Tundra Replacement Bulbs
Discussion in 'Lighting' started by T-Rex266, Jan 27, 2014.
  1. Feb 11, 2018 at 9:20 AM
    SocaliTundra958
    SocaliTundra958 New Member
    Temecula
    2018 SR5 CREWMAX TUNDRA
    stock
    Any recommendations/links for 2018 interior, trunk bed and reverse lights. If you can include link that be appreciated, thanks
  2. Feb 16, 2018 at 1:42 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    The turn signal of the 2018 LED headlight fixture is 7444NA (can use 7443, 7440 standard type). The side marker lamp is the same as 16-17.
  3. Feb 16, 2018 at 1:50 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    I've used VLEDS for all of my interior dome, vanity and footwell, and external cargo, backup, 3rd brake, rear brake, front and rear turn signals and front side marker lamp and license plate replacements to LED. My headlights and fogs were replaced with 2018 OEM LED headlamps and fogs. My puddle lamps were replaced with a different brand, but VLEDS now carries them as well. As far as resisters go, I used one 3 OHM sealed resister on each rear turn signal only when replacing both front and rear turn signal. Brakes did not need a resister. Their guide is very accurate for 2016, but not available for 2018 - call or email for assistance, they are very helpful.
  4. Mar 15, 2018 at 12:37 PM
    MRTUND460
    MRTUND460 New Member
    2010 CrewMax Platinum
    TRD Supercharged, Doug Thorley headers, MBRP cat back exhaust, DAP Tuned, 4.5" BDS lift, Firestone airbags, TRD sway bars, TRD big brakes, Icon CNC upper control arms Fox DSC shocks all 4 corners, Deaver custom rear leaf springs, 2018 Sequoia headlights.
  5. Mar 17, 2018 at 3:29 PM
    obz
    obz Not a New Member
    Utah
    So I just tried using a 7440 LED bulb for my '18 along with my recon tails and no go. No light, no nothing. If you look at the bulb wires they are slightly different. Not sure if that makes a difference or not, but no light at all. I'm going to try to use the 7444NA equivalent (which are different) and see if they light. Not sure if it has anything to do with my Recon tail lights, but either way be aware.
  6. Mar 17, 2018 at 6:58 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    Just to be clear, I had the stock OEM 2016 incandescent bulb rear lights and the 2018 LED headlights which use incandescent bulbs for turn signal and marker lights. I replaced the front 7444NA bulbs with VLEDS' (7443_6_HV_A_N) HIGH VISIBILITY AMBER 6 LED 7443 7440 and the front side marker lamps with
    (194_14_HV_A) HIGH VISIBILITY AMBER LONG LIFE 360° 14 LED 194. In the rear I replaced the incandescent 921 bulbs with VLEDS'
    (921_6_R) HIGH VISIBILITY RED HIGH POWER 6 LED 921 and (VLR_3_DUO) VLR-3 RESISTOR WATERPROOF CONNECTOR W/ DUOTAP HARNESS - (load resisters on each side in the back to eliminate hyper-flash).
    I now have all LEDs inside and out...and working great!
  7. Apr 27, 2018 at 5:06 PM
    Kuroichiyon
    Kuroichiyon New Member
    2007 RCSB Black 2WD
    Awesome information here! Thanks!!
  8. Apr 27, 2018 at 5:11 PM
    Kuroichiyon
    2007 RCSB Black 2WD
    I’ve had good luck with JDM Astar LED bulbs. Everything that Amazon says fits my truck has been plug and play without transisters. No hyperflash.
    UseEveryColor likes this.
  9. May 13, 2018 at 8:46 AM
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    Bump for 18 headlight bulb types :anonymous:.. anyone have additional information?
  10. May 13, 2018 at 9:50 AM
    GreatAvalon
    GreatAvalon New Member
    2016 Tundra Limited DC
    Front parking/clearance light- 168/194
    Front turn signal bulb- 7443 (NON-CK)
    LED headlights- low/high beams
    Halogen headlights- H4
    LED fog lights
    Travo60[QUOTED] likes this.
  11. Jun 4, 2018 at 4:22 PM
    Rolltide4469
    Rolltide4469 New Member
    2012 CM 5.7
    2012?? Am I missing it?
  12. Jun 4, 2018 at 6:39 PM
    GreatAvalon
    Same as 2011 and 2013
  13. Jun 11, 2018 at 1:58 PM
    Benzu
    Benzu New Member
    2015 Toyota Tundra
    Do you know where I can get the whole Head Light assembly , or new LED Headlight assembly?
  14. Sep 11, 2018 at 5:04 AM
    Danny
    Danny New Member
    2018 Tundra Crewmax SR5
    Are the 2018 fog lights h4 also? I’m not quite understanding your message
  15. Sep 11, 2018 at 6:58 AM
    GreatAvalon
    2018 fogs are LED (at least as long as you have LED headlights). If you have halogen H4 headlights, your fog lights are probably halogen which is a H16 fog light bulb size. It’s the same base as an H11 bulb, but the H16 is 19watts versus the 55watts for the H11.
    FoghornTX likes this.
  16. Sep 11, 2018 at 7:43 AM
    Danny
    Danny New Member
    Thank you for the response. I wanted to ask you, will the higher wattage led h4s be pnp and not overheat my headlamp? I read briefly about this possibly happening with fog lights so I just want to be sure. Also, what would you recommend, thanks
  17. Sep 11, 2018 at 8:56 PM
    GreatAvalon
    Hey @Danny - so do you have halogen headlights and fog lights currently on your 2018, or do you have the LED lights? That will determine how I answer :)
  18. Sep 12, 2018 at 3:55 AM
    Danny
    Danny New Member
    I have halogens on my headlamps and fog lights
  19. Sep 12, 2018 at 5:06 AM
    #49
    GreatAvalon
    Honestly, what I would do is buy the 2018 LED headlights at like $285 or so a piece from @Roman from Toyota of Cool Springs online and then get an @iHacker harness.
