Tundra Rear axle
Discussion in '1st Gen Tundras (2000-2006)' started by carsonchunk, Mar 27, 2021.
  1. Mar 27, 2021 at 1:15 PM
    carsonchunk
    carsonchunk [OP] New Member
    I have a 2005 Toyota Tundra Double cab 2wd. I took the rear driver side axle out to get the wheel bearing pressed out and new one in. The machine shop told me that the wheel bearing spun onto the shaft. Now I will need to buy a new rear axle shaft. I'm not able to find it anywhere for a 2005 Toyota Tundra Double cab 2wd except from a the toyota dealer. Part number I believe is 42311-34060.
    https://parts.livermoretoyota.com/p...ft-Left--Right--Rear/63307005/4231134060.html
    Thanks any help will be appreciated.
  2. Mar 27, 2021 at 4:40 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Ouch. Might want to check your local junkyard for that axle shaft.
  3. Mar 28, 2021 at 7:35 AM
    Professional Hand Model
    Hand Protectors
    NAPA sells a Rear Axle Kit that I have on my rear driver side after a shop debacle.
    Parts look quality, but only one recco is to buy and use the Toyota Seals which are superior to the NAPA ones that are provided in kit. Do not use the NAPA Seals. Buy Toy Seals.
    NAPA Kit costs about $300 (axle, rings, seals- do not use)
    Toy seals are about under $20.
  4. Mar 28, 2021 at 9:44 AM
    carsonchunk
  5. Mar 29, 2021 at 4:50 PM
    carsonchunk
    Found an axle shaft at the local pick n pull. I'm putting it back on now but notice my seal has a tear? Do you think it will be ok to put on or put the old one back in?
  6. Mar 29, 2021 at 4:53 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Why not just buy a new seal... they're not very expensive.
  7. Mar 29, 2021 at 5:09 PM
    Hand Protectors
    Buy a new Seal for about $10 OEM only. Do not put that torn one on or else you will ragret it.
    Lil Steve, Glock 40 and des2mtn like this.
  8. Mar 29, 2021 at 5:22 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Brand new seal from dealer.
  9. Mar 30, 2021 at 11:26 AM
    The old saying goes, if you had to ask, you probably know the answer. Its torn, replace it.
