Tundra is bad on the highway
Discussion in '2.5 Gen Tundras (2014-2021)' started by jsurf58, Aug 20, 2019.
  1. Aug 20, 2019 at 3:46 AM
    jsurf58
    jsurf58 [OP] New Member
    Jordan
    2019 tundra trd limited
    Stock
    I put in a rear seat bar in my 19 Trd limited crew max. Truck wanders on the highway and is bouncy like a boat when it his bumps in. 100% stock and I figured this Ute ofatruck would cruise fine seeing the long wheel base and weight. I really hate how unstable/ not planted/ unpredictable it is at 70-80mph. It feels like the shocks are worn out. This is the exact feel of worn shocks but the truck is brand new with only 2k on it. I had a lifted fj cruiser and I think that truck handled better. Very disappointed . Anything I can do before major modification.
    Rica25 likes this.
  2. Aug 20, 2019 at 3:58 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Truck are designed to carry a load in the bed... secure two to three hundred pounds of dead weight in the bed over the rear axle, the ride will smooth out. My '07 was a little unstable around 125, I secured some weight over the axle and she stays planted now.
  3. Aug 20, 2019 at 4:11 AM
    LML 3500HD
    The rear sway bar is causing your issues.
    Unless you are towing most of the time (like Rex said, having weight in the bed or on the hitch), the sway bar stiffens up the rear and makes you feel the road in the suspension.
    I would remove the sway bar, sell, enjoy your new Tundra.
    Black Wolf, Skeezo, BTBAKER and 4 others like this.
  4. Aug 20, 2019 at 4:12 AM
    PJR202
    PJR202 New Member
    I've found the ride to be surprisingly smooth and stable. Granted, I'm coming from 12 year old Tacoma and performance package mustang but I've had comments about the nice ride.
    Boerseun likes this.
  5. Aug 20, 2019 at 4:37 AM
    jsurf58
    Jordan
    Stock
    I’ll try adding weight to the bed. I added the rear sway bar after I bought it to try to stabilize the vehicle better. Do get me wrong the truck is good. I really just don’t like the highway unstable feel. Can drive it with one finger like some other trucks.
    Rex Kramer likes this.
  6. Aug 20, 2019 at 4:47 AM
    Rex Kramer
    Georgia
    I would sell my truck if I couldn't use a rear sway bar on it... I can't stand driving a road vehicle that doesn't feel solid & planted. Trucks without a rear sway bar feel sloppy, and out of sync to me. Articulation is not much of a requirement on the roadway, stability & control at higher speeds are what you want on-road.
  7. Aug 20, 2019 at 4:48 AM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Have the alignment checked. Also check your tire pressures. If the pressures are too high, the tires will be bouncy and cause the truck to wander.
  8. Aug 20, 2019 at 4:53 AM
    Taofouajarodeve
    Taofouajarodeve New Member
    Tao
    2021 Voo Doo Blue Crewmax
    None
    I have a 2019 DC 4x4 with sway bar and it seems to ride fine for me on highways. I do have 295/70/17 wheels with BFG AT. Maybe more rubber is benefiting me.
    Tundyfundy likes this.
  9. Aug 20, 2019 at 5:02 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    I've had two Tundras, and they both felt really stable to me on the highway. What car/truck were you driving before? Does it have a level kit? Lift?
  10. Aug 20, 2019 at 5:30 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I drive 45 miles on rte 93 one way to work in NH, cruise at 75. My ride is smooth sailing
    Babysfirsttundra likes this.
  11. Aug 20, 2019 at 5:35 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    I thought the rear sway bar was designed to keep the truck planted, which in turn makes it feel more stable, especially in turns...
  12. Aug 20, 2019 at 5:38 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Love the way my 17 drives on the highway. Drive 54 highway miles roundtrip every day work and been on dozens of long highway trips and the truck handles great
    nlaroy and Boerseun like this.
  13. Aug 20, 2019 at 5:40 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Yes.
  14. Aug 20, 2019 at 5:41 AM
    Boerseun
    Ferdie
    Sarasota Florida
    Sway bar does not stiffen it up. It is free moving. It only stabilizes around curves when the vehicle leans to one side. On a straight road it does not do anything to stiffen the ride.
  15. Aug 20, 2019 at 5:43 AM
    Boerseun
    Ferdie
    Sarasota Florida
    What is your tire pressure? Too high pressure might cause it to be more bouncy. My truck drives like a proverbial Caddilac on the road - stable and I can drive it with one finger on the steering wheel at 80 mph.
  16. Aug 20, 2019 at 5:48 AM
    Boerseun
    Ferdie
    Sarasota Florida
    Just reading your first post. Slow bounce like a boat would not be too high tire pressure. High pressure would be short choppy bounce. But check pressure anyway. I am surprised that you do not like the ride - the stable ride was the thing that impressed me the most of the truck when I got it. I often get distracted day dreaming and not paying attention to my speed, and when I look down I realize I am doing 80 or 90, and it feels like 60.
    Skeezo likes this.
  17. Aug 20, 2019 at 5:56 AM
    LML 3500HD
    On a straight, smooth road, totally agree. The suspension is not cycling.
    In the bold is his problem when hitting bumps, which is cycling the suspension.
    I haven’t had a rear anti-sway bar on a truck since my 2002 Dodge 2500. The frames were so flexible that they needed the rear sway bar from the factory. Since then, not one of my trucks needed nor required an anti-sway bar.
