Tundra towing capacity overstated?
Discussion in 'Towing & Hauling' started by Starrholdings, Apr 13, 2020.
  1. Apr 15, 2020 at 3:57 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Plenty of threads on this. There’s different Types but generally they don’t alter the existing suspension except for cutting your jounce bumper. They go between the. Frame and leaf spring. If one goes bad you won’t have jounce bumper on that side. Some come with internal bumpers so if it does go flat then it just functions like a normal truck. Look into sumo springs as well if your towing just occasionally and generally tow the same load each time.
    TTund16[QUOTED] likes this.
  2. Apr 15, 2020 at 4:18 PM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    Did you wait until the 1000 mile mark before towing?
    Tundyfundy likes this.
  3. Apr 17, 2020 at 7:46 PM
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    So is ford. New F150 having a bad day. Thats a new jayco 28ft trailer. badday.jpg
  4. Apr 18, 2020 at 12:49 AM
    Tundyfundy
    Bay Area, CA
    TROLL. Just arrived home after a 500 mile trip from the Bay Area towing my 26 foot TT loaded down. 7500 lbs of easy riding rolling down the highway. Definitely the dog wagging the tail not the other way around.
  5. Apr 18, 2020 at 3:11 PM
    Half track
    Rob
    Western Nevada
    Tow Mirrors
    Troll: I see you have modified your suspension. Your suspension has added about 300 lbs to your truck weight. And going with an off road suspension and lift kit, I'm am not surprised you trailer is wagging the tail.
    That said, must trucks that add left kits and off road suspension lose some stability when towing. And I bet your hitch weight is closer to 1000 lbs. See what your tongue weight is and adjust as needed.
  6. Apr 18, 2020 at 3:38 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I’ve pulled well over the Tundra’s weight rating when I was younger and dumber, and never had any issue. I’d say something’s off like @ColoradoTJ said, so listen to the expert before doggin the Tundra bro beans.
  7. Apr 18, 2020 at 4:17 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    You have 2000 lbs of cargo including hitch weight and you expect it not to squat? I tow my 5000 lb bay boat with no problems at all. Truck barely squats with 450 lbs on the hitch. My truck is leveled with stock rear.
  8. Apr 20, 2020 at 4:06 AM
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    Trade it in, you will never be happy with it. I moved from my V10 F350 to the 5.7 Tundra and other than a bit softer rear suspension have always felt it was a better tow rig.
  9. May 17, 2022 at 7:26 PM
    Leverguns
    Leverguns New Member
    Tommy
    2019 Platinum Crewmax
    Bilstein Sway bar and heavy duty rear springs
    I have a 2019 Platinum CW,
    Same issue, rear sag.
    Called General Springs and installed 5 leaf heavy duty rear springs.
    I tow a 30’ flagstaff, North Carolina to Yuma AZ and back 8.7 mpg average over all.
    Hitch setup is 12K Equalizer.
    Bilstein shocks all 4 corners.
    Stock suspension leaves a lot to be desired.
    Great truck!!!
    Forget airbags or sumo springs, bandaids at best.
    Lake.Life24 likes this.
  10. May 18, 2022 at 2:39 PM
    Half track
    Rob
    Western Nevada
    Tow Mirrors
    Woo! With a front living room slide , your hitch weight got to be about 1,200 lbs. How does that tow up a 7% grade?
  11. May 18, 2022 at 7:41 PM
    Leverguns
    Tommy
    Tows great.
    Power was never the issue.
    The suspension was always a problem.
    I tried sumo springs: some people say they work, not for me. They acted as a pivot point.
    I tried airbags: what a nightmare that was on a long trip, nothing but a rodeo going on there.
    I almost went to a F250 after that trip.
    I then started digging into spring rates.
    Springs on the rear were not designed to tow.
    I replaced them and all is good.
    Thinking of going with bigger brakes, that will only be as a precautionary measure for long downgrades.
    But regardless what you drive there’s always that long downgrade to be cautious of.
    Gotta love Tundra,,
    Loaded with trailer 14.5K
    Kungfuamp likes this.
  12. May 18, 2022 at 8:53 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    14.5k lbs? Is that your trailer weight or the combined weight of your truck and trailer?
  13. May 18, 2022 at 9:04 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Please share what springs you upgraded to.
    Doxiedad likes this.
  14. May 18, 2022 at 9:04 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Uhhhh 4000 pound trailer and it’s the tail wagging the dog? You did something wrong somewhere. Did you use the same positions on your weight dist hitch as the ford?
    I’ve towed weigh more than that (pun intended) and had no issues. For that light of a trailer I wouldn’t even bother with a wdh I’d just use a ball and be done
  15. May 18, 2022 at 9:07 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    3 words.
    Roadmaster active suspension. /endthread
    CoffeeAddict and Terndrerrr like this.
