Tundra Mud Flaps ..
Discussion in '3rd Gen Tundras (2022+)' started by roboots21, Mar 9, 2022.
  1. Feb 3, 2023 at 9:24 AM
    #121
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Do you have pictures of installed on your truck?
    Can they be adjusted to stick out a little more than OEM for better coverage? I have a slight poke, would be nice to have the flaps stick out maybe an 1” or 1 1/2”
  2. Feb 3, 2023 at 3:42 PM
    #122
    TUNDRA-TY
    TUNDRA-TY Winter SUCKS!
    Tyler
    Tricities, WA
    23 SR5 4WD CMSB CSM
    There isn't that much adjustment. Maybe only ½ an inch... I dont have any up close pictures...this is my previous Tacoma with them on. They can be adjusted out more then stock though.
  3. Feb 7, 2023 at 2:52 PM
    #123
    nobaddays
    nobaddays New Member
    Tyler
    2023 Black Tundra TRD Pro
    Full front PPF, Tint, Go Rhino boards, Retrax, 35's, Rekgen Flaps
    Rekgen mud flaps. Only two gripes... #1: They use a different size screw than factory, #2: you have to reuse one rear screw, but the screw is silver, not black. Both minor, but both annoying.
    Overall, great fitment, better coverage than stock, no tire rubbing and installation instructions that are easy to follow.
    nodak67 and coldcanuk like this.
  4. Feb 7, 2023 at 2:58 PM
    #124
    Blistering fish
    Blistering fish New Member
    Blister
    2023 tundra 1794 iForce max TRD OR army green
    If anyone wants the tuff skinz ones I posted a bit back in this thread pm me. My new truck came with them
  5. Feb 17, 2023 at 2:48 PM
    #125
    graf_von_tundra
    graf_von_tundra Not so new
    Central Texas
    2023 Tundra 1794 4x4 Black
    I purchased two Amazon options that have been discussed here:
    I ultimately returned option A because of how twisted the rear flaps appeared. The front flaps looked good for both options. I've got some measurements if you need them.
    Hopefully this helps folks.
    Option A:
    Option B:
    arrampico and mlive like this.
  6. Feb 17, 2023 at 4:04 PM
    #126
    Tom976
    Tom976 New Member
    Tom
    I wonder how flexible these flaps are. Looks like if you drive over a curb that these things can get damaged.
  7. Feb 17, 2023 at 4:13 PM
    #127
    mlive
    mlive New Member
    South Central, PA
    2023 Tundra DC 6.5
    I just bought Option B also and will be installing this weekend hopefully.
  8. Feb 17, 2023 at 5:10 PM
    #128
    Fxclm5
    Fxclm5 New Member
    Tbh I hated my option A mudflaps and even tried to bend the metal brackets back. Not very good luck doing that.
    But shown a few ppl my truck now and nobody points it out, and when I do they just shrug and think it's how it's supposed to be since the flap follows that inward bend of the wheel liner.
    I'm like it's not parallel 90degrees, and they are like huh so what/where, then I show them a specific angle to look at it and they all go wtf who cares.....
    Tldr, some post on interwebs made me think the flaps were pointing inward were awkward. But irl ppl think that's the way it's supposed to be.
    Boerseun and graf_von_tundra like this.
  9. Feb 17, 2023 at 6:59 PM
    #129
    graf_von_tundra
    Central Texas
    Both do flex but option B seems more rubbery. I’m driving through pastures quite a bit, so I’ll report back if I damage them.
  10. Feb 20, 2023 at 3:22 PM
    #130
    graf_von_tundra
    Central Texas
    Mattedfred[QUOTED] likes this.
  11. Feb 26, 2023 at 10:22 AM
    #131
    Thehype31
    Thehype31 New Member
    Upstate NY
    2023 super sonic red platinum hybrid
  12. Feb 26, 2023 at 5:47 PM
    #132
    mattvarnell
    mattvarnell New Member
  13. Feb 27, 2023 at 6:01 AM
    #133
    nodak67
    nodak67 New Member
    JR
    the oem mud flaps are ok, seems like they made them slightly shorter than the 2nd gen flaps.
    may look into something that is slightly taller to do better coverage on the auto boards. still getting some snow build up on the boards just before the leading motor.
  14. Feb 27, 2023 at 8:44 PM
    #134
    Chugbug
    Chugbug New Member
    2023 Platinum, Midnight Black
    Has anyone tried these out yet?
    https://www.weathertech.com/toyota/2023/tundra-hybrid/mudflap-no-drill-digitalfit/
    Sorry not sure what happened with my previous post but Yes I had them on my 22 Limited and really did like the look. They come with everything you need and Its an easy install, maybe 1/2 hour all together. They mount using the existing screw pattern (longer screws included), and include 4 strips of PPF to protect where the mud flap contacts body paint. If you're off roading you might want to look at something a little more flexible, Weather Tech's are fairly stiff but otherwise :thumbsup:
    Jojoma2016 and Thehype31 like this.
