Tundra Remote Start not working
Discussion in '2.5 Gen Tundras (2014-2021)' started by Lgwill, Oct 6, 2021.
  1. Oct 6, 2021 at 7:56 AM
    Lgwill
    Lgwill [OP] New Member
    Greg
    2016 Black Tundra
    None
    I have a 2016 Tundra and my remote start is not working. I have only had the truck a few months and when I bought it start worked now it will not respond.
  2. Oct 6, 2021 at 7:59 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Can you share a bit more info?
    1. Is it OEM or aftermarket?
    2. If it is aftermarket, what brand is it? Often posting a pic of the remote you use to start the truck helps.
    3. Does it try to start and fail?
    4. Does everything else on the remote work?
    And welcome to the community!
  3. Oct 6, 2021 at 8:02 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  4. Oct 6, 2021 at 8:02 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Is there a question?
    :crapstorm:
  5. Oct 6, 2021 at 8:10 AM
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    he just wants to make a statement
  6. Oct 6, 2021 at 8:18 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Thanks for sharing, that's a real bummer dude.
  7. Oct 6, 2021 at 8:21 AM
    Lgwill
    Greg
    2016 Black Tundra
    None
    It is OEM.
    It does not try to start.
    Everything else on remote does work
  8. Oct 6, 2021 at 9:11 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    So do the 2016s require an active Connected Services account to run remote start? It appears the newer models do, not sure its an option on the older models.
  9. Oct 6, 2021 at 9:15 AM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    No connected services to start for that year. By looking at that key fob I have no clue how one could remote start with that?
    For that year, Toyota does sell a remote start accessory and I believe it comes with a separate key fob that is installed by dealers?
    Maybe the OP can tell us the button sequence he uses to start the truck with that fob?
  10. Oct 6, 2021 at 9:18 AM
    mountainpete
    Thanks.
    How do you normally start the engine with the remote? Is it press lock twice and then press/hold on the third until it starts?
    BravoDeltaRomeo likes this.
  11. Oct 6, 2021 at 11:06 AM
    Lgwill
    Greg
    2016 Black Tundra
    None
    That is correct. Two lock and third hold. Worked when I first got it but not now?
  12. Oct 6, 2021 at 11:09 AM
    50Shades
    J
    West Coast
    just doing process of elimination here... are all the doors closed and the hood closed before trying to engage the remote start?
    have you installed anything lately that required tapping into fuses? check fuses etc
  13. Oct 6, 2021 at 11:26 AM
    Lgwill
    Greg
    2016 Black Tundra
    None
    Yes they are.
  14. Oct 6, 2021 at 11:42 AM
    mountainpete
    This is the installation manual for what I think you have: http://toyotaparts.sparkstoyota.com/install/PT398-34150inst.pdf
    I would suggest:
    1. Try a different remote if you have one.
    2. Check all of your connections to the hood switch. If the computer senses the hood is open it won't start the truck.
    3. Identify if your truck has an immobilizer or not (it's in the install guide)
    4. Re-pair your remotes - starts at page 24 but make sure you pick the right one (immobilizer equipped or not)
  15. Oct 6, 2021 at 11:52 AM
    Saltyhero13
    Or LEDs. Some can create interference.
    50Shades[QUOTED] likes this.
  16. Oct 6, 2021 at 11:55 AM
    50Shades
    J
    West Coast
    oh totally forgot about that! some LEDs will create interference. Found that out the hard way when i replaced my garage door opener light with LED...basically locked myself out of the house...
  17. Oct 6, 2021 at 1:18 PM
    mountainpete
    Usually bad LEDs prevent the entire remote from working and not just the starter.
  18. Oct 6, 2021 at 1:22 PM
    Saltyhero13
    Typically yes. Its possible to only block a subset of the commands as well.
    50Shades likes this.
  19. Oct 6, 2021 at 1:26 PM
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    Simple stuff first, maybe replace the remote battery?
  20. Oct 6, 2021 at 1:27 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2019 SC TRD Pro CM 040 2020 Sequoia TRD Pro 040
    Also maybe hook it up to a laptop and check the remote start system status in Techstream.
  21. Oct 6, 2021 at 1:36 PM
    mountainpete
    I'm confused... The remote runs on one frequency set so I assumed all commands would be blocked. Commands don't run on different RF.
  22. Oct 6, 2021 at 1:42 PM
    Do58
    Do58 New Member
    Honestly, the OP needs to pull the under dash to see what it is. It very well might not be factory even though he is using the factory remote. DEI, compustar and many other companies have rs that you can use the factory fob. There is an immobilizer in the vehicle and his key is coded ( either a G or H key ) so you can actually program the immobilizer interface needed ( for aftermarket rs and/or security ) as a stand alone rs. Pulling the under dash will explain what needs to be done in the sense of troubleshooting. Otherwise, it’s just a guessing game.
  23. Oct 6, 2021 at 1:44 PM
    mountainpete
    Agreed. Also why I shared the install guide above :)
  24. Oct 6, 2021 at 1:45 PM
    boostedtrdpro
    Jeremy
    This ^^ I had one in my 2017 that was the Fortin Evo One and it used the factory remote. Find the box under the dash, usually connected to the steering column key switch and report back.
  25. Oct 6, 2021 at 1:48 PM
    Saltyhero13
    Depends on how the commands are embedded on the signal with this remote system.
    mountainpete[QUOTED] likes this.
  26. Oct 6, 2021 at 2:06 PM
    Lgwill
    Greg
    2016 Black Tundra
    None
    Thanks and I will try your suggestions.
  27. Oct 6, 2021 at 2:13 PM
    mountainpete
    Awesome. @Do58 reinforces an important point above and I want to make sure you see it. You really need to know exactly what system you have installed. It's likely the one I provided the link to above if it's OEM, but confirming is key.
    Saltyhero13 and Do58 like this.
  28. Oct 6, 2021 at 2:15 PM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Yep the Fortin Evo One in my 2017 from Tech12Volts used factory fob and required lock press 3x, no long hold dance. The only reason that one wouldn't start and wouldn't beep would be hood safety switch not closed.
  29. Oct 6, 2021 at 2:27 PM
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    No that is the correct key for factory remote start. I hit my lock button 3 times quickly holding it on the third until it beeps on more time. All doors must be shut properly for it to work akso.
  30. Oct 6, 2021 at 2:29 PM
    Saltyhero13
    Not being evasive with you @mountainpete I can't say with certainty this is how the Tundra key remote embeds its command info on the RF signal. Some remotes use a header/preamble (wake up/listen command) followed by a command (ie lock, unlock, alarm). There is usually some type of security scheme embedded in the signal to prevent spoofing/recording; these can vary greatly from one manufacturer to another.
    Basic, less secure remotes would frequency modulate the base RF with a different signal per command. These typically can be spoofed/recorded.
    This video is an example where you can see the remote's transmission on a spectrum analyzer and the frequency is shifting. The other command is using a higher portion of the band (presumably after its mixed with the base RF signal). Relevant part is at 4:44.
    https://youtu.be/RiAJbCnGzZs?t=284
    In this example it would be possible that interference blocks one command but not the other. There is enough separation between the two command to do so.
    Here is a deeper dive in one approach to security for key remotes:
    https://youtu.be/5CsD8I396wo
    mountainpete and 50Shades like this.
