Tundra Replacement Bulbs
Discussion in 'Lighting' started by T-Rex266, Jan 27, 2014.
  1. Mar 25, 2019 at 2:23 PM
    #61
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Perfect. Although I know I'll probably need resistors for the back, a small part of me is holding out hope that those will be plug and play like my blinker bulbs.
    Can't wait to hear the results!
    @silverhack
    If those don't work I'll bite the bullet and try these - https://gorecon.com/product/part-264202rd-921-912-906-t15-5q-6-l-e-d-s-360-degree-red-led-bulbs/
    silverhack[QUOTED] likes this.
  2. Mar 26, 2019 at 1:34 PM
    #62
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
  3. Mar 26, 2019 at 1:36 PM
    #63
    CCLJ03
    Craig
    Ok I’ll try the GoRecons and report back.
  4. Apr 15, 2019 at 3:51 PM
    #64
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I need some recommendations. I bought some load resistors from superbrightleds for my headlights. Now that I have them I'm kinda puzzled about where i can mount them. I have them temporarily installed on my truck with JB weld steel stick. They are holding, but I have wires zip tied incase they come loose.
    It's not the same as bolts. I just don't know where it's safe to drill holes to mount. Additionally I don't know if that steel stick i used will conduct heat or not. Hopefully its not an insulator.
  5. Apr 19, 2019 at 2:41 AM
    #65
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  6. Apr 27, 2019 at 3:17 AM
    #66
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Can some do me a favor and post a picture of their foglight beam pattern. My truck did not come with them so I don't know what they should look like. I think the housings I bought are off somehow. No matter what I do they don't seem right to me.
  7. May 16, 2019 at 9:15 PM
    #67
    RAMSPORT
    RAMSPORT New Member
    2013 Tundra SR5 Crewmax
    Putco Blade tailgate light bar, Interior LEDs, Exterior LED's, Billet grill, Color match door handles, Pro Comp Nitro 3" leveling lift kit, 33" x 12.50 R20 tires, BAKFlip MX4 tonneau cover.
    Can someone tell me if I need a resistor for each blinker bulb that’s replaced? I want to replace both front and rear ones with LEDs. Does that call for 4 resistors? Was looking for some that were plug and play that wouldn’t hyper flash, but no luck. Thanks.
  8. May 31, 2019 at 1:11 AM
    #68
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    What size bulb on the 2019 driver side foot/courtesy light .... under dash panel..?
    montez25 likes this.
  9. Dec 8, 2019 at 12:37 PM
    #69
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    So I replaced my interior lights and blew a fuse on the rear dome... replaced fuse but now everything works except rear passenger dome light...? The weird thing is... if I press and hold the button just right it will stay on, but if i let go or move it shuts off. First bulbs I tried were too small and not a good fit. Is it possible I damaged something inside on the bulb connector?
  10. Dec 24, 2019 at 10:00 AM
    #70
    Bigbird57
    Bigbird57 New Member
    LASFIT do not require a resistor.
    But are $$$$.
  11. Apr 9, 2020 at 8:05 AM
    #71
    Walkem
    Walkem New Member
    Canada
    2020 TRD Sport Premium CMax
    Think it's safe to assume that the 2020 bulb sizes are the same as the 2019's?
  12. Jun 9, 2020 at 12:27 PM
    #72
    Corr2626
    Corr2626 New Member
    Corey
    2014 Tundra Limited
    Soooooooo what do yall think for my LED upgrade in my '14....
    Auxbeam LEDHeadlightBulbs at $35- save a bit of $$$ to have a nice set of new bulbs????
    Or
    Morimoto 2 stroke 2.0 at $140- a little better quality in lighting (the majority I read) and better warranty.
    I really fill those are my two best options. Anybody care to school me
  13. Jun 12, 2020 at 4:57 PM
    #73
    HR has the S-V.4 that is supposed to pretty good.
    Corr2626[QUOTED] likes this.
  14. Dec 6, 2020 at 10:40 AM
    #74
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    Are you talking about interior bulbs? I had changed all of my interior (& cargo) bulbs on my 2015 DC and when I sold it. I removed them all and exchanged them with my 2021 Limited CM OEM bulbs. They were plug and play, no issues.
    As for exterior, I went to the site listed above Alla Lighting and checked my vehicle and the bulbs seemed to be the same. Of course, my headlights are already LEDs, but I am looking signals, brakes, and reverse lights to upgrade. Hope this helps!
  15. Feb 20, 2021 at 5:00 PM
    #75
    cjmay13
    cjmay13 New Member
    Corey
    Indiana
    2017 Toyota Tundra TRD Pro Cement Gray
    None Yet.
    2017 TRD Pro, I'm seeing differing front turn signal sizes. Which one is correct, 3157ck or 4157na??
  16. May 6, 2021 at 8:19 AM
    #76
    New2TundraTRD
    New2TundraTRD New Member
    Adrian
    Ontario
    2011 SR5 CrewMax TRD
    Offset rims with lift in the rear w/275-65-18 10s
    WHAT ABOUT THE LIGHT BEHING THE IGNITION RING? aRE THESE ALL PART NUMBERS? tO WHAT BRAND OR MAKE OF BULB?
  17. Aug 20, 2021 at 4:24 PM
    #77
    Cybertek
    Cybertek 67 Tons of Romping, Stomping mean!
    William
    Pensacola, FL
    2006 Tundra Double Cab 2WD SR5
    None
    Thank you, salute!
  18. Dec 23, 2021 at 9:16 AM
    #78
    rhythmz
    rhythmz New Member
    2012 Tundra Limited CrewMax
    Why does he always skip 2012 Model Year?
  19. Jun 1, 2025 at 5:48 AM
    #79
    Seepick1
    Seepick1 New Member
    VA
    2006 SR5 Double Cab 4.7L
    Question: I ordered the Seaight LED version of the DE3175 for my dome light. The new lights are quite a bit shorter than the factory bulb, and will not work. Any thoughts on this?
    Link to the lights I purchased below:
    https://a.co/d/daPMmVk
    Thanks for any info