  16. May 19, 2022 at 3:18 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    I checked them out again after reading your post, been eyeing them for some time, do you need to use a WDH with the RAS system?
  17. May 19, 2022 at 3:51 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I never did when I had them on my truck. Loved RAS
    OHwendTrd[QUOTED] likes this.
  18. May 19, 2022 at 3:55 AM
    WDH should still be used when indicated. RAS helps the truck handle loads better (reduce squat) by adding spring tension to the rear leafs. It does not replace the function of a WDH. I only use a WDH with my travel trailer, RAS wouldn’t replace its function there.
  19. May 19, 2022 at 3:57 AM
    #49
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Thanks, both comments are helpful, looking to buy a TT this spring and I'm prepping my brain to handle this.
  20. May 19, 2022 at 4:00 AM
    #50
    OHwendTrd
    Josh
    21 SR5 3UR-FE
  21. May 19, 2022 at 4:02 AM
    #51
    Lake.Life24
    Shawn
    Upstate, NY
    For a travel trailer I would absolutely get a WDH. I’ve never towed a TT. Only equipment. When pulling a giant box that can catch wind I would take all necessary precautions. You can’t put a price on safety
  22. May 19, 2022 at 4:06 AM
    #52
    I’ve run both the chain style and the friction plate equalizer style WDH and really like the friction plate style better. Doesn’t need a separate sway control and feels very solid.
    Retired...finally likes this.
  23. May 19, 2022 at 4:12 AM
    #53
    Leverguns
    Tommy
    I used (General Springs) Heavy Duty (5) leaf on the rear. 2,500 lb rating ea.
    Empty they ride just like you want without all the harshness.
    Loaded, let’s just say they do their job.
    Most important thing when towing is making sure your weight distribution hitch is setup correctly.
    I live in the Smokey Mountains, so I travel plenty of steep grades constantly.
    correction: total weight of rig is 15,200 loaded.
    Truck loaded: 7,300 lbs
    Trailer: 7,900 lbs
    When properly equipped Tundra is a hard truck not to love.
    Safe driving and awareness play a huge part in towing heavy as well.
    ZPhilip[QUOTED] likes this.
  24. May 19, 2022 at 4:19 AM
    #54
    Leverguns
    Tommy
    I corrected the stated weight.
    Weight is: Truck-7,300/Trailer-7,900.
    Tongue weight -875 lbs, included in Truck weight.
    All in all it seems to be a great setup and safe.
    Nasty winds across the open plains I had no problem with.
    I also NEVER drive over 62 mph.
  25. May 19, 2022 at 6:18 AM
    #55
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    That is one of the biggest issues I see. Drivers towing loads near or at the max capacity for their tow vehicle, and going 80mph.
    KNABORES likes this.
  26. May 19, 2022 at 6:38 AM
    #56
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    That's a little heavier trailer than I'm looking to get so I'm glad to hear you have no issues.
    I'll be getting myself an Equal-i-zer and getting a hitch shop to set it up for me professionally.
  27. May 19, 2022 at 6:38 AM
    #57
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My wife and I were on the verge of buying a 5300 lb trailer this week and I was planning to just tow it the ~15 miles on the highway with my regular ball mount and then towing it back when I could get an appointment to get a WDH. My wife (after admitting she doesn't understand anything about this) freaked out and decided that was unsafe and we had to get a WDH first. So while the trailer was sitting on the street at the seller's house waiting for us to get an appointment at a hitch shop, it got sideswiped. :facepalm:
  28. May 19, 2022 at 6:56 AM
    #58
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    I wasn't going to comment on here since OP is long gone but it seems the thread now has a life of its own.
    My RV tongue weight is about 700lbs loaded and I routinely tow it for short trips without the WDH for maintenance, loading, cleaning, etc.
    It really only evens out the rake even w/o the WDH on a stock CM Platinum. Something is seriously wrong with OPs setup or suspension. And this is coming from someone that regularly dogs on the Tundras towing capacities.
  29. May 19, 2022 at 7:53 AM
    #59
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    Surprised nobody's brought up the benefits of a re-gear. Seems like a solution worth pursuing for anyone towing and/or rolling bigger wheel/tire combos. I'm looking into it, anyway.
    I've towed plenty of times ... heavily loaded 21' toy hauler, heavily loaded 7x14 enclosed trailer, and smaller stuff. Proper load distribution + tongue weight + hitch height + air bags and I've never had any issues other than miserable fuel economy. Truck wasn't lacking for engine or braking power.
  30. May 19, 2022 at 8:05 AM
    #60
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    OP perished in a transmission related thermobaric detonation.
    glowblue, OHwendTrd, Oey12 and 7 others like this.
