Tundra stereo sound issue
Discussion in 'Audio & Video' started by Lgs503, Jul 22, 2018.
  1. Jul 22, 2018 at 2:50 PM
    Lgs503
    Lgs503 [OP] New Member
    Sorry if this has been posted before, I searched and saw some similar threads but they were mostly with aftermarket stereos.
    I have a 2012 tundra crew max and the stereo seems to be working but no sound is coming through the speakers.
    Nothing weird has happened the battery didn’t die or anything. I went to work and the stereo worked fine and when I went to leave it would power up and everything functions but no sound comes through.
    Just to be clear this is the stock sereo.
    Thanks for the help
    Josh
  2. Jul 22, 2018 at 2:55 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    Did you mute it with the steering wheel controls by accident?
  3. Jul 22, 2018 at 3:51 PM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    or press the pause button on the head unit ?
  4. Jul 22, 2018 at 3:51 PM
    Lgs503
    Nope, and it doesn’t beep when I hold down the mode button and turn the stereo off either.
  5. Jul 22, 2018 at 3:53 PM
    Scpringle
    Jackson MS
    you may want to disconnect the battery for a few min and give it a refresh so to speak . Any thoughts from the board ?
  6. Jul 22, 2018 at 3:53 PM
    Lgs503
    Nope, I thumb through all the different modes, cd, radio, none of it works. I mean it appears to be working but no sound comes out. The radio seems to be functioning, display works, it know what song is playing.
  7. Jul 22, 2018 at 4:01 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    Did you push AND hold mode to rule out the mute? I had same issue once.
  8. Jul 22, 2018 at 4:09 PM
    Did you confirm the wires are plugged into the head-unit?
  9. Jul 22, 2018 at 4:34 PM
    Lgs503
    I didn’t check at the head, I’m assuming I need to pull the dash apart to do that? Seem like there has to be some other fuse or something?
  10. Jul 22, 2018 at 4:35 PM
    I think you need to pull the vent clips off to remove the HU to check.
  11. Apr 13, 2020 at 12:51 PM
    PDRTUNDRA
    PDRTUNDRA New Member
    Sorry to bring up a old thread but has anyone figured out this problem? I was just driving today and the radio works fine but i have no sound at all for anything 2018 Platinum JBL system
  12. Apr 13, 2020 at 1:12 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Is there an amp fuse somewhere? Maybe check there first.
  13. Apr 13, 2020 at 1:48 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Does the truck have a separate amp under the seat maybe? Maybe the issue is at that location or does the head unit power the speakers?
  14. Apr 13, 2020 at 3:08 PM
    PDRTUNDRA
    I’ve checked all the fuses and nothing. It has a amp under the passenger side seat and I’m planning on replacing it which some research I did on the forums here and hoping that will fix things. Sense I bought the truck 3 weeks ago the amp has always felt a bit weak. Compares to my buddies tacoma with the same jbl system.
  15. Jul 5, 2020 at 8:23 AM
    Apinion
    Apinion New Member
    2015 Black Tundra Platinum
    Same problem 2015. Nothing changed. Got to destination and everything was great. Went to leave later in the evening and now no sound. All buttons operational, but no beeping from HU and no volume.
  16. Mar 6, 2021 at 5:28 PM
    Elvio b
    Elvio b New Member
    2018 tundra platinum
    Hello I have a 2018 tundra and everytine I turn on the truck on I hear a popping sound from the speakers.i already disconnected the amp and the popping sound is gone when I restart the truck but when I plug the amp again and start the truck it does the same thing.iz anyone having this issue,need help
  17. Apr 5, 2021 at 7:18 PM
    mas2021
    mas2021 New Member
    2011 Toyota tundra crew
    My 2011 platinum is doing the same thing. No sound comes in or out like it's shorting out. Then it may play for a few then it may go back out again. I checked the wires at the amp under the passenger seat but they were all connected. It does it with the blue tooth and the sat radio. Obviously a shorting issue.. any suggestions. Thought about just buying an android radio and putting it in.
