Tundra234's 2020 Barcelona SR5 DC
Discussion in '2.5 Gen Builds (2014-2021)' started by Tundra234, May 29, 2022.
  1. May 29, 2022 at 3:02 PM
    Tundra234 [OP] New Member
    20240621_092750.jpg 20200916_174721.jpg 20210718_131458 (1).jpg Compress_20220529_190703_3619.jpg Compress_20220529_190703_3785.jpg Compress_20220529_190659_9404.jpg Compress_20220529_190659_9992.jpg Compress_20220817_212055_5004.jpg Compress_20220622_103244_4797.jpg Compress_20221022_125022_2831.jpg Compress_20221022_125023_3449.jpg Compress_20221022_125022_2382.jpg Compress_20221022_125022_2594.jpg Compress_20220910_172102_2670 (2).jpg Compress_20221018_104839_9586.jpg Compress_20220814_211633_3586 (2).jpg Compress_20221113_120458_8531.jpg Compress_20220529_190703_3262.jpg Compress_20220529_190701_1313.jpg Compress_20220724_200035_5270 (2).jpg Compress_20220529_190700_0777.jpg Compress_20220911_130309_9650.jpg Compress_20220529_190657_7739.jpg Compress_20220529_190656_6411.jpg Compress_20220529_190656_6015.jpg Compress_20221126_082707_7413.jpg Compress_20230220_205152_2668.jpg Compress_20230220_163630_0228.jpg Compress_20230220_163628_8535.jpg Compress_20230715_090529_9744.jpg
    Suspension
    TRD rear sway bar
    TRD front sway bar
    SPC upper control arms
    Toytec Aluma 2.5 coilover lift
    Toytec shackles set at 1.5
    Toytec Boss rear shocks with remote resis
    Alcan leaf springs +200 with 1/2" lift
    Timbren bump stops
    Coachbuilder front bump stops
    Coachbuilder carrier bearing drop kit
    Fuel Maverick 18x9 0 offset (old)
    Fuel Crush 18x9 +1 offset
    295/70/18 Nitto Ridge Grapplers
    Engine and performance:
    DirtyDeeds 8" without resonator
    Banks Pedal Monster
    Transmission cooler kit from @Genuine Cooling Systems
    Aluminum oil filter housing
    StopTech Sport cryo treated slotted rotors
    Fumoto oil drain valve
    Hypertech Speedometer calibration
    Stillen Cold Air Intake
    TRD airflow accelerator
    Exterior:
    Color matched hood bulge and TRD Pro grille
    N-Fab Podiums (Line-X'ed)
    Rough Country front bumper
    Road Armour Stealth rear bumper
    GearAmerica anti-theft shackles on rear bumper
    Coachbuilder 1/2" bumper shims
    UnderCover SE tonneau cover
    Bushwacker flares (Line-X'ed and PPF)
    RCI engine skid
    Desert Eagle front cat plate
    Valhalla rear cat plate
    Valhalla vertical add-on to rear plate
    Gloss black overlays
    Painted exhaust pipe
    Black chrome exhaust tip
    Llumar ceramic tint (5% side and rear, 50% windshield)
    Taillight vinyl overlay
    Jomax TSS relocation kit
    Interior:
    Drivers side grab handle
    Husky X-Act floor mats
    SEM trim black (silver/chrome delete)
    AJT climate control knobs, shifter trim, cup holder, steering wheel trim
    Lock'r Down full console safe
    G-Tek Fab aluminum door sills
    Anytime backup camera kit
    MirrorTap radar detector power wire
    3W Liners window control module
    Rear seat fold down mod
    TackForm phone mount
    Cupholderheroes inserts
    Clazzio leather seat covers (all black)
    3d switch plate from @abomb60
    AirOnBoard switches
    TRD shift handle
    Shift bezel degloss with matte clear
    Screen Pro-tech instrument cluster screen protector
    Rago dash plate with ICS support plate
    ICS Fab ball mounts and arms
    Escort Max 360C MKII mounted on Ram mounts power plate
    Rear AC conversion
    6 switch mount plate from @RainMan_PNW
    Lighting and electrical:
    Baja Designs S8 40" in hood bulge
    Morimoto XB Gen 2 headlights (PPF installed)
    Vleds puddle lights in mirrors
    Muth red signal mirrors
    Vleds Stage 1 tail conversion
    Vleds footwell kit
    Vleds LPR system
    Rigid SAE pods (4) in front bumper
    Rigid SR-M Pro flush mounts in rear bumper
    Rigid Dually D2 pods (4) behind grille (tinted lenses)
    Console safe lighting
    Led strip bed lighting
    Blue Sea (#5026) 12 circuit fuse block
    Blue Sea (#7187) 100 amp circuit breaker
    Blue Sea (#2307) 130A 4 post busbar
    Blue Sea (#2126) MaxiBus 250A 6 post busbar
    Blue Sea (#4366) DC power panel with Rago Fabrication mount in bed
    Overland Equipped fuse block mount
    Cargo light to 3rd brake light conversion
    Audio:
    Maestro RR
    Maestro USB retention
    Pioneer DMH-7600 NEX 9 inch floating display
    Rockford Fosgate 4 ch amp (mids and highs)
    Rockford Fosgate 1200 watt amp (subs)
    2 10" subs - JL Audio Stealth box
