Tundra grille LEDs
Discussion in '2.5 Gen Tundras (2014-2021)' started by chrisbusnut, Jan 13, 2020.
  1. Jan 14, 2020 at 8:55 PM
    Rica25
    Ricardo
    Tulare
    bad ass truck
    matictundra[QUOTED] likes this.
  2. Jan 14, 2020 at 9:07 PM
    Rica25
    Ricardo
    Tulare
    did you modify those grille lights your self?
  3. Jan 14, 2020 at 9:22 PM
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    Give us the details, close up pics etc. Those look great!
  4. Jan 14, 2020 at 9:45 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Yes. Cut it using dremel and cut off wheel. I also made my own custom brackets. The lights don't mount to the grill. The lights mount to the custom brackets and to the radiator front core support. I had to flip the horns around for clearance.
  5. Jan 17, 2020 at 2:29 PM
    King R 808
    King R 808 New Member
    Ryan
    2020 White Tundra TRD Pro
    Parts are in from Vleds! Time to start my Yota leds” project! Who needs raptor leds when u got Yota!E14C32C3-569E-4163-BEBA-3C673BD069CC.jpg
    DIYDad, WFD473, Rica25 and 1 other person like this.
  6. Dec 1, 2020 at 8:00 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Bumping an old thread. I'd like to know more about how you physically mounted these lights in your hood bulge!
    the ER kid likes this.
  7. Dec 1, 2020 at 8:57 AM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Pretty easy except you have to drill a hole to put the lights through.
  8. Dec 9, 2020 at 4:40 AM
    King R 808
    Ryan
    Yes pretty simple. Used a drill to punch some holes in the plastic bulge insert and used the pod lights with flush mounting kit. Just be careful when your drilling so its not too large and the spacing is right. I sort of have OCD so had to cut small pieces of white paper and tape them in place before i drilled so i could step back and take a look. But is one of my favorite mods and simple to do. worst part for me was getting through the fire wall and mounting the button in the center console under the HU.
    DIYDad[QUOTED] likes this.
  9. Dec 9, 2020 at 5:24 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Anyone take the new honeycomb grill and put two round lights in using the same thought process as @King R 808
  10. Jan 14, 2021 at 5:08 AM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    Do you have a link for these? I got some on Amazon that were cheap. Already replaced 3X I’m over it!!! Helppp
    King R 808[QUOTED] likes this.
  11. Jan 14, 2021 at 5:19 PM
    King R 808
    Ryan
    Here ya go. Also used the flush mount kit for each and needed to get extension wires and things to mount in the bulge correctly. I can type up a parts list I used if needed. Might be a little more expensive than things online but it's been over a year and nothing has gone out. Plus they have a good warranty.
    https://www.vleds.com/shop-products/pod-lights/pod-3-w-5-5k-c.html
    KELZ84[QUOTED] likes this.
