Tundra Stalking, er...um, SPOTTING with Charlie™ (2.5th Gen Edition)!
Discussion in '2.5 Gen Tundras (2014-2021)' started by PennSilverTaco, Sep 23, 2019.
  1. Jun 21, 2022 at 12:00 PM
    #511
    Retired...finally
    Canadian dollars are different aren't they? Maybe the pound is too. Yeah, that's my story. :hattip:
  2. Jun 21, 2022 at 12:12 PM
    #512
    TundraRunner481
    TundraRunner481 Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    So almost 1000# over pay load, no big deal! If they got into a good crosswind, good luck to them!
  3. Jun 21, 2022 at 1:21 PM
    #513
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    I ain't saying anything else....
  4. Jun 21, 2022 at 1:59 PM
    #514
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Have you not dove into the proverbial shitstorm that is the 2nd/2.5 gen Tundra payload discussion?
  5. Jun 21, 2022 at 6:23 PM
    #515
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck
    Please see signature!
    No; Can't say that I have...
  6. Jun 21, 2022 at 6:31 PM
    #516
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    We use Kilos, and less of them to do the same thing.
  7. Jun 21, 2022 at 6:38 PM
    #517
    Wixo
    Wixo The Best Member
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    Please link it
  8. Jun 21, 2022 at 6:58 PM
    #518
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I can also remember small, “lightweight” 5th wheel trailers, one brand made locally, that didn’t work over a ‘90’s F150. No slide-outs, no A/C maybe 20’ overall… I have no idea on weights, but the one an old neighbour had I’d guess at 4000-4500 lbs.
    A far cry from most of the behemoth 5’ers on the market today.
  9. Jun 21, 2022 at 8:01 PM
    #519
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I usually try to distract the wife really quickly when she sees one of those triple axle fifth wheels that are bigger than our house and starts drooling.
  10. Jun 21, 2022 at 8:30 PM
    #520
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    @Cpl_Punishment
    This 2014 Double Cab SR5 was totaled, and the current owner repaired it after getting it cheap; The truck has a rebuilt title, but you would never guess by looking at it, and it has only 60K miles!
    June 19th, 2022:
    Springtown, Pennsylvania
    bulldog93 likes this.
  11. Jun 21, 2022 at 8:32 PM
    #521
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    ZappBrannigan likes this.
  12. Jun 21, 2022 at 9:09 PM
    #522
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    …with zero tongue weight on the rear of the Tundra. That is what hamstrings the Tundra and most other half tons out there when it comes to heavy trailers.
  13. Jun 21, 2022 at 9:13 PM
    #523
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Mmhmm. Give me enough time and I could pull that shuttle with one hand too. But I ain’t carrying it.
  14. Jun 21, 2022 at 9:40 PM
    #524
    Good Lord.
    In the past year I have seen two Ram 1500 trucks with the air suspension that failed with rather large trailers hooked to them without LDH’s. The rear bumpers were almost on the ground. Looked pretty scary.
  15. Jun 21, 2022 at 10:12 PM
    #525
    Wow. I can only imagine what that is like to tow.
    They have airbags or something on the rear suspension to help with the pin weight. So if that is the trailer that was posted by another member, 2180 lbs and the 11280 lbs is unloaded vehicle weight. That’s 19.4% pin weight.
    Even scarier is what that trailer is rated for at 15880 lbs. that would put his pin weight at over 3000 lbs.
    I did some testing with my truck and when I have exactly 3000 lbs in the bed I’m just barely into the overload springs. This is where I have to start being careful. I can only go another 600 lbs + myself to be at max capacity.
    This load I actually had to move the hitch up one position up to level up the trailer. This also the day I said my next trailer will have hydraulic jacks. I also called myself a moron for 80 miles coming out of the mountains in a flippen blizzard at -7*F (by the time I got home it was -14).
    I had just started getting into the overloads so I was around 3000 lbs pin weight. Trailer was pretty heavy. This was my wife’s Valentine’s Day gift. 13873B61-B530-46B9-927F-2C8DB6773BC8.jpg
    As I promised myself, my next trailer would be more heavy duty and have hydraulic jacks. This load, I was at max capacity. Pin weight was around 3550 lbs or so.