    Black Wolf and Newm like this.
  18. Aug 20, 2019 at 5:59 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    My rear sway stabilized mine better. I haul stuff for customers sometimes, so it helps in turns and highway ramps. I had a slight bounce issue on certain roads with my 2018 platinum so I bought some coachbuilder shackles which helped. Like stated above, tire pressure can cause that as well.
    sf319 likes this.
  19. Aug 20, 2019 at 6:05 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    My 18’ Sport feels incredibly planted on the highway, even with it being lifted and bigger tires. You have other issues.
    Skeezo and Boerseun like this.
  20. Aug 20, 2019 at 6:15 AM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    My alignment was off from the factory, good advise to get the FREE alignment check from Toyota, up to 12 months, 12k
  21. Aug 20, 2019 at 6:23 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    I politely disagree with this statement. Having purchased a TRD sway bar and driving for awhile with it and then removing it the truck most definitely rides choppier with the bar in straight line highway driving. Think about it, you are linking both sides of the suspension together essentially through a bar so when you hit a bump on one side it is now felt more on the other side as well. It stiffens up the whole rear end. You just aren't noticing it. I suggest testing this theory yourself. Try taking it off for two months and then putting it back on. I did it twice to confirm my findings and ensure it wasn't something else causing the stiffer ride.
    I am not the first person to comment on this either. I have read numerous posts of many sway bar threads of people removing them because of a harsh ride. One guy commenting not long ago that was the first thing he did when he bought his new Sport was remove the bar. It was most noticeable to me because my kids car seat shook like crazy when I had the bar on fairly smooth Florida highways. As soon as I took it off it quit each time.
    Iowa12tundra, Newm and ColoradoTJ like this.
  22. Aug 20, 2019 at 6:25 AM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    Do you have the Sport or Offroad package? I assume not since you added an anti-sway bar.
    I have been very happy with the ride quality of my '19 Limited double cab, neither Sport nor Offroad. I also like the ride quality of my daughter's FJ. Neither are as soft as a car or unibody SUV, but that's expected. As others have said, maybe the alignment is out. Or, maybe you have a bad tire. Your dealer should have a road force balancing machine to check the tires properly.
  23. Aug 20, 2019 at 6:33 AM
    JeremyGSU
    Jeremy
    2016 Tundra
    If you're referring to me I have a regular '16 SR5 Crewmax 4x4 non-TRD. It does have TRD 18" wheels that are Road force balanced. Once the tires are warm the truck rides extremely smooth.
  24. Aug 20, 2019 at 6:35 AM
    Boerseun
    Ferdie
    Sarasota Florida
    I agree with isolated bumps or potholes. But OP is talking about "bouncing like a boat" on a highway. Sway bar would not have any affect on that condition. If anything, it would keep it from bouncing like a boat. My truck has a sway bar and I love the ride.
  25. Aug 20, 2019 at 6:39 AM
    JeremyGSU
    Jeremy
    2016 Tundra
    I would agree with that then. Unless the roads are just pitiful it shouldn't be riding that badly.
    Boerseun[QUOTED] likes this.
  26. Aug 20, 2019 at 6:43 AM
    Rica25
    Ricardo
    Tulare
    So I drive a 2008 that has coachbuilder shackles and 5100s all around but soon will have 6112s and 5160 on rear I also have front and rear TRD sway bars........yesterday I took my uncles new 2019 to work so we can install his 6112s and 5160 with shackles and while driving it 2019 TRD 4x4 bone stock I noticed the same thing you are talking about real bouncy and mushy I did no like the drive so today I'm finishing his truck with the shackles ......I've not had my truck stock since 2009 so now I know there is a big difference in doing shocks shackels and say bars
  27. Aug 20, 2019 at 7:41 AM
    Stewartac
    Stewartac New Member
    Castle Rock Colorado
    2013 White Tundra
    Bilstein 5160s or throw the sway away
  28. Aug 20, 2019 at 8:04 AM
    LML 3500HD
    Where the OP is located (I will not state unless he does), I’m just going to assume the roads are rather rough and hard to maintain due to traffic and seasonal weather.
    There have been many threads on this, and everyone has a different opinion on how their own truck rides. I guess it depends on what one compares it to.
    Highway driving over concrete expansion joints can have a harmonic effect from the rear to the front. This can be caused due to factory shocks not being able to slow down the rebound of the leaf springs. We have this problem around here and it can bounce a truck around quite a bit. Ben at Filthy Motorsports has a cure for this (running a 2.5” shock on all 4 corners as it should be for a heavy truck) and custom tunes the rebound adjustment (slows down) and controls how violently leaf springs react to rebound.
    Personally, I would remove the anti-sway bar and see how you like it. Next would be shocks.
    Black Wolf, Kerch71 and Rica25 like this.
  29. Aug 20, 2019 at 8:59 AM
    djhase
    djhase New Member
    I just did a 2000 mile trip with my wife in our new 19 Tundra. It road very comfortably on all types of roads. Totally stock with the offroad package (bilstien 4600's).
    Skeezo, Tamutundra and Ronin73 like this.
  30. Aug 20, 2019 at 9:42 AM
    Rex Kramer
    Georgia
    That is it's purpose, it also helps reduce trailer sway.
