Tundra Warranty Voided by Lift
Discussion in '3rd Gen Tundras (2022+)' started by KroppDuster, Aug 22, 2022.
  1. Aug 22, 2022 at 7:16 PM
    funE_man
    funE_man New Member
    Northern Illinois
    '23 Solar Octane Sequoia TRD PRO
    It's on Toyota Parts site now, and showing up @$1200 cheaper at some dealers without installation
    BJBlixt likes this.
  2. Aug 23, 2022 at 12:41 AM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Well…my long term plan was to always go with the OEM kit…just wasn’t soon so this may change things.
    The OEM kit is also only good for 3yr/36K miles so beyond that we could all be screwed either way…
    The other issue beyond an OEM lift is that some dealers (or Toyota if they are trying to play hardball) may cite your “larger tires” for premature failures on a suspension (or God forbid transmission part).
    Their OEM lift kit poster seems to suggest/show a larger tire and the show truck at SEMA portrays it with the kit but nothing is saying OEM lift AND larger tires included in warranty…just OEM lift.
    I think most of us understand that long term there could be issues…but LONG TERM is the key there not sub 10K miles.
    So here is hoping that this is a one off issue and this new third gen isn’t so sensitive to modifications that mild ones cause earlier issues than would have taken 50K+ miles to develop on previous generations for comparable usage :fingerscrossed:
  3. Aug 23, 2022 at 7:41 AM
    brucega7x
    brucega7x New Member
    2022 Tundra SR5 CrewMax 4X4
    If it’s truly an issue, we’re going to see a loooot of problems here in the next several months because a shit ton of people have RC levels and Westcott lifts.
    If there’s no influx, this guy was a fluke or wheeling the truck hard. Or both. I dunno.
    DBWA, BJBlixt and eddiefromcali like this.
  4. Aug 23, 2022 at 8:18 AM
    FI460
    FI460 New Member
    Rick
    2022 Limited CM/6.5' TRD OR 4x4
    I can't remember if it was on Instagram or Youtube, but he mentioned that the truck has been primarily a mall crawler.
  5. Aug 23, 2022 at 8:41 AM
    TownTRD
    TownTRD New Member
    Cris
    Bay Area, CA
    2020 Army Green TRD PRO CM
    Diff Drop.
  6. Aug 23, 2022 at 8:46 AM
    KroppDuster
    KroppDuster [OP] A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    In the actual video he flat out said that it's mainly been a pavement princess.
    However, he has tested it off road. If you dive into his YT channel, he's several vids of him taking it off road to test different trail scenarios and the various drive modes. He also has a video where he tests his truck against a stock 4WD without the OR package to see the difference in off road performance.
    So he has taken it off road. Maybe in one of those test he over extended the droop and it allowed the front shafts to pull out enough to damage the seals. If you watch the video, it looks like the shaft seals have been compromised vs torn CV boots. When lifting a vehicle...I feel like it's usually torn CV boots that are the first to go and not axle seals first, but that's based off my own personal experience with my old Taco.
    And, regardless of what it is, just like @bigjuice said...premature failure due to a lift shouldn't be this quick. It might reduce the over life expectancy of the axles by 10%-15%. It should not reduce the life by 80%-90%.
  7. Aug 23, 2022 at 9:02 AM
    Feel like the bearing would have to fail for the axle seal to see any additional stress.
    FI460 likes this.
  8. Aug 23, 2022 at 9:14 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Just one more reason to drive my 2/0 lifted 2016 until the wheels fall off.
    I had a conversation with a factory warranty guy about my front lift. He agreed my Toytech coilovers would obviously not be covered but everything else would. I told him my shocks were installed using the TRD PRO shock instructions and set at TRD PRO shock height. Since Toyota didn't seem to think any other changes were required when installing factory Toyota shocks at plus 2" it would be hard to say I caused a failure by using an aftermarket coilover.
  9. Aug 23, 2022 at 9:26 AM
    alex17117
    alex17117 New Member
    Alex
    2024 limited, Lunar Rock
    As a guy coming from a Tacoma, I can only wonder if there’s a needle bearing that is failing and causing the seal to be stressed. It was an easy fox to install a bushing on the Tacoma. Anyone want to pull the driver side cv and see what’s going on in there?!