    What a lot of people don’t even consider since they install LR E tires is running out of capacity. I can only go over my maximum pin weight of 3808 lbs by 100 lbs before I run out of tire capacity. Now if I step up to a 275/70/18 I would have a lot more tire capacity for the added safety factor (and probably will on my next set).
  16. Jun 22, 2022 at 12:27 AM
    #526
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I wish Toyota would make a 3/4 and a 1 ton. I would be all over that.
  17. Jun 22, 2022 at 1:12 AM
    #527
    So would I.
  18. Jun 22, 2022 at 5:10 AM
    #528
    Retired...finally
    Must be the case since the Honda Element had a towing capacity of 1,500 lbs in the US but 1,500 KG in Australia.
  19. Jun 22, 2022 at 5:18 AM
    #529
    Terndrerrr
    Music City
    6UR-FE
    They’ve got the engine for it. The iForce max has better HP/torque numbers than every gasser HD truck on the market. I’d like to think they’re one step closer to a 1T truck, but it’s hard to be hopeful at all.
  20. Jun 22, 2022 at 7:16 AM
    #530
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Which weight distribution hitch do you recommend for towing the Space Shuttle with my Tundra?
    And what speed do I need to achieve for liftoff?
    #holdmybeerandwatchthis
  21. Jun 22, 2022 at 9:33 AM
    #531
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    I look at this thread and it made me think. Currently running "empty" with a few items in the bed I have about 2,700lb on the rear axle. In theory I can put up to 4150lb on the axle. Make room for some stuff in the truck and I figure you could pull a fifth wheel if you keep the pin weight below say 1200lb.
    There are few out there that might qualify.
    IMO, all of these are all too big but the numbers might work.
    Granted you will probably want airbags or SumoSprings before you go down this road.
    Now, this would be very Tunda toe-able and might be a great little unit.....
    https://escapetrailer.com/escape-5-0-specifications/
  22. Jun 22, 2022 at 7:29 PM
    #532
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    June 19th, 2022:
    Cpl_Punishment likes this.
  23. Jul 1, 2022 at 7:52 PM
    #533
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2018 DCSB TRD Sport; The owned moved it and I took a second batch of pictures...
    June 25th, 2022:
    Carlisle, Pennsylvania
  24. Jul 2, 2022 at 11:00 AM
    #534
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
  25. Jul 2, 2022 at 6:35 PM
    #535
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    So I met this guy with a 2014 AC at the GM Nationals a week ago; His truck did not have a 5th wheel, but it did have aftermarket air suspension, and he seemed to think that a Tundra with air suspension could handle a 5th wheel...? I dunno; I personally would not pull a trailer that big with a half-ton truck...
    June 25th, 2022:
    EB1_8415.jpg EB1_8436.jpg EB1_8557.jpg EB1_8558.jpg EB1_8559_Edit.jpg EB1_8561_edit.jpg EB1_8560.jpg
  26. Jul 2, 2022 at 7:22 PM
    #536
    There’s a lot more that goes into towing a 5th wheel other than air suspension. Suspension is a big part, but so is axle ratings, power train, brakes and alternate braking systems, etc.
  27. Jul 2, 2022 at 7:23 PM
    #537
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    But a Tundra could be beefed up to haul a really large trailer without, say, replacing the rear diff or regearing it?
  28. Jul 2, 2022 at 7:25 PM
    #538
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2017 DC SR5
    June 25th, 2022:
  29. Jul 2, 2022 at 7:30 PM
    #539
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    June 26th, 2022:
    Bethlehem, Pennsylvania
  30. Jul 2, 2022 at 7:53 PM
    #540
    The payload ratings are what they are. Some get lucky going over, others do not. We have had some rear axles that were destroyed on here. Let’s be honest, most people don’t come on here and brag that they went way over, broke stuff so everyone can say…”I told you so.”
