Tundra Transmission fluid coming out of dipstick, breather tubes rusted out
Discussion in '1st Gen Tundras (2000-2006)' started by Hobojordo, Jan 23, 2020.
  1. Jan 23, 2020 at 1:29 PM
    Hobojordo
    Hobojordo [OP] New Member
    2000 tundra v8 4x4
    Hi everyone,
    I just got a 2000 Toyota Tundra 136k miles..it had been on salty roads and thus the breather pipes going into the front differential and transmission/transfer case are completely rusted out. What is the easiest way to reach those? I'm sure they are too rusted to just unscrew, will I have to pull the motor/drop the tranny?
    Also what is the little plastic covered black gearbox on the back of the tranny? It's cracked open....
    Thanks for any tips!!
    Jordan
  2. Jan 23, 2020 at 9:40 PM
    Whothefat
    Whothefat New Member
    Clark
    Las Vegas
    2006 Black Tundra DC 4x4
    Hey Jordan welcome from Nevada.
    I probably can’t help much but if you post some pictures of what you’re talking about some other members will be better equipped to assist you
    Hobojordo[OP] likes this.
  3. Jan 24, 2020 at 11:02 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    The black box is probably your 4wd actuator.
  4. Jan 24, 2020 at 12:57 PM
    Professional Hand Model
    Hand Protectors
  5. Jan 27, 2020 at 11:06 AM
    Hobojordo
    2000 tundra v8 4x4
    These are both rusted out down below..
    This is the broken box on the back of the tranny
  6. Jan 27, 2020 at 11:21 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  7. Jan 27, 2020 at 11:41 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Normally, those little breathers just pull right out of the tube the rest in. I used a pair of needle nose pliers I think. In your case, you're going to have to be gentle and see what happens. It almost looks like most of the breather is gone.
  8. Jan 27, 2020 at 12:13 PM
    Hobojordo
    2000 tundra v8 4x4
    Do you think those being blocked would cause the pressure to build up in the transmission that led to the overflowv out of the dipstick? They seem to go to the four-wheel drive actuator and the differential.... Not sure why that transmission would overflow in that case... Is there another vent for the transmission somewhere?
  9. Jan 27, 2020 at 12:14 PM
    Hand Protectors
    Pull those rusted corpses out and install new breathers.
  10. Jan 27, 2020 at 12:17 PM
    Hobojordo
    2000 tundra v8 4x4
    I cut them off below the rusted out vents... But the problem is actually worse farther down the line than those... Where those rubber hoses connect to metal tubes that then go into the differential. Those metal tubes are rusted out I can crush them with my fingers
  11. Jan 27, 2020 at 12:17 PM
    Hand Protectors
    Those 2 you pictured are ADD and front diff breathers. The transmission has one on top of the case on top of the transmission itself. You have to reach your arm up there to feel for it. Basically its inaccessible.
  12. Jan 27, 2020 at 12:19 PM
    Hobojordo
    2000 tundra v8 4x4
    Oh okay thank you.... I'm sure the transmission one is then clogged and rusted also.. may have to drop the transmission to reach it and work on it huh?
  13. Jan 27, 2020 at 12:19 PM
    Hand Protectors
    Your truck is probably NEFTR (not economically feasible to repair) unless you can DIY. The rust cancer has taken hold.
  14. Jan 27, 2020 at 12:29 PM
    Hobojordo
    2000 tundra v8 4x4
    Perhaps.... It's borderline. I can do it myself , and it's a good motor..136k with and a new timing belt..but yeah...rust .. ugh..
  15. Jan 27, 2020 at 12:31 PM
    Hand Protectors
    Looks like you have a leaking Valve Cover Gasket (dripping down on exhaust).
  16. Jan 27, 2020 at 12:50 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    That frame looks to have some serious rust. You might have rusted through areas, or close to it.
    Have you checked the frame from front to back for rusted through holes, or weakened frame?
    Especially around the front and rear suspension. Drop the spare and look at the cross-member back there also.
    NY trk?