  10. Aug 23, 2022 at 9:31 AM
    mass-hole
    mass-hole New Member
    I finally just watched the video and the dude is really whiny. He put a random 2" level on his truck that anyone could draw up in cad in their spare time(with the stock shocks), completely changed the range of motion of the front suspension, and put tires on that probably weigh 2x+ the stock tires and then proceeds to piss and moan about how Toyota suggested to him that lifting the truck was ok because they showed off a long travel truck at Sema. Even though Toyota themselves have created a lift kit that is properly engineered to keep the truck as reliable as possible and includes shocks(which keep the suspension in the correct range of motion), springs, knuckles, and TRD designed and developed front lower knuckles, front extended axle-shafts, front stabilizer links, front outer tie rods, front tie rod sleeves, front jounce bumpers, extended brake flex hoses, and Forged upper control arms manufactured by Roush.
    My guess is that some of the lift may be coming from the knuckles and some from the springs/shocks.
    Man up.
    yukonrider likes this.
  11. Aug 23, 2022 at 9:48 AM
    KroppDuster
    Bilstein 5100s
    Whiny or not...he hasn't done anything that literally hundreds of people have done to their 3rd Gens. Not only hundreds of people have done on the 3rd Gen but thousands of people have done on their 2.5 Gens.
    If people were tearing up axles on the 2.5 Gen with a 2" spacer, people would be burning down Toyota's US HQ.
    FI460 and DBWA like this.
  12. Aug 23, 2022 at 9:57 AM
    DBWA
    DBWA New Member
    Dave
    2022 Tundra TRD Limited 6.5' Bed
    @mass-hole I didn't find him whiny, he seemed to take a pretty straightforward and logical approach, if any thing it reminded me of a fairly cogent legal argument.
    1.) Toyota advertises Tundras (and other cars) performing actions or modified in a way that voids the warranty, which is misleading at best and possibly exploitative
    2.) Toyota dealers sell Tundras in a state that voids the warranty and won't specify whether or not they disclose this to the customer
    3.) A low mileage Tundra should be able to run a relatively small/common spacer and be tough enough to run bigger tires without breaking its axle
    I feel like those are all pretty reasonable. Point #3, I would argue, contains the most appeal to emotion of his 3 points, but I don't find myself disagreeing with him. It should be that durable--especially given its price tag and prior generation's durability. If anything I think @KroppDuster makes a good point that key details are missing and its hard to judge whether or not Toyota voided the warranty or the Dealership denied the claim. I do think @mass-hole you raise some good points of inquiry: was the lift he installed designed poorly, was it installed poorly, how did it impact the geometry and physical forces on the truck? I find it a drawback that you'd have to extend the axle-shaft to lift the truck by 2". If anything I think Toyota should step in and repair the truck and clarify what voids a warranty in the case of lifts.
    FI460 and ColoradoTJ like this.
  13. Aug 23, 2022 at 10:43 AM
    GreenSweeper77
    GreenSweeper77 New Member
    2022 Solar Octane Tundra TRD Pro
    So with a TRD Pro, would this be an issue with the Westscott leveling kit?
  14. Aug 23, 2022 at 11:06 AM
    mass-hole
    What did Toyota do to suggest that its ok to throw a random spacer in the truck? It may be a common mod, doesn't mean they can't provide pretty clear proof that such a mod could increase stress on components. And that was my point in listing what the TRD lift includes(which is probably what was on all the Sema trucks). Its a pretty extensive list that pretty much replaces most of the components outside of the frame rails with the exception of the lower control arm. Clearly some thought was put into it just to achieve 2.6".
    The dealer can do what they want to the truck not being actually owned by Toyota, just like they can put a market adjustment on the price. The dealer can also choose not to make a stink about the warranty on a truck they themselves modified with known components and the customer paid them for.
    My point is, the guy modded his truck with a random spacer lift and is running 70 lb 35" Geolandars on offset wheels and is now pissing and moaning that something broke.
    ColoradoTJ likes this.
  15. Aug 23, 2022 at 11:12 AM
    mass-hole
    I mean if it truely is a fault of the lift then that sucks for everyone wanting to do a cheap lift on the 3g Tundra. For everyone else, they can spend the money for the TRD lift which, honestly, if its $1200 seems like a bargain for what you get.