    I'd go that route because the H4 headlight optics are trash, so if you put LED bulbs in there it would take a very expensive LED bulb to be just OK in the H4 halogen headlights. Instead, one of the 2018 headlights is essentially the same amount as the only H4 LED bulbs I would recommend, but you get significantly better results.
    As far as the fog lights, the 2018 fog lights are I think $120/piece and are plug and play swap from the halogen fog lights. If you didn't want to go that route, I recommend the following bulbs - but again, 2 of the 2018 LED Fog lights are only a bit more than these and install just as easily. https://www.xenondepot.com/h11-h8-h16-philips-Ultinon-LED-Bulb-p/12834unix2-h11.htm
    Mamalona and Roman like this.
  20. Sep 12, 2018 at 5:26 AM
    #50
    Danny
    Danny New Member
    Too much money man I still got my 30 day tags on and this truck has already costed me some serious dough lol
  21. Sep 12, 2018 at 4:18 PM
    #51
    GreatAvalon
    Haha well that’s the best solution. I’d recommend bulbs totalling about $500 and that’s still for some junk performance because of the stock halogen tundra lights sucking. Honestly I wouldn’t do anything and save some pennies until you can swing the full OEM LED conversion.
    ToyotaToolbox likes this.
  22. Sep 27, 2018 at 8:10 PM
    #52
    Alla_Lighting_Auto_LED
    Alla_Lighting_Auto_LED Alla Lighting Automotive LED Bulbs
    14722 Yorba Ct Chino, CA91710
    2017 Toyota Tundra
    2014-2021 Toyota Tundra Bulb size guide as below, or click Toyota Tundra LED lights bulbs to check the related LED bulbs by choosing different truck's trims and applications for 2018 Toyota Tundra
    Exterior Lights:
    Headlight Bulb High Beam and Low Beam: HB2 headlight bulbs
    Daytime Running Light Bulb if equipped with Halogen Lamp: 4157NAK bulb
    Door Mirror Illumination Light Bulb: 168 bulb
    Fog Light Bulb (Front): H16 bulb
    Side Marker Light Bulb (Front): 168 bulb
    Back Up Reverse Light Bulb: 7440 bulb
    Brake/Stop/Tail Light Bulb: 3157 bulb
    Center High Mount Stop Light Bulb: 921 bulb
    Daytime Running Light Bulb: LED
    Dome Light Bulb: 168 bulb
    License Light Bulb: 168 bulb
    Map Light Bulb: 168 bulb
    Side Marker Light Bulb Rear: 3157k bulb
    Tail Light Bulb: 3157k bulb
    Turn Signal Light Bulb Rear: 921 bulb
    Turn Signal Light Bulb Front: 4157NA bulb
    Vanity Mirror Light Bulb: 7065 bulb
    Stepwell Light Bulb: 74 bulb
    Parking Light Bulb: 4157NA bulb
    Luggage Compartment Light Bulb: 921 bulb
  23. Nov 28, 2018 at 4:04 PM
    #53
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Going to do a 2019 listing?
  24. Nov 28, 2018 at 5:48 PM
    #54
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Same as 2018. Most bulbs are the same throughout all 3rd gens
  25. Dec 28, 2018 at 3:07 PM
    #55
    Seek
    Seek New Member
    Lorton, VA
    2017 Super White Tunda SR5 Off-Road
    2017 OEM Halogen headlights - Has anyone used VLEDS in these housing? Results? On their site it states that it's okay to use in all housings.
  26. Feb 16, 2019 at 11:42 AM
    #56
    steve-smith
    steve-smith New Member
    2019 Toyota Tundra
    310 to 381 hp
    The driver side headlight reflector came bent down slightly so the headlight is not quite as bright as the passenger side. I plan on trying to figure out a way to pull the reflector up but have not done so yet. Other than that I like them a lot, huge improvement over the stock headlight assembly that was cracked and fogging up from old age.
  27. Feb 22, 2019 at 9:36 PM
    #57
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    Apologies if I'm being dumb, but I'm trying to research replacing interior lights, and as far as I can tell it would be handy to know how many bulbs to order. The lists here are awesome, but despite probably 45 minutes of searching I still don't know how many, say, to replace the main instrument cluster bulbs. I do realize I could pull the dash apart and count them myself, but I'd rather not take it apart, put it back together while I wait for my order, then take it apart again - not if somebody can just say "order four bulbs".
    So, seems like it would be nice data to add, in general, to these lists. Specifically for my needs, though, we're talking about a 2003 Tundra access cab. I've seen people say they replaced "4x #194" and somebody mentioned 10x. At superbrightleds.com's $4.95 each, would be great not to order any more than necessary.
  28. Mar 24, 2019 at 7:37 PM
    #58
    Dakota Kid
    Dakota Kid New Member
    Dean
    Question. Just ordered some leds for the 8nterior of 18 1794. Says there are 4 door bulbs. Either I’m crazy, or there are no door lights on a 2018 1794? Anyone help me keep my sanity?
  29. Mar 25, 2019 at 2:19 PM
    #59
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Does anybody have a bead on some red 921 LED bulbs? I see white everywhere but I want red.
  30. Mar 25, 2019 at 2:21 PM
    #60
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    CCLJ03[QUOTED] likes this.
