Tundra Speaker Wiring Diagram
Discussion in 'Audio & Video' started by csuviper, May 29, 2015.
  1. May 29, 2015 at 8:27 AM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Here is the speaker wiring diagram if anyone needs it.
  2. Dec 6, 2016 at 8:31 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I'm not sure what year/model of Tundra this is supposed to represent, but I can say with absolute certainty that it is NOT the 2016 CrewMax.
    619Tundra and SiberianTundra like this.
  3. Dec 6, 2016 at 11:50 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    That makes sense!
    NewImprovedRon likes this.
  4. Feb 25, 2017 at 6:21 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Don't see it on that diagram, but does anybody know what color the + and - wires are for the JBL sub in a 2013?
  5. Feb 25, 2017 at 6:37 PM
    csuviper
    Broomfield, CO
    Sorry yes it was looked up by my truck year, 2012
    831Tun likes this.
  6. Feb 26, 2017 at 11:04 AM
    Tundra Fan
    Toby
    Hopefully this uploads.......here is the JBL wiring diagram for those who need it. It was posted for a 2009, but the sub wires are color coded correctly for my 2013. I don't know if it is the same for 1st or 3rd Gens though.
  7. Feb 7, 2018 at 8:57 AM
    Happybg81
    Happybg81 New Member
    William
    13’ Balcked Out Rock Warrior DC
    Switched backup camera, interior led’s, backflip g2, smoke led taillights, rhino liner, leveling kit, black powder coated rw wheel rings, weathertech mats, under seat storage, evo one remote start, flowmaster 50 series, S&B CAI, Focal 6x9 front doors, Rockford Fosgate 6.5” rear doors, JL Audio dash tweeters, Kicker hideaway under rear seat
    I am adding a kicker hideaway sub in a 2013 non jbl dc. Based off the diagram, where is the closest place to the rear of the truck to tap in the rear speakers? I really don’t want to run them clear to the head unit.
  8. Feb 7, 2018 at 10:33 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    For the non JBL systems, every audio channel in the vehicle is available at the "Amp" unit under the passenger seat. You can check out my audio install thread (see my sig block for link) to get the pin/signal information you need. From there it's an easy run through the door sill channels to get to the rear of the cab.
    Since non JBL systems don't have a sub channel, you'll need to tie into the audio through some sort of summing device and crossover or a processor/amp that breaks out the low frequency audio for your new sub. Have you figured out how/where you are doing that yet? That will also affect your routing path from the passenger seat OEM Amp.
  9. Feb 7, 2018 at 11:15 AM
    Happybg81
    William
    I don’t seem to have an amp under the passenger seat.
  10. Feb 7, 2018 at 12:00 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Oops just noticed you have a 2013. My comments are related to 3rd Gen, 2014 - 2018. I'm not as familiar with the 2013 models, I'd have to look at the drawings.
  11. Feb 7, 2018 at 12:21 PM
    Happybg81
    William
    Ok, so all the diagrams I have found show black & yellow wires for driver rear and red & white wires for passenger rear. When I pull up plate at front doors and look inside the wiring loom there is a black and yellow twisted together on the driver and a red and white twisted together on the passenger. Is it safe to say these are what I’m looking for?
  12. Sep 3, 2020 at 6:36 PM
    walterwhtTRD
    walterwhtTRD New Member
    2019 Tundra TRD PRO
    I'm currently doing a build on my 19 TRD PRO, and I am wandering if I need to install the JL FIX86 to get a full range signal configured for the Jl VX700/5i with TUN processor internal. Im hearing i do not need the fix, only to use rca adapting harness for input signal to amp and the signals at the oem amp are already full range is this correct?
  13. Jan 11, 2021 at 4:11 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Based on the manual number listed in the original post (EM04E1U) I'm thinking that diagram is for a Gen 1. My 2008 had an EWD manual number of EM08H0U. I also have a few other EWDs stashed away:
    2008 EM08H0U (also covers 2007)
    2009 EM11A0U (only the diagrams, not the rest of the manual, but not much change from 2008)
    2010 EM12D0U (not sure if this will also cover 2011-2013, but very little changed in those years)
    2015 EM26B0U (also covers 2014)
    2021 EM27M0U (also covers 2016-2020)
    I'm more than happy to share applicable diagrams if someone needs something out of any of them. Don't know that I can post up the full documents though.
    SC2019T likes this.
  14. Jan 27, 2021 at 8:01 AM
    OU812
    OU812 New Member
    2003 Tundra SR5
