Tundra won't start
Discussion in '2nd Gen Tundras (2007-2013)' started by Dave14711, Jun 11, 2018.
  1. Jun 11, 2018 at 11:44 AM
    Dave14711
    Dave14711 [OP] New Member
    Dave
    Red 2011 Tundra Rock Warrior Crewmax 5.7
    I have a 2011 tundra crewmax Rock Warrior 5.7 with 90k miles on it. I've had it for about 2 years and haven't had any issues up until a few weeks ago.
    Issue 1: About 3 weeks ago was driving home from work about 5 minutes into my drive and I heard a click and the 4 high and low lights started flashing on my dash and the abs light and traction control off lights came on and the truck won't shift into 4 hi or low. I pulled over to make sure everything was all right and found nothing. Truck was driving just fine, no noises and guages were all reading normal. Did some troubleshooting online and found a ton of different possibilities. Tried disconnecting the battery. I'm assuming it's a sensor.
    Issue 2 (most pressing issue): I went to start my truck this morning and it just continually rolls over. Battery was full charge but I tried jumping just in case it was a little low and nothing. I notice when I turn the key the check engine and a/t oil temp light come on (not flashing) but I'm not sure if they Normally do that prior to start. I tried using spare key because someone said something about security system and out of the probably 20 times I've tried to roll it over I heard it almost start for a very brief second and nothing after that. Any feedback on either of these issues would be greatly appreciated.
    Thanks,
    Dave
    Y0TA PR0 likes this.
  2. Jun 11, 2018 at 11:50 AM
    I want to say the alternator may be the culprit.
    HecticEnergy likes this.
  3. Jun 11, 2018 at 12:44 PM
    Dave14711
    Dave
    Thanks T-Rex, I didn't think about the alternator. Is there any way for me to verify that?
    Dave
  4. Jun 11, 2018 at 1:23 PM
    Multi-meter
  5. Jun 11, 2018 at 1:26 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Either this^^^ or take it to an auto parts store and they can test them for you.
  6. Jun 11, 2018 at 1:27 PM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    I’m not a mechanic but...
    Even if the alternator is out, shouldn’t it still turn over with a jump?
  7. Jun 11, 2018 at 1:28 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Yes, until the battery is totally dead.
    4x4_Angel likes this.
  8. Jun 11, 2018 at 1:30 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    That's what i was thinking
    kenomouth64 likes this.
  9. Jun 11, 2018 at 1:32 PM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    ... once it gets started? Or are you saying to bring the alternator in (after it’s pulled off the truck....)
  10. Jun 11, 2018 at 1:36 PM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    ... so I’m not a mechanic because I can’t spell neutral? ...
    Oh, maybe you meant that other part...
    :D
    Sorry, cross thread talk...
  11. Jun 11, 2018 at 1:39 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    If I remember correctly the alternator has to be attached to the vehicle it is running on. I'd call them and ask. However, I don't believe it's your alternator. It's something else, I just don't know what.
  12. Jun 11, 2018 at 1:42 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME! Hope you find the cause and fix it.
  13. Jun 11, 2018 at 1:49 PM
    TOTU17
    TOTU17 New Member
    Main alt fuse could be out also
  14. Jun 18, 2018 at 9:52 AM
    hellonwheels
    hellonwheels New Member
    2013 Texas Edition
    The symptoms of the lights coming on and not shifting to 4hi or lo are the truck being in "limp" mode. Its what the computer does to allow you to keep running the truck to get it to a place to be worked on without letting itself be over-worked.
    Is this truck a Flex Feul? There is a new ECM update recall that corrects a problem with an alcohol sensor that can cause starting problems.
    Your problem most likely has nothing to do with the alt. as long as you still have batt power. Even if the alt. did die your truck should have run until it depleted the Battery.
    You need to check the things that are vital to make fire. Air, fuel, and spark
    rons23 likes this.
  15. Jun 18, 2018 at 10:02 AM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    Pull the battery out and have it tested.
  16. Jun 18, 2018 at 11:16 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    If the truck turns over with sufficient power, then my guess, would be that the battery is fine and the alternator is fine.
    I am betting you have a fault somewhere in the electrical. Could be the ECM has some solder that is cracked or a loose ground wire somewhere. Try lightly slapping the ECM with your palm and verify that all the wires are plugged in securely into the ECM.
    You also might want to look around for loose ground wires or frayed wires "grounding themselves out".
    If this is a Flex Fuel vehicle, those are known to have issues with the alcohol sensor.
    Honestly this could also be the dreaded secondary air pump failure. I wouldn't jump to conclusions though.
  17. Jun 19, 2018 at 4:57 AM
    hellonwheels
    2013 Texas Edition
    And if it is a secondary air pump issue, your 2011 truck should be covered by the extended warranty Toyota put out because of the common failures. If you haven't got it fixed yet it might be worth talking to the dealership. And if you did figure it out, let us know what the problem was.
  18. Jun 19, 2018 at 5:55 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    1. Check for ignition spark.
    2. Check for fuel pressure.
    rons23 likes this.
  19. Jun 19, 2018 at 12:21 PM
    Punisher17
    Punisher17 New Member
    My tundra has a master key (black) and valet key (grey). If you use the valet key it will eventually not even start the truck anymore. I had a basic key cut for keeping in case I needed another key made and lost all my master keys and it can unlock the front door. I tried starting my truck with that basic key that had no chip and it kept turning over but would not start. Just an idea.
  20. Jun 19, 2018 at 2:21 PM
    Uncle_Charlie
    Uncle_Charlie New Member
    2018 Tundra- Work truck package
    Have you checked for codes?
  21. Jun 19, 2018 at 2:54 PM
    Adam New Member
    put your key in. If the red light stays a blinky(security) your key lost its code. Happened to me. Try a different key if you got it.
  22. Jun 20, 2018 at 3:40 PM
    Adam New Member
  23. Jun 21, 2018 at 5:20 PM
    Twinky
    07 double cab work horse
    Do you have a check engine light on?
  24. Jun 21, 2018 at 5:31 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Dirty MAF
  25. Jun 25, 2018 at 12:21 AM
    Twinky
    Was kinda hoping to see a resolution to this one, or an update.
    A bad ground can literally cause a ton of issues. Its something that most people can do themselves but is overlooked cause its not an actual mechanical component.
    When a vehicle doesnt start its common to see ppl check, the battery post connection, starter, alternator, ect.... But forget to check the battery negative to body ground..
    That reminds me, ive been meaning to scrap the paint off my ground connections. Eh... Ill probably continue to put off instead, though.
  26. Jul 1, 2018 at 4:29 PM
    Brian3UR
    Brian3UR New Member
    2013 Silver Sky DC 4x4
    Drop in K/N filter with TRD airflow accelerator BullyDog GT Tuner 2.5" Suspension leveling kit TRD rear sway bar Line-X bedliner Charcoal Filter (in air box) delete Deleted screen in throttle body gasket Coolant to throttle body bypass LED lighting inside bed and under hood Center console from 2007 Tundra with LED light for cup holder Small amplifier and subwoofer to enhance factory radio BAMuffler TRD Dual Replacement system (on order) LED headlights, fog lights, brake, tail and interior lights Side mirror glass with turn signal indicators (from Platinum model)
    Check to see which codes are stored in the ECM (your local dealer or even AutoZone can do that). Post them here and I'll try to lead you in the right direction.
  27. Jul 1, 2018 at 4:49 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