    Rockford Fosgate front door speakers
    Rockford Fosgate rear door speakers
    Pioneer dash speakers
    Stinger Roadkill Stealth in doors
    Roku Express
    Miscellaneous:
    Custom made decals (by me)
    Thinkware F200 Pro dash cam (front and rear)
    ScanGauge 3
    UnderCover Swing cases (modified bracket install)
    Hornblasters Conductors 232 kit with Stealth spare tire delete kit
    Badlands 3 ton offroad jack and mount in bed
    Manual to power sliding window conversion
    https://www.tundras.com/threads/how...-power-rear-sliding-window-conversion.130717/
    To do:
    Thinkware side view cameras
    Victory4x4 Fuel tank skid
    G-Tek Fab SABM
    ABS sensor guards
    Cargo switch to puddle/footwell
    CH4x4 backlight
    Bumper studs
    Lock box
    Dual power rear console panel
    Drain kit
    5.7 inside, AC writeup, rear window, SG3
    Refresh maestro
    Amp mount maple brd
    Breaker at amp
    Drain valve and air service port
    LC blower motor upgrade
    Tail harness
    Favorite links:
    https://screwdsecurity.com/
    https://rcimetalworks.com/
    https://shop-coachbuilder.myshopify.com/
    https://www.alcanspring.com/
    https://hotshotoffroad.com/ @memario1214
    https://valhallasshields.com/ @Classy63
    https://overlandequipped.com/collec...use-block-bracket-for-2007-2021-toyota-tundra
    https://*****************/products/toyota-tundra-screen-protech-kit
    https://www.motivxtools.com/collect...wrench-mx2301-funnel-mx2341-drain-tool-bundle
    https://www.bluesea.com/
    https://www.aironboard.com/online/
    https://genuinecoolingsystems.com/
    https://adamspolishes.com/
    https://bankspower.com/
    https://dirtydeedsindustries.com/
    https://www.vleds.com/
    https://stillen.com/
    Favorite products:
    SEM 39143 Trim Black Aerosol - 15 oz. https://www.amazon.com/dp/B000EM019O
    Favorite detailing products:
    Adams Graphene liquid wax https://www.autozone.com/wash-clean...polishes-graphene-liquid-wax-16oz/1173219_0_0
    Adams Graphene Tire Dressing https://www.amazon.com/Adams-Graphene-Tire-Dressing-Combo/dp/B08NVZT8V3
    303 AeroSpace Protectant https://www.amazon.com/303-30313-CSR-Protectant-Plastic-Fiberglass/dp/B00KN0UOEE
    SC SR5, TNDRA6!9, ThePearl and 16 others like this.
  2. Jun 8, 2022 at 4:26 PM
    QuicksandPNW
    QuicksandPNW New Member
    Kevin
    Washington State
    2020 Quicksand Tundra SR5
    Bed Rail System Tonneau Cover
    Nice truck! Giving me some ideas
  3. Jun 8, 2022 at 4:40 PM
    Thanks. It's getting there lol.
    DJI_20250130173831_0023_D.jpg DJI_20250130173912_0025_D.jpg DJI_20250130173933_0026_D.jpg DJI_20250130174000_0028_D.jpg DJI_20250130174200_0033_D.jpg DJI_20250130174048_0030_D.jpg DJI_20250130174051_0031_D.jpg DJI_20250130174153_0032_D.jpg
    DJI_20250130173933_0026_D.jpg DJI_20250130173831_0023_D.jpg DJI_20250130173912_0025_D.jpg DJI_20250130173933_0026_D.jpg DJI_20250130174000_0028_D.jpg DJI_20250130174200_0033_D.jpg DJI_20250130174048_0030_D.jpg DJI_20250130174051_0031_D.jpg DJI_20250130174153_0032_D.jpg
  4. Jun 11, 2022 at 7:13 AM
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    Bilstein 6112/5160 3/1 w/CB shackles Ironman front bumper, 18+SR5 Honeycomb grill
    U have any kind of issues with the cryo rotors? I'm thinking of switching to those next
  5. Jun 11, 2022 at 7:25 AM
    Not at all. I actually took these off of my 2013 before I sold it so I have been running them for about 3 years now.
  6. Aug 15, 2022 at 12:13 PM
    tuckerstundra
    tuckerstundra New Member
    Kenneth
    2010 Tundra 4X4 Platinum
    None
    Great looking Tundra! Is the suspension modifications strictly for the lift or does it help with towing as well?
  7. Aug 15, 2022 at 2:06 PM
    I did the suspension for the lift but no issues with towing at all.
  8. Sep 28, 2022 at 3:31 AM
    mav7021234
    mav7021234 New Member
    thinking of buying the thinkware f200 pro dashcam. how did you wire it up (hardwire/12v cigarette)? what was the best way to wire up/mount the rear camera? i have the crewmax so im not sure what would be best since the window can roll down
  9. Oct 2, 2022 at 6:34 PM
    I have it plugged into the cig lighter. It does come with a hardwire kit if you want to go that route. My rear cam is mounted on the non sliding window. I would think that the CM has the same trim so you could use something like a piece of aluminum to drop it down below the window.
