  1. Oct 3, 2024 at 11:01 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Thanks... not sure about all that, but I try to help when/where I can :thumbsup:
    If you're enjoying shooting a Sig, chances are you won't prefer shooting the Glock over the Sig; definitley two different beasts... Fairly easy to become highly proficient and comfortable w/either platform, especially if you're 'green' and can learn properly the first time rather than creating a bunch of training scars and then trying to work out the kinks as they present themselves once you move to more advanced shooting methods, techniques and environments. Definitely a good idea when you're first learning to try and stick w/a particular platform than bouncing back and forth between systems.
    I ran a Sig P226 for a few years (unit requirement that we all ran the same pistol for mag compatibilty between everyone in the unit). Fortunately, that 'policy' was removed after a brief period and we were allowed to carry what worked best for us w/in reason. It was a very nice pistol and short of it not liking some of our training rounds it was pretty damn reliable. Personally, I didn't like how it was weighted, and I hated the double/single operation of the trigger. For me, I'd prefer for the trigger to feel consistent w/each press.
    I know a lot of folks don't care for the contour and shape of the Glock pistol, but the newer generations have made some improvements to that and they are a bit more user friendly for those looking for a slight beaver tail and some contour where the webbing of your strong hand makes contact w/the grip. The other issue that you'll hear a lot about is how Glocks don't 'present' well; this is a misnomer and is caused by poor shooting mechanics. Many folks operate a pistol w/the belief that the strong hand (right hand for a right handed shooter) is responsible for 70-80% of the 'grip strength' used to control the pistol, recoil, and desired lateral movement of the weapon; and if you present w/your off hand doing only 20-30% of the work, yes you'll find that there is a propensity to 'cant' the weapon to the left slightly. This isn't caused by the pistol, it's caused by the mechanics of the human body. These mechanics are the reasons folks are taught to intentionally cant their pistol when shooting one handed (because it allows the arm to remain more stable throughout the process).
    But once you build a proper 2-handed grip, it's your non-dominant hand that should be handling about 60-65% of the stabilization, presentation and guiding of the weapon. A lot of folks try to squeeze the grip of the gun w/their strong hand (bottom 3 fingers). This technique has you trying to control the entire pistol w/3 fingers at the mid-range point of the grip (not real efficient in terms of leverage)....
    The more efficient way to control the weapon is to have you hand(s) control the pistol where there is more weight (high on the gun) and to do so by 'vicing' the gun, which is done by applying an inverted V shaped pressure high on the pistol... In other orders if your hands are placed in a verticle position near each other and you roll them inward to where the pads on the index fingers (at the palms) make contact and develop pressure; you'll want your off-hand slightly higher than your strong hand (maybe about 1/2-3/4") , while the pinky end of your palms start to wander apart slightly... (this is how to begin vicing properly).
    If you do this in the air (empty handed) at chest height and have your hands drawn into your chest, what happens to your elbows??? They extend outward; you should also feel tension in your traps... now while maintaining that position and pressure, push your hands from your chest forward and in line w/your eyes (head up and body square to your target). Now don't lock out completely, just press forward until the shoulders feel slight discomfort or tension and then back off slightly... this is approximately the ideal position for your arms while shooting. If done properly, your body should be squared up to the target; your left hand should be slightly above the right; the right elbow should be slightly below the left (causing the right forearm to be angled down just a bit more than the left); and while the left (non-dominant) hand actually drives the pistol to the proper angle of presentation (not the right hand). Abviously, there are many other 'touch' points within your grip that assist in controling the pistol, but vicing and proper alignment and angles of your hands/arms is key :thumbsup:
    Something else to consider... loose hands are fast hands. Fighters don't clench their fist until just prior to impact (less tension = more speed and dexterity in their hands); grip the shit out of knife and see how fast and fluid your motions are... now loosen your grip and allow the blade to flow and dance w/o as much resistence from you... night and day difference; now choke up on the knife (don't cut yourself) and work the blade w/a high grip... faster, more balanced and much more control of the blade. Look at an MLB hitter... those w/a looser grip on the bat have a much greater bat speed over those that grip the bat hard. Guys like Arraez, Schwarber, and Chisolm have very fast bat speeds (their hands are loose). The same thing happens with a shooter who has a strong 'grip' w/the dominant hand; it results in slower presentation, movement of the pistol and muuuch slower and sloppier trigger manipulation.
    Quick circle back to that 'tension and pressure' you felt in your traps / rear shoulders area... this should be where you 'feel' or allow recoil to pass through. Recoil should NOT and does NOT naturally drive the front of the pistol up (this is human input based on years of conditioning while watching TV and such as to how a pistol should behave once fired). Recoil should move reward. Gases and the explosive energy that are pushing the round out of the front of the barrel of the weapon should be creating an equal and opposite reaction at the same time (sound familiar, right); which means recoil SHOULD be driving the weapon back into you... unless of course you are allowing the pistol to control you and eventually as that energy reaches your elbows and causes them to bend more the path of least resistance for that energy is them folding and driving your hands up; which since our brains were taught that the pistol should climb w/recoil would give our bodies confirmation that upward movement means we are doing it right, but unfortunately it's wrong...
