Tundra weird noise at start up- whistle
Discussion in '2.5 Gen Tundras (2014-2021)' started by Achuop, Feb 4, 2017.
  1. Feb 4, 2017 at 5:50 PM
    Achuop
    Achuop [OP] Stormtrooper 5.7
    Anthony
    Orange County, CA
    2015 Tundra Crew Max TRD 4x4
    TRD Pro grill, Magna Flow Exhaust, 3/2 leveling kit, TRD sway bar, black out emblems, Bakflip G2 cover, 20” ProComp wheels and Tires and lots of love and affection.
    So today my Tundra started making this weird noise on start up. A whining sound, like a belt or something.
    Has anyone dealt with this before.
    I'm only at 35,276 miles.
  2. Feb 5, 2017 at 5:59 AM
    Any sound clips?
    Sure it's not your gf/wife/signicant other?
  3. Feb 5, 2017 at 6:22 AM
    da_jeep_luva
    da_jeep_luva New Member
    Paul
    2017 CM and 2008 RCSB
    TRD Pro suspension, powder coated bumpers, wheels, tires, lowered, coated, list keeps going.
    Burrrrrrrnnnnnnn
  4. Feb 5, 2017 at 8:51 AM
    Achuop
    Anthony
    Orange County, CA
    Yes but I can't figure how to upload it. Keep getting a file extension error.
  5. Feb 5, 2017 at 8:53 AM
    Achuop
    Anthony
    Orange County, CA
  6. Feb 5, 2017 at 9:10 AM
    The whistle or the shut off noise? Not hearing much else
  7. Feb 5, 2017 at 9:12 AM
    Achuop
    Anthony
    Orange County, CA
    The whistle when start up. Not turn off.
  8. Feb 5, 2017 at 9:12 AM
    Are you running an after market intake?
  9. Feb 5, 2017 at 9:13 AM
    Achuop
    Anthony
    Orange County, CA
    Nope. All stock but exhaust.
  10. Feb 5, 2017 at 9:13 AM
    Throttle body spacer?
  11. Feb 5, 2017 at 9:15 AM
    Achuop
    Anthony
    Orange County, CA
    You think it's covered under warranty?
  12. Feb 5, 2017 at 9:17 AM
    Exhaust manifold gasket?
    Is it wet where you are? Perhaps water got its way onto a belt
    Tensioner
    Edit: appears normal
    Achuop[OP] likes this.
  13. Feb 5, 2017 at 9:18 AM
    Achuop
    Anthony
    Orange County, CA
    Not wet at all. It's been pretty dry here. I'm going to check it out again after I get out of bed.
  14. Feb 7, 2017 at 2:02 AM
    TTund16
    TTund16 New Member
    The belt could be slipping a little at start up.
    my old Tacoma made a similar sound for several seconds at start up ... especially if it was cold outside.
    air out the engine or best wait till next day before you start the engine and have someone (other than your ex) start the car. With the hood open, you may smell it if u have a good nose or maybe able to locate it better!
    I could smell mine even with the hood shut :)
  15. Feb 7, 2017 at 3:52 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Whatever it is, if it were me, I would take it to a dealer to have them look at it in the next day or so. Just in case.......
  16. Feb 7, 2017 at 6:09 AM
    Nyconickk
    Nyconickk New Member
    Nick
    2010 crewmax
    Full exhaust, intake
    does the noise go away after some time?
    What you could try is (with the engine off)
    Shoot some wd40 at each pulley or tensioner 1 at a time, starting the truck between each spray and see if the noise is affected upon start up.
  17. Feb 7, 2017 at 7:22 AM
    Achuop
    Anthony
    Orange County, CA
    The noise went away the next day. I'm almost at my 36,000 basic warranty expiration. Got a few more hundreds to go. Probably will take it in just in case.
  18. Feb 7, 2017 at 5:40 PM
    NJBBPTUNDRA
    NJBBPTUNDRA New Member
    Sal
    2016 Blazing Blue Tundra Platinum
    TRD Exhaust TRD Cold Air Intake TRD Sway Bar
    Mine is brand new and got the noise after I installed the TRD intake. I hear a whistling at startup, shutdown and when I accelerate as well. My friend's sequoia has a CAI and has the same whistling. After installing a CAI, you have slightly elevated engine noise in the cabin, so I'm sure you have under acceleration but very faint. Definitely nothing wrong with your truck, and if you look in your owner's manual, you will see that the Tundra will make noises up to 30 mins after shutoff.
  19. Feb 7, 2017 at 8:57 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    The TRD CAI and other CAI will cause the 'whistle' and there is a DIY to eliminate it. My point is that the 'whistle' related to CAI is known...
    NJBBPTUNDRA[QUOTED] likes this.