    15SR5CM and mav7021234[QUOTED] like this.
  10. Oct 24, 2022 at 7:19 AM
    Arthur Dent
    Arthur Dent New Member
    2012 Tundra 4WD Double Cab Long Bed
    Very nice! Giving me some good ideas. Funny, I just got the N-Fab Podiums as well. I was hoping to mount them this past weekend but got stuck working on the backup camera. The previous owner put some diamond plating on the back that covered up all the holes...even the access hole for the spare tire! :)
  11. Oct 24, 2022 at 5:09 PM
    KurdishNinjaPilot
    KurdishNinjaPilot New Member
    2016 Tundra SR5 4X4
    Would REALY like that, where? How much and how difficult of a MOD?
  12. Oct 24, 2022 at 5:17 PM
  13. Oct 27, 2022 at 6:18 AM
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    What are the 4 silver screws mounted to the front of your fuse cover? I just ordered the same blue sea set up and bracket as you.
  14. Oct 27, 2022 at 7:48 AM
    8-32 × 3/4" Socket Head Cap screws
  15. Oct 27, 2022 at 8:23 AM
    I went back and looked. Are you referring to the circled area? That is a busbar. However, the screws that come with the fuse block are too short. That's what the 8/32 x 3/4 screws are for. Lowes didn't have any that long. I got them from Amazon, but you may be able to find them at Ace or a local hardware store.
  16. Oct 27, 2022 at 11:06 AM
    ProtoJ
    ProtoJ New Member
    Yes, the bus bar. I just ordered the same mounting bracket with auxiliary fused box. What is the bus bar for?
  17. Oct 27, 2022 at 12:25 PM
    I run power from the battery to the bar. From there, 1 lead goes to the circuit breaker feeding the fuse block. Another lead runs to the main power for my stereo, and the last one is for the harness on my Baja light bar.
  18. Oct 27, 2022 at 12:28 PM
    That bracket is very nicely made. The screws do not interfere with any of the markings on the inside of the lid. I still need to work on the rest of my wiring that will be hooked up to the fuse block.
  19. Dec 1, 2022 at 5:16 AM
    trj
    trj New Member
    Tom
    2020 Tundra SR5 TSS Quicksand
    Awesome build!
  20. Dec 1, 2022 at 5:27 AM
    Thanks
  21. Dec 1, 2022 at 7:30 AM
    Ceezurin
    Ceezurin New Member
    Franco
    El Paso, Texas
    2019 Cavalry Blue Limited Crewmax
    Bilstien 5100 all 4 corners, Toytec shackles, mbrp full exhaust single exit, husky liners, diode dynamics interior and exterior lighting
    Very nice, methodical build! Where did you get those taillight decals? I’ve been searching for something like that for a minute. Thanks
  22. Dec 1, 2022 at 8:06 AM
    I cut them on my vinyl machine.
    rocsteady and Ceezurin[QUOTED] like this.
  23. Dec 14, 2022 at 5:34 PM
    Steplift20
    Steplift20 New Member
    2018 Tundra
  24. Dec 18, 2022 at 7:46 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Very nice.
    RCI skid with DE cat plate mounting: Did you drill/notch holes in the DE plate or the RCI skid?
  25. Dec 19, 2022 at 5:12 AM
    I will have to look. I believe I did both so that the bolts pass through both plates to prevent them from being pulled apart without removing the bolts completely.
  26. May 5, 2023 at 7:43 PM
    Florida AF
    Logan
    North Florida
    So.... we need to meet up so I can see this thing in person and ask you the 100 questions I have LOL... I will bring the drinks of choice :D
  27. May 5, 2023 at 7:48 PM
    Ask away lol. I'm always on here.
  28. May 5, 2023 at 7:49 PM
    Florida AF
    Logan
    North Florida
    The big one is more details about your bed power. I was doing random searches for some ideas and then rechecked your build... looks like you nailed that one and yet I cannot seem to follow along to how you did it.
  29. Sep 11, 2023 at 10:08 AM
    Parts listing for window conversion. I will update as project is in work.
    64810-0C080 Main fixed window $215
    64807-0C010 Sliding window $70
    69088-0C010 Regulator $45
    67207-0C010 Glass stopper (comes with 2 in pkg) $15
    85710-0C110 Window motor $235
    69811-0C020 Window motor mounting plate $50.00
    82998-12790 Terminal repair wire (2 required) $14.80 each
    90080-87025 Relay (2 required) $58.00 each
    84810-0C120 Window switch $57
    90980-11900 Window motor connector $8.00
    90105-A0014 Regulator mount bolt (2 required) $0.96 each
    90080-14057 Window motor screw (3 required) $1.25 each
    90178-A0025 Flange nut $1.20 each
    PolishedTRD, 16MagSR5 and Florida AF like this.
  30. Oct 25, 2023 at 11:04 AM
    rphass17
    rphass17 New Member
    What about a junkyard window and motor? Maybe even the switch, all of this seems too easy.
