Tundra Rear lift issue
Discussion in 'Suspension' started by Shelbie67, Aug 25, 2018.
  1. Aug 25, 2018 at 5:25 PM
    Shelbie67
    Shelbie67 [OP] New Member
    Blake
    NorCal
    2018 tundra crewmax platinum
    RADFLO 2.5 suspension, apex rock sliders, BFG KO2, exhaust delete, Full Active Stereo
    ill try and make a long story short.....I drive a 2018 crewmax platinum with 12k miles
    I first installed the Toytec shackle @ the 1” hole and I felt the rear then rode like s***. Also looked like my rear leafs were on the flat side. Hub measurement was 24.5” or 39.75” ground to fender (running 33”).....toytec couldn’t help me so I decided to try the Icon leafs.
    I went with the 51200 leaf pack. Installed yesterday and I lost height...I now measure 24.25”
    The leafs are supposed to add 1.5” the ride is a little better.
    Am I missing something why I barely got any lift with these options?
    Are my brand new leafs already flat???
    Thank you for your input!
  2. Aug 25, 2018 at 5:41 PM
    Vizsla
    Vizsla 2 = 2.5
    Did you re-use the stock overload leaf? It’s needed for 1.5” lift.
  3. Aug 25, 2018 at 5:53 PM
    Shelbie67
    Blake
    NorCal
    I have the main Toyota spring, the Icon leaf pack and ONLY the thick spring, did I need the other one attached to it as well?
  4. Aug 25, 2018 at 5:59 PM
    Vizsla
    Vizsla 2 = 2.5
    Picture?
  5. Aug 25, 2018 at 6:19 PM
    Shelbie67
    Blake
    NorCal
    I’ll get a picture soon, do you have this setup? I’m thinking I’m short a leaf now, but pretty sure I followed icons directions
  6. Aug 25, 2018 at 6:35 PM
    Shelbie67
    Blake
    NorCal
  7. Aug 25, 2018 at 6:44 PM
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
    If you’re only looking for 1.5” I’d ditch the shackles and use a block. Wouldn’t affect ride quality.
  8. Aug 25, 2018 at 7:24 PM
    Vizsla
    Vizsla 2 = 2.5
    No I do not have them, but installed them. Yours look correct. I’m no further help, but this is my 18 rear measurements with a 1” lift block(provided exactly 1” lift) on 33” tires. Mine is a pig, full armor, sliders, gear etc..
    Driver - 40 7/8” ground to fender, 25 1/8” hub center to fender
    Passenger - 41 1/8” ground to fender, 25 3/8” hub center to fender.
  9. Aug 25, 2018 at 7:59 PM
    Shelbie67
    Blake
    NorCal
    Are the shackles suppose to be angled back like that?
  10. Aug 26, 2018 at 4:38 PM
    Shelbie67
    Blake
    NorCal
    So I just took a good look at my leafs and they appear to be in a “w” shape....
    How are they flat already!
  11. Aug 28, 2018 at 10:13 AM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    After seeing your pics, I wonder what would happen if you removed those shackles and put the stock ones back on. It would alleviate some of that press down on your leaf pack.
  12. Aug 28, 2018 at 12:54 PM
    Shelbie67
    Blake
    NorCal
    Those are the stock shackles
