Tundra Lowered Honey-D WideBody
Discussion in '2.5 Gen Builds (2014-2021)' started by DPT007, Sep 28, 2017.
  1. Dec 29, 2017 at 8:45 PM
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    @DPT007 How is the paint on your painted middle section of front bumper holding up?
    How long have you had that section painted?
  2. Dec 29, 2017 at 8:59 PM
    DPT007
    DPT007 [OP] New Member
    Ben
    2016 Tundra Plantinum
    Tint
    ok, so I found this steel plate with predrilled holes spaced apart every .75inches. after having the tires and rims on the vehicle we noticed in order for the wheels to clear the bumper and not rub, all we had to do was forward displace the bumper shell 1.5inches. this steel sheet did exactly that. 16 piece strips in total for all the mounting points on the bumper shell. On the factory holes i used the same hardware that was on the car, and on the bumper shell holes i found M8 x 1.25 bolts and nuts to thread in place. No additional movement of the bumper was necessary. there is one mounting point on the lower part of the bumper shell that needed to be cut off and the holes moved forward to also avoid hitting the tires.
    TRD_femi[QUOTED] likes this.
  3. Dec 29, 2017 at 9:02 PM
    DPT007
    Ben
    Tint
    Are you referring to the bumper shell itself? I never painted that, The Tundra is a Plantinum edition all the bumpers front and back came painted from factory.
  4. Dec 29, 2017 at 9:02 PM
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    @DPT007 Thanks for the update!!! Hiro had previously said 1" forward movement was needed for adequate clearance.
  5. Dec 29, 2017 at 9:04 PM
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    Yes, middle section of the bumper shell.
    I did not know that about Platinum's, I just assumed they all came with the "black" non painted middle section.
  6. Dec 29, 2017 at 9:09 PM
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    @DPT007 How was/is the overall fit of the kit?
    During the test fit, did everything line up like you hoped it would?
  7. Dec 29, 2017 at 9:28 PM
    DPT007
    Ben
    Tint
    Really good actually. Although The entire kit is fiberglass, rough edges and the holes are not pre-drilled (which sucked)The edges i had sanded down by hand, but the surface for the the most part was made realitively smooth.
  8. Jan 22, 2018 at 3:44 PM
    DPT007
    Ben
    Tint
    Sorry the wheel well cutting has taken so much of our time. C1957472-55C9-4C97-A92E-5EAE09B144B6.jpg
    Mountun Goat, Black Wolf and blue16 like this.
  9. Jan 22, 2018 at 3:44 PM
    DPT007
    Ben
    Tint
    We had to hammer in the body, cut away frame supports and next step is weld everything shut
    4x4_Angel and Black Wolf like this.
  10. Jan 22, 2018 at 3:46 PM
    DPT007
    Ben
    Tint
    It’s now driveable with the new tires and rims!! Still have a slight issue locking out the steering and the tires barely rubs the inside well. We are placing new steering stops which decrease the turning angle a smidge
    4x4_Angel, Black Wolf and blue16 like this.
  11. Jan 22, 2018 at 4:43 PM
    DPT007
    Ben
    Tint
    Trial testing drive ability of new tires and rims.. really just an excuse
  12. Jan 22, 2018 at 5:01 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Turning out amazing!
  13. Jan 25, 2018 at 10:51 PM
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    What is a steering stop?
  14. Jan 26, 2018 at 12:22 AM
    I'm liking it so far!!
  15. Jan 26, 2018 at 6:35 PM
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    Looks like it's gonna turn out awesome!
  16. Jan 26, 2018 at 8:01 PM
    drumzdj
    drumzdj New Member
    Oro Valley
    2011 Crewmax 4x4
    Impressive build
  17. Mar 20, 2018 at 9:44 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Inspiration for OP......
    fFZ5zz1_zvCKqkQIqoIKDS0v62mtQwAeVi5j4dks_b55996cdc0ad350ab5689ee62e9cfcf7d4432e9d.jpg
  18. Mar 20, 2018 at 10:46 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    seems pretty self-explanatory to me...
    Ps3udonymous and zackbremer like this.
  19. Mar 20, 2018 at 1:40 PM
    #49
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    that's gonna be a pain in the nutsack when he burns out a headlight bulb
  20. Mar 20, 2018 at 1:42 PM
    #50
    tomsinamerica
    Tom
    Wilmington, NC
    an adjustable bolt that stops the spindles from being turned too far. essentially it limits the amount you can turn the wheels preventing damage to either the wheels/bodywork or steering rack.
  21. May 2, 2018 at 5:35 PM
    #51
    DPT007
    Ben
    Tint
    Ok so work is finally coming to a close. We finished working on the two front wheel wells. Add the pump stops to each front wheel and We cut out a seem 7B34080E-1428-4FE4-B54F-FF747248ABDE.jpg 049BBE08-2F53-4BA2-8C64-DF39AF538288.jpg E3FF9B75-2731-458B-B3C3-64CCE83DFCF2.jpg 4C534B32-7D20-4CE2-B5E3-A7EAAE030A10.jpg that was rubbing into the tires on a tight turn. Also finished welding up a portion of the sub frame that was cut.
    Mountun Goat likes this.
  22. May 2, 2018 at 5:37 PM
    #52
    DPT007
    Ben
    Tint
    So if u look at the previous post we welded a threaded steel rod to the turn angle that the turn arm comes into contact with. This lowers essential the turn angle of the truck, small compromise for me to get the desired look with the larger tires and rims for this build. I couldn’t be happier.
    Quebec likes this.
  23. May 2, 2018 at 5:38 PM
    #53
    DPT007
    Ben
    Tint
    Next up! Body kit got dropped off today for paint!!! Super excited, build should be done by end of May. Just in time for my bday memorial weekend!! 928BF2B9-7840-4D51-993E-0F6E42B10DEE.jpg
    blue16, 1UPPER, smslavin and 3 others like this.
  24. May 3, 2018 at 3:08 PM
    #54
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    :woot: progress
  25. May 3, 2018 at 4:11 PM
    #55
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    :popcorn::popcorn:
  26. May 7, 2018 at 8:07 AM
    #56
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    @DPT007 How did you hold those body kit parts in place while you drilled the fender holes?
  27. May 7, 2018 at 8:45 AM
    #57
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    2017 Tundra Limited 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights Bilstein 5100
  28. May 7, 2018 at 8:49 AM
    #58
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
  29. May 7, 2018 at 8:55 AM
    #59
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I’ll follow this. Looks cool so far
    DPT007[OP] likes this.
  30. May 7, 2018 at 9:03 AM
    #60
    DPT007
    Ben
    Tint
    Hi,
    Ok so I’ve been told to wait until after paint to mark and drill holes in the body because placement may change a little during the painting process. But we plain on using blue painters tape to place the parts and use extra hands to help make sure things don’t shift while marking holes. Once they are marked we will remove the pieces and drill the holes accordingly.
    See pic for example
    blue16, Quebec, 1UPPER and 2 others like this.
