Tundra hitch receiver height vs Tacoma receiver height
Discussion in 'Towing & Hauling' started by BWTundra, Aug 27, 2018.
  1. Aug 27, 2018 at 9:16 AM
    BWTundra
    BWTundra [OP] New Member
    2018 SR5 4X4 TRD Sport CrewMax 5.7L V8
    Greetings to all. So, I had a 2017 Tacoma TRD Offroad (which I loved deeply) and purchased an RV with a stated dry weight of 3400lbs. After full water tanks, propane, battery, gear, family body weight, hitch weight, etc, I knew the Tacoma would handle it fine. It towed pretty well, even up HWY 285 from Denver to Kenosha Pass, but although the trailer brakes were cranked up a bit, it was not fun at all coming back down. Out of curiosity, I took the TT to get weighed and the reality was that the actual true dry weight was 3950. That's a big difference for the Tacoma. The TT's marketing material had a misprint (confirmed with the manufacturer). But we love the trailer and decided to upgrade to a 2018 Tundra TRD Offroad. (Got almost full value back for the Taco). Although I loved my Tacoma and miss her, I'm warming up really quickly to the Tundra. So, long story short, does anyone know the actual height difference between the Tacoma TRD Offroad hitch receiver hitch, and the Tundra TRD Offroad hitch receiver? I completely forgot to measure it before I let her go to compare. Before I go to get the TT out of storage (after the 500 mile break-in period for the Tundra), I wanted to know if I will likely need to adjust the hitch (Fastway E2) to a different height first. Thanks for your help.
    Y0TA PR0 likes this.
  2. Aug 27, 2018 at 9:22 AM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    WELCOME! Very nice truck!! I don’t know the height difference but I had to adjust my hitch when I traded my Tacoma with my tundra when I had the same TT.
  3. Aug 27, 2018 at 9:32 AM
    BWTundra
    Thank you much SR5TRDTUNDRA! That is exactly what I needed to know and will save me a couple trips. Now I'll have to figure out if I have two wrenches big enough and two arms strong enough to crank those bolts on the hitch, or if I'll have to take it in somewhere first.
  4. Aug 27, 2018 at 9:43 AM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    No problem! I had my local RV dealer adjust it for me, and they charged me a box of donuts and coffee lol :anonymous:
    Hope everything works out for you. Enjoy that nice tundra!
    Pudge and BWTundra[QUOTED][OP] like this.
  5. Aug 27, 2018 at 9:48 AM
    JGood614
    JGood614 New Member
    2018 Tundra SR5 TRD-OFFROAD
    welcome and nice truck
    if that picture is your actual vehicle then you have the Tundra TRD Sport not TRD Offroad. To my knowledge it should not affect hitch height but just incase.
    Boerseun likes this.
  6. Aug 27, 2018 at 9:52 AM
    MikeyMTBs
    MikeyMTBs New Member
    Same here. From 16 Taco to 17 Tundra, had to adjust the WDH down to accommodate for the taller tundra. The camper was nose high otherwise.
    The tundra is a great truck... I miss the size of my taco, but don’t miss the high floor seating position or how high the engine had to rev to make power. The tundra takes care of all of that but is otherwise just a big, lumbering truck.
    Good luck and enjoy!
    BWTundra[OP] and Y0TA PR0 like this.
  7. Aug 27, 2018 at 10:03 AM
    BWTundra
    JGood, you are correct. It is the Sport. I am still stuck in "Off Road" mode from the Taco. Mikey, the size of the Taco was perfect in every way and was the vehicle I have been dreaming of for at least 10 years, but when it came to pulling a full TT down hill with my family, it was really nerve wracking. I think me and the Tundra will get along just fine though.
  8. Aug 29, 2018 at 9:13 AM
    BWTundra
    FYI, it turns out that I did not need to change the hitch height. Not sure how, but it was pretty much perfect as it was. I messed up though and completely forgot the 500 mile break-in rule before towing. I hitched it up to take it the RV to the dealer for a quick repair and got about 2 miles down the road before I remembered. I turned around immediately and unhitched it. Took it really easy and slow though, so I am praying that I didn't mess anything up.
  9. Aug 29, 2018 at 10:00 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    He was saying he a TACOMA offroad and got a new tundra. There is definitely a difference in hitch height
  10. Aug 29, 2018 at 10:01 AM
    Pudge
    CT
    You're fine, pretend it didn't happen and enjoy the hell outta yoir new truck. Oh and tow that trailer when you reach 500 miles, you're gonna love it
    sprtbkr likes this.
  11. Aug 29, 2018 at 10:04 AM
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    I had a 2014 Tacoma TRD Sport and ended up moving my Fastway E2 hitch up 1 notch when I moved to the Tundra.
    BWTundra[OP] likes this.
  12. Aug 29, 2018 at 10:20 AM
    BWTundra
    After I hooked up the trailer, I checked it with the bubble level and it was near perfect. I thought for sure it would need adjustment. After I unhitched it, I took the Tundra to the RV dealer and had them measure it up against the same model of TT I have and they agreed that no adjustment was needed. Just lucky I guess.
    Pudge likes this.
  13. Aug 29, 2018 at 10:22 AM
    Pudge
    CT
    Rear seat bar is worth it at around $200, it'll tow even better. And obvi a weight distribution hitch would be even better, you won't even know its back there with those 2 parts
    Edit. I see you have a fastway wd hitch already disregard that part of my post lol
  14. Aug 29, 2018 at 10:26 AM
    BWTundra
    Pudge, I have a Fastway E2 WDH, but I had not set the bars up yet in this photo. For that couple miles I did tow before I realized my error, you are right, I didn't even feel it back there. Looking forward to towing it up the mountains in a couple of weeks if I can get enough miles on the truck by then!
    Pudge likes this.
