Tundra-Safety or better gas mileage
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rick4x421, May 21, 2017.
  1. May 25, 2017 at 12:23 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
  2. May 26, 2017 at 7:19 AM
    OPSteel
    OPSteel New Member
    2017 White Tundra TRD Crewmax
    TRD grille, Bushwacker OEM flares, stereo system
    Thank you for that
    kenomouth64 likes this.
  3. May 28, 2017 at 2:20 PM
    hey_mikey
    hey_mikey New Member
    Concord, NC
    15 MGM Limited CrewMax 4x4
    To clarify, according to the IIHS, the Tundra just rated Good on the moderate overlap test, which is a 40% overlap test and representative of a large percentage of real world crashes. This means very low chance of injury in such crashes.
    However, the Tundra is only rated Marginal in the SMALL overlap test, which is a 25% overlap, but those accidents do not account for the majority of frontal crashes:
    "In a 2009 Institute study of vehicles with good ratings for frontal crash protection, small overlap crashes accounted for nearly a quarter of the frontal crashes involving serious or fatal injury to front seat occupants."
    The Tundra is a great truck, but the last redesign occurred before the small overlap test became common and the engineers did not design for such a situation. While it would be nice to see manufacturers be proactive, they usually only make changes when deficiencies are highlighted. For instance, when the moderate overlap test first came out, most manufacturers did poorly in that test, as they only designed for a frontal impact into a wall (which was the standard of the time). Now, most pass with the highest rating.
    With the IIHS now requiring a good performance in the small overlap test for a Top Safety Pick rating, you'll see the same improvements made in next generation vehicles that will make the roads safer for all.
  4. Aug 31, 2017 at 9:22 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Yep, sorry OP but I gotta call BS on that speed estimation. Didn't even break the windows.
  5. Aug 31, 2017 at 10:28 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Comparing mileage or even purchase price doesn't tell you the whole story. If you compare total cost of ownership I think you'll find the Tundra runs away with it.