    Bottom line w/recoil is that it should move reward and be felt in the body; standing shooter w/a pistol should feel the recoil in their shoulders/trap area.... prone rifle shooter w/the buttstock mounted at the shoulder should feel the recoil run through their entire body and exit at the feet. Slo-mo video of prone shooters can be seen w/the energy exiting their body at their feet.
    Crap, I'm rambling.... sorry!!!
    If you do like the Sig platform better, take a look at the P365-AXG Legion. Just note that it is a striker fired weapon, so it's essentially a single action pistol (like the Glock) and trigger press is the same every time. But, the ergonmics are very consistent to your P322. This pistol is also loaded w/a bunch of upgrades (flared mag well, removable MOS plate (I believe it's a RMR-c compatible platform), so if you decide to move to an RMR at some point you can do so w/o having to buy a new slide or sending yours out to be machined :thumbsup:
    https://www.sigsauer.com/p365-axg-legion.html
    Anyhow, my bad for typing out a book again, but if you want any more info or wanna chat in greater detail and work through some of this stuff prior to getting started, let's move this to a PM so we're not clogging up the thread :cool:
  2. Oct 3, 2024 at 11:09 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Need more details please.
    coTony, French Avocado, JMB and 7 others like this.
  3. Oct 3, 2024 at 11:23 PM
    Tripleconpanna
    Smart ass...:rant:
    Oh wait, here... :smack: take that!!!!
  4. Oct 3, 2024 at 11:33 PM
    Tripleconpanna
    I'm not quite sure I even said anything remotely close to that....
    https://youtu.be/4Iy_LV9lxN8
    j-utah, OldGuy03[QUOTED] and T-Rex266 like this.
  5. Oct 4, 2024 at 2:54 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    hmmm...I think this is just the cooling off period.
    which means, they will work at 50% - at best.
    j-utah, T-Rex266 and Tripleconpanna like this.
  6. Oct 4, 2024 at 3:08 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Re: pistols
    I'll give my completely unqualified opinion.
    I started in the early '80's with a browning buckmark .22. still have it. I learned to shoot with that.
    then, in the late '80's I got a Glock G19 from a cop friend of mine. still have it.
    I learned to shoot real loads with this gun. I still carry it sometimes.
    so, my neural pathways know the grip & tendencies of a Glock. That's why I carry it.
    my body knows it- instinctively.
    its it better than a 1911?...dunno. don't care. I know how to shoot a Glock well.
    I do have a
    Sig P210 it's a nice shooter.
    Staccato P (2011 style) it's the top shooter I have. red dot & all. suppressor as well.
    Staccato C2 - small 2011 - I thought I would carry this, but It's not a glock.
    Springfield EDM - meh.
    Glock 17 with comp. beauty of a shooter.
    in short - I only carry Glock (G19* or G26) because that's what my body knows.
    learn on the gun you will rely on.
    get a good holster.
    and for all you heathens with a kydex holster....go tighten those little screws on the side.
    don't ask me how I know this.
    *I have a Lasermax on my G19. it also has hi viz sights. the lasermax is awesome, as it does not alter the performance of the gun. It's like 4wd...I have it, but never use it. https://www.lasermax.com/green-guide-rod-laser.html
    sbxx312, blenton, NWPirate and 3 others like this.
  7. Oct 4, 2024 at 3:22 AM
    Tripleconpanna
    That's probably cuz you get stuck and you're like, 'screw it.... this is a now a heavy leg/core day', and you just pull the truck out yourself :muscleflexing:
  8. Oct 4, 2024 at 3:24 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    LOL
    truth be told - I forget it's there!!!
  9. Oct 4, 2024 at 3:41 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    all this gun talk & now I have to share a story.
    I like going to the range & shooting pistols...then go over to the rifle range & shoot 20 rounds of my .308
    well, my trucker buddy came one day & decided, since he had such a fun time, he wanted a rifle too.
    (FTR - he can't hit the broad side of a barn with a pistol)
    he bought a Fierce Firearms Carbon 6.5 Creedmoor. (picture below)
    but....he put a full monte' Swarovski scope on it (z8i).
    <yes...that rifle is a $7k pkg.>
    this is how far scopes have come....
    Ables Ammo zero'd the scope @ 100yds. and set up the app on his phone.
    so, my buddy set's up on the 300yd range...puts the little red dot on the target & hits it dead center.
