Tundra tried to strand me today
Discussion in '2nd Gen Tundras (2007-2013)' started by Gunnyart, Mar 19, 2019.
  1. Mar 19, 2019 at 3:46 PM
    Gunnyart
    Gunnyart [OP] New Member
    Art
    2007 Double Cab 5.7
    Brand new here and hope y'all have a clue what might be going on.
    So I ran my truck trough the car wash and the next time I shut it off (2-3 minutes later) and tried to restart it (ten minutes later) it acted like the battery was completely disconnected. No power at all. I called for a jump but before they arrived I popped the cover off the fuse block under the hood to see and I heard what was probably a battery relay click and sure enough everything was back on. I did loose my radio presets etc. but everything else seems normal. Battery voltage is right in the middle of normal.
    I'm guessing perhaps something shorted when it got wet but I really have no idea.
    BTW the fuse block was dry when I removed the cover
    Any clue where to start looking?
  2. Mar 19, 2019 at 3:55 PM
    Mnorris1206
    08 tundra
    No corrosion on battery terminals or no loose connections? And is their a cover on the positive post ? That's all ik lol
    15whtrd likes this.
  3. Mar 19, 2019 at 4:02 PM
    Gunnyart
    Art
    2007 Double Cab 5.7
    No corrosion or loose connections also no positive battery cover though.
    Mnorris1206 likes this.
  4. Mar 19, 2019 at 4:06 PM
    Mnorris1206
    08 tundra
    Yep they don't come with one. That is strange I'm sure someone will chime in soon. Ik @15whtrd may have some good info
  5. Mar 19, 2019 at 4:22 PM
    15whtrd
    15whtrd Mr. Blonde
    That’s a tough one. Possibly the wires underneath the fuse block got too wet and somewhat shorted out. Hard to diagnose when it doesn’t continue doing it. Make sure your battery is connected really solid. Check the grounds and their final termination away from the battery. Other than that I got nothing.
  6. Mar 19, 2019 at 4:24 PM
    Gunnyart
    Art
    2007 Double Cab 5.7
    That's about all I can figure as well. Thanks
    15whtrd[QUOTED] likes this.
  7. Mar 19, 2019 at 4:25 PM
    Mnorris1206
    08 tundra
    Hand wash for now on lol but at least it's not a ridgeline and it didn't catch fire .
  8. Mar 19, 2019 at 4:29 PM
    Gunnyart
    Art
    2007 Double Cab 5.7
    Well Thank God for that! ha.
    Mnorris1206[QUOTED] likes this.
  9. Mar 19, 2019 at 4:44 PM
    The positive battery terminal should have one. The negative doesn't need a cover. H2O can be a conductor.
    15whtrd and Mnorris1206[QUOTED] like this.
  10. Mar 19, 2019 at 5:09 PM
    Mnorris1206
    08 tundra
    Why did I see it said negative battery cover
    15whtrd likes this.
  11. Mar 19, 2019 at 5:25 PM
    15whtrd
    15whtrd Mr. Blonde
    Good call!!
  12. Mar 20, 2019 at 4:21 AM
    Dr_Al
    Dr_Al New Member
    Al
    While playing around with the TechStream software I noticed that one of the things you can do is actuate the starter solenoid. I didn't try it but I assume that when you turn the key to the start position it tells the computer you want to start the engine and it sends a signal to the solenoid. If so then your problem could have been the computer just needing to be reset. If so and it happens again I would pull the fuses just for the ECU for a minute to reset it.
  13. Mar 20, 2019 at 5:23 AM
    Ericsopa
    Ericsopa Old man and the sea
    Since your radio also lost all its presets, I'd pull both terminals off the battery and reset everything, clean the fittings really well, clean off the battery top then hook it all back up. Then coat the battery terminals with a protective grease. Might want to refresh all the ground connections on the body that you can access, too.
  14. Mar 20, 2019 at 5:51 AM
    TXDrifter
    TXDrifter BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Many times when having electrical issue many people overlook the engine block ground, I would check and see if its tight.
    Watt maker likes this.
  15. Apr 3, 2019 at 10:29 AM
    Gunnyart
    Art
    2007 Double Cab 5.7
    It happened again!:mad:
    Just like before only I didn't just come from the car wash. As before I popped the cover off the fuses and tapped on stuff and viola' started working again. I replaced the "sub batt" relay but while I had it out I tried to start the truck and it did just fine so it probably had nothing to do with the problem.
    I'm going to need to have my wife drive it for a few weeks and just pray it doesn't happen to her too.
  16. Apr 3, 2019 at 11:54 AM
    15whtrd
    15whtrd Mr. Blonde
    Sounds like a bad connection somewhere under the fuse box or on the fuses them selves. Check for any type of oxidation or corrosion on any of the connections in and under the fuse box. Similar to when a lightbulb isn’t working and then you tap it and it starts to work again.
  17. Apr 3, 2019 at 12:16 PM
    Radioclash75
    Radioclash75 New Member
    Hooper
    Chicago area
    2018 Tundra Sport 5.7FlexFuel. Black-Beauty
    If you said you lose radio and electric turn radio on so you can hear it with key on, not running. Gently start moving harness around until you get to where the radio starts sputtering. That will put you in area you need to inspect closer.
  18. Apr 5, 2019 at 6:32 AM
    Gunnyart
    Art
    2007 Double Cab 5.7
    I didn't loose my radio presets this time. (last time either actually. It brought me back to the set up screen when I powered on and I thought it meant I had lost them but the radio battery/capacitor probably prevented that.)
    I'm thinking it must be in the fuse holder or a bad ground.
  19. Apr 5, 2019 at 6:47 AM
    Radioclash75
    Hooper
    Chicago area
    Not losing presets because there is a memory, but if losing power because of loose plug you can have radio on, again with engine not running so you’re working off battery power only, and listen to it or have someone watch the dash as you go by the fuse block. If you start moving around the harness and plugs, when you get to the one with a bad connection you will hear the radio come in and out or lights on dash start to flicker. That’s when you know you’re in right area and start digging in that spot for bad ground or loose pin in plug.
  20. Apr 5, 2019 at 6:54 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Any modifications to the truck? Alarms, etc. A 12 year old truck with a finicky issue like this is typically an easy fix once you find the little bastard. Some great tips here. Process of elimination time. Nice truck BTW... My favorite color!
  21. Apr 5, 2019 at 8:45 AM
    Gunnyart
    Art
    2007 Double Cab 5.7
    I'll try that thanks.
  22. Apr 5, 2019 at 8:50 AM
    Gunnyart
    Art
    2007 Double Cab 5.7
    Thanks. I like the color too and happy accident it matches my wife's Honda color.
    It has an aftermarket head unit (JVC) but it was installed with a harness no wires were cut and spliced.
    It also has a couple LED lights on the front ranch hand bumper but it's pretty straightforward setup with it's own separate switch that doesn't seem to be a problem.
    I don't see evidence that it ever had an alarm.
  23. Apr 5, 2019 at 8:53 AM
    Radioclash75
    Hooper
    Chicago area
    Go
    good luck, electrical gremlins are always a fun adventure
  24. Apr 5, 2019 at 8:56 AM
    Gunnyart
    Art
    2007 Double Cab 5.7
    Grrrrrrrrrrrrrr
    Radioclash75[QUOTED] likes this.