    At the end of the day though, hes got a lift, 70 lb 35's and likely more negative offset wheels. Yeah they seem like basic mods but the stress on the front end is probably considerably higher.
  16. Aug 23, 2022 at 11:23 AM
    FI460
    FI460 New Member
    Rick
    I'm not sure you understand what pissing and moaning means. I think he brings up some good points.
    It would be absurd IF the 2022 Tundra can't handle a 2" spacer lift. That will be a hell of a talking point for the Ford/ Chevy/ Dodge salesmen.
    That this is the first report of this issue with hundreds of other guys running nearly identical setups suggests that it's a defect with the parts on this particular truck though. We all know that Toyota should take care of his problem.
    RookieEP likes this.
  17. Aug 23, 2022 at 11:24 AM
    This isn’t nothing new fellas. Choose to modify a vehicle…
    You become the warranty department for what system was modified.
  18. Aug 23, 2022 at 11:46 AM
    KroppDuster
    Bilstein 5100s
    Just to level set the convo here...
    1) YT content creator aside, I don't think anyone here is expecting Toyota to warranty items that are impacted by aftermarket mods.
    2) This is the primary concern here: Whether or not the 3rd Gen is capable of handling a basic spacer without destroying the axles within an EXTREMELEY short period of time.
    I guess to summarize it...
    • Does adding a spacer add stress? Yes.
    • Do most people understand that it reduces component life? Yes.
    • Does any one who installs a spacer lift expect their axle to have this damage in less than 5,000 miles? Hell no.
    LukeS, bigjuice, DBWA and 3 others like this.
  19. Aug 23, 2022 at 2:13 PM
    #49
    brucega7x
    If my (supposedly) bad ass $55k 4X4 can’t handle my 1.75” RC level and 35” tires I’m 100% trading it in ASAP.
    The idea of that is the most absolutely ridiculous thing I’ve ever heard of.
    FI460 likes this.
  20. Aug 23, 2022 at 3:19 PM
    #50
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Nothing exists for the 3rd gens and it is nearly impossible- the RC 6in lift has one, but you have to cut the frame to install it.
    Just crawled under my truck today to check the axles, all is well on mine with almost 6k miles and over 100m this past weekend on shitty fast dirt roads. Truck has been lifted since it had 500 miles on it, but was done right with coilovers, bump stops, UCA's, rear springs, rear shocks, panhard bar, sway bar relocation kits, etc.
    AZBoatHauler likes this.
  21. Aug 23, 2022 at 3:42 PM
    #51
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    Nope, not finding it. Do you have a part number handy?
  22. Aug 23, 2022 at 4:27 PM
    #52
    LukeS
    LukeS New Member
    Luke
    Northeast PA
    Army Green Limited TRD OR
    funE_man likes this.
  23. Aug 23, 2022 at 4:53 PM
    #53
    Maharisc
    Maharisc w/Patty
    Karl
    Excellent, Thank you.... 37% off at my local dealer...
    FI460 and BJBlixt like this.
  24. Aug 23, 2022 at 5:51 PM
    #54
    SawF16
    SawF16 New Member
    FI460 likes this.
  25. Aug 23, 2022 at 6:01 PM
    #55
    bigjuice
    WA State
    2024 Terra TRD Pro
    Here you go…another member posted it last week
    Mrconnsmythe likes this.
  26. Aug 23, 2022 at 6:04 PM
    #56
    bigjuice
    WA State
    2024 Terra TRD Pro
  27. Aug 23, 2022 at 6:31 PM
    #57
    GreenSweeper77
  28. Aug 23, 2022 at 7:40 PM
    #58
    DexterL
    DexterL New Member
    No, it’s a far superior lift (and almost 3x higher) but comes with shocks that aren’t as nice as the fox trd pros
  29. Aug 26, 2022 at 11:42 AM
    #59
    outlaw.taco
    outlaw.taco New Member
    Houston
    From TRD Lift Kit Installation Guide
    This combination should alleviate the stress on driveshaft, aftermarket need to catch up quick on this.
  30. Aug 26, 2022 at 11:47 AM
    #60
    DBWA
    DBWA New Member
    Dave
    What's the make up of the kit? What height increase?
    UPDATE: Found this on a TFL Now video at SEMA