    ON HIS VERY FIRST SHOT OF A HIGH POWERED RIFLE.
    that's how good scopes/technology are these days.
    some say it's cheating...
    reminds me of the grumping ICE folks do when I bring up the performance of a Tesla Plaid.
    and yes...it's not a skill to shoot that rifle. it's just technology helping humans do amazing shit.
  10. Oct 4, 2024 at 4:11 AM
    I'm be worried about a beer panic
  11. Oct 4, 2024 at 4:21 AM
    Kuul, but Swarovski been putting out top notch hunting optics for 75 years. My Grandfather had a set of Swarvoski binocs he'd let me use before I was old enough to drive in the late 60's. Not sure how that relates to ICE vs EV though. Top notch rifle optics have always been available if you fork out enough money.
  12. Oct 4, 2024 at 4:29 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Yes...I was alluding to the technology of that scope.
    it range finds...then, adjusts point of aim. it's dum-dum proof. (my ICE/EV analogy)
    it will tell you:
    range
    flight time
    energy at impact
    temp
    other shit I don't know.
    and I can attest to the quality.
    I have these at the lake...for....well, birdwatching....yeah, that's the ticket.
  13. Oct 4, 2024 at 5:10 AM
    I'd like a pair of those!
  14. Oct 4, 2024 at 5:58 AM
  15. Oct 4, 2024 at 6:28 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    All your beer is supposedly brewed locally, though. :p
  16. Oct 4, 2024 at 6:42 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    You didn't say that. I did silly.
  17. Oct 4, 2024 at 6:47 AM
    True. whew!
  18. Oct 4, 2024 at 7:42 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Correct. I'll donate $5 on it. And I'll actually need your PayPal. I don't even know what Venmo is.
    T-Rex266, Tripleconpanna and j-utah like this.
  19. Oct 4, 2024 at 7:44 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    LOL.
    it's nice being among peers.
  20. Oct 4, 2024 at 8:20 AM
    Outbound
    Aaron
    Northern Alberta
    Quality of a set up really makes a difference. My longest hit was a cold bore shot on a 12" gong at 1250 yards. I'm a decent shooter but it took a proper set up to make it happen. I was using a Prairie Gun Works Coyote in .308 Win with a Nightforce optic, i think the ATACR, ($10K CAD set up about 8 years ago...), custom handloads with match grade bullets and about 3 years of DOPE that the owner put together. Add in a highly experienced spotter who called my drop and windage and I was able to essentially line up the crosshairs, pull the trigger and get a hit. I probably couldn't do that with a factory Remington 700 and mid range Leupold optic, I'm not that good. LOL
  21. Oct 4, 2024 at 9:42 AM
    18" TRD Off Road Wheels
    The SAS isn't really tech. It is basically open sites that are recessed down into the slide. There is no battery, no light, or switch or anything. It's not a dot sight.
    Regular on the left, SAS on the right. It's a tritium night sight just like the irons on a Sig.
    The way it works is that it has to be properly aligned to see the dot. Just like with regular sights, if you have in cockeyed you can't see the front sight, with this if it's cockeyed you don't see down the tube and the dot isn't visible. You're not taking time to "f around with dots" any more than you are taking time to line up front and rear iron sites. Improper alignment on the left, obviously.
  22. Oct 4, 2024 at 10:11 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Errors in aiming can't be quickly or easily corrected, as there is no visible reference. Nothing about SAS sights tells you whether the end of the barrel is high, low, left, or right compared to the rear sight; the only information you get is 'you're off'. With traditional sights, you'd know and can correct quickly. Inexperienced or infrequent shooters, or someone in distress, would need extra time to get on target.
    I don't think many, or any, have trouble pulling a gun with traditional sights out of a holster. IMO this is a horrible idea.
  23. Oct 4, 2024 at 10:23 AM
    I didn't have an issue when handling it in a store. I can't explain it, but you can pretty easily reference the error/orientation issue. At least, I could. I still didn't buy it because I wouldn't pay extra for it. I don't hate the bullseye sight, but I don't think it is worth a premium.
  24. Oct 4, 2024 at 10:24 AM
    It's not the holster that would be the issue. It's the sights and levers snagging clothing in concealed draws. It's not a big issue, but one that there are complaints about in the shooting community. SIG offered a solution.
  25. Oct 4, 2024 at 11:24 AM
    WTF :puke:
    Im not shampooing his upholstery, but I’ll take a little out for him. wtf is wrong with people
  26. Oct 4, 2024 at 11:25 AM
    Not all of us are neat freaks. :boink:
  27. Oct 4, 2024 at 11:48 AM
    JFC. Seriously
    OldGuy03, j-utah and Black Wolf like this.
  28. Oct 4, 2024 at 11:49 AM
    I can't wait to bring you my truck. LOL
  29. Oct 4, 2024 at 11:55 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    No IPA's? How about......
  30. Oct 4, 2024 at 12:01 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    That's a blast from the past. Most girls when I was in high school really liked that stuff.
