent, and I'm getting 545 Mbps on the garage PC, I'm paying for 500.
    I was only getting around 35 to 40 on that PC, 10 to 15 before I got fiber..:thumbsup:
  19. Jul 23, 2025 at 3:42 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I had the same.
    I mounted my outside sensor just out side the garage window...in a constant shady spot.
    the inside sensor is odd because there is a heat ceiling...it's that hot @ 7 feet
    but about 3 degrees cooler at 4 ft
    amazing.
    the slab in the garage is still ~80 degrees, so when I rest i generally lay on floor.
    the humidity recently has been laughable....I go thru 3 dew rags.
    OldGuy03, T-Rex266, kirkb and 3 others like this.
  20. Jul 23, 2025 at 4:00 PM
    Azblue
    The Dirty T ( ^_^)_且
    Nobody wants to know about your weird fetish kinks.
  21. Jul 23, 2025 at 4:01 PM
    Azblue
    Time for a garage mini-split, or at least a swamp cooler like I have.
  22. Jul 23, 2025 at 4:03 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I've been spending a lot of time in the garage doing my PT for the last several months.
    It's starting to turn into a workout adding some work with my thick rubber bands.
    Added some situps and walking up and down my exercise step.
    I'm lucky to have a double window in the garage as well as 2 fans.
    I don't mind the heat so much, but I can't be out on the sun like I used to.
  23. Jul 23, 2025 at 4:03 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I disagree..
  24. Jul 23, 2025 at 4:06 PM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2025 RAM 3500 6.7L Cummins
    I used to tell them I was extremely interested and ask if they could hold on while I found my reading glasses. Then I would check back after about 20 minutes to see if they were still there.
  25. Jul 23, 2025 at 4:11 PM
    Melikeymy beer
    Muscogee Nation
    Running the space heater overnight.
  26. Jul 23, 2025 at 4:19 PM
    Azblue
    That is not fair. Now I don't like you.
  27. Jul 23, 2025 at 4:38 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    On the way to work this morning
    Hit 90 this afternoon
  28. Jul 23, 2025 at 4:40 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Not mine. I drink at least a gallon of water a day.
  29. Jul 23, 2025 at 4:46 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    And this is why our landfills are full...
  30. Jul 23, 2025 at 5:15 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    I love it, that's hilarious