  15. Feb 28, 2023 at 1:14 AM
    #135
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    Not sure why these mud flap builders and oem can’t grasp that we want soft pliable mud flaps like tractor trailers. Nothing worse than rock hard ones that will crack break and tear off everything they are attached to in the woods. Guess it’s form over function like everything else on these trucks.
    mayan and Chugbug[QUOTED] like this.
  16. Feb 28, 2023 at 4:08 AM
    #136
    Thehype31
    Upstate NY
    Thank you for the feedback- I think I’m going to pull the trigger and give them a shot. I’ve always been a weather tech fan for almost 20 years now- try to support made in USA as much as I can.
    Appreciate it!
  17. Feb 28, 2023 at 6:19 AM
    #137
    nodak67
    nodak67 New Member
    JR
    Mattedfred likes this.
  18. Mar 5, 2023 at 12:59 PM
    #138
    mattvarnell
    Weathertech mudflaps. Looks nice, easy install, includes PPF and longer screws. Not super flexible, but not rock solid either. Don't know if the work yet, but I think they will.
    PXL_20230305_205211482.jpg PXL_20230305_205216599.jpg PXL_20230305_205226727.jpg PXL_20230305_205231388.jpg
    Thehype31, Chugbug, mlive and 3 others like this.
  19. Mar 11, 2023 at 4:56 PM
    #139
    lesh234
    lesh234 New Member
    Will be added soon
  20. Mar 11, 2023 at 7:16 PM
    #140
    Tom976
    Tom976 New Member
    Tom
    I put on the weathertech ones on my 1794. Look pretty good. Hardest thing was putting on that paint protector film in cold weather.
    In hindsight, I dont think I really needed to put that paint film on.
  21. Mar 12, 2023 at 10:10 AM
    #141
    lesh234
    lesh234 New Member
    On my list
  22. Mar 12, 2023 at 2:53 PM
    #142
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    Nice view of some mud flaps being posted, here's mine with measurements:
    These are the RefitEco Mud Flaps for 2022 2023 Toyota Tundra Accessories All Weather Guard Mud Guards Splash Front & Rear 4pcs Set
  23. Mar 19, 2023 at 11:15 AM
    #143
    D_Tran11
    D_Tran11 New Member
    2022 Tundra TRD Pro - White
    If anyone needs a set of OEM mud flaps, let me know. Can sell either fronts only, rears only, or the whole set. Cheap! From North Carolina.
    EDIT - SOLD
  24. Mar 19, 2023 at 6:24 PM
    #144
    DimSum07
    DimSum07 New Member
    Steven
    Annandale VA
    2024 Silverado 1500 LZ0
    Sent you a PM
  25. May 9, 2023 at 7:09 AM
    #145
    AND
    AND New Member
    Washington, PNW
    Do you have a link for these?
    Also, did you just use the same OEM holes to attach them?
    Thanks
    nodak67 likes this.
  26. May 10, 2023 at 11:57 AM
    #146
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    No link, just the universal mud flaps. i used the existing holes- held the flares up in place and marked them then drilled em out!
    AND likes this.
  27. May 10, 2023 at 7:13 PM
    #147
    Yota802
    Yota802 New Member
    I have a set ( front and rear ) Toyota OEM mud flaps for sale. Nearly new 3 months old, perfect condition. If interested, let me know.
  28. May 20, 2023 at 12:06 PM
    #148
    Tommyboyl
    Tommyboyl New Member
    2017 black limited crew max
    Pro suspension skidplate and shifter oem audio plus weathertech tint pro grille headlights mirrors and door handles
    Im interested
  29. Jul 1, 2023 at 4:16 PM
    #149
    Mrconnsmythe
    Mrconnsmythe New Member
    Saskatchewan, Canada
    2025 Tundra Ltd TRD OR WCP
    Just added the RekGen Mud Flaps. Better coverage now on my +15 offset rims. Installation super easy. Why they didn't stick with bolt screws rather than phillips i'IMG_2276.jpg IMG_2274.jpg IMG_2269.jpg IMG_2273.jpg m not sure but it is what it is.
    arrampico, pwpblue and NHKTundra like this.
  30. Jul 1, 2023 at 4:29 PM
    #150
    Tom976
    Tom976 New Member
    Tom
    Use a 1/4" ratchet with philips bit and correct size socket.
    They also make small ratches just for bits that can get into even tighter spaces.
