Tundra fuel economy 5.7
Discussion in '2.5 Gen Tundras (2014-2021)' started by Lexaris1, Sep 26, 2017.
  1. Sep 26, 2017 at 4:37 PM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    lol @Tundra9831 only 500 miles on the truck you haven't even filled up the gas tank once:confused:..smh
    fulanoderock and Law323 like this.
  2. Sep 26, 2017 at 4:59 PM
    Tundra9831
    Tundra9831 New Member
    I have filled it up once after the dealer filled it up. I'm also in and out of my truck about 5-7 times per day and since it gives a summary each time I have some data on mpg during break-in. Since the OP was asking about mileage during his break-in I figured I would give some data for him to compare.
  3. Sep 26, 2017 at 5:39 PM
    BayRunner
    2017 Tundra Platinum
    Just completed a 1600 mile road trip and intentionally wanted to see what kind of mileage I could get. Kept it between 68 - 70 and finished up with 18.5 mph. Contributing factors were easy accelerations, tonneau, dual exhaust (not that this matters), and stock tires (trying to wear down the Dunlops). Not bad for a beast.
    71_340 likes this.
  4. Sep 26, 2017 at 5:58 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I have noticed that stop and go really kills the mileage on mine. The worse the traffic the worse the MPGs. Does anyone know how many gallons are left when the light comes on?
    WayneOtis and Coolhardy like this.
  5. Sep 26, 2017 at 6:26 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    I get about 10mpg, and sitting on 6inches with 35’s.
    Am I complaining? Nope!!!!
    Especially the amount of stares, thumbs up .....
  6. Sep 26, 2017 at 6:51 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Lol I wait till I'm coasting down a gradual long decline and then reset the MPGs. Once it hits the 30.0 max mpg I take a pic and that's good enough for me for that tank.
  7. Sep 26, 2017 at 9:01 PM
    geno0506
    geno0506 New Member
    Michael
    :cheers:
  8. Sep 26, 2017 at 9:08 PM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    8in lift on 37s, gettin about 9.5mpg.. thankful I got the 38gal fuel tank :rofl:
  9. Sep 26, 2017 at 9:43 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    so far the Tundra is only a couple mpg worse than the Tacoma. if you buy a truck with a big V8 and are worried about gas mileage maybe you should of got the Prius...
  10. Sep 26, 2017 at 9:55 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    Fought with my wife, left the house and filled up the gas tank. After resetting the odometer, I started following a semi at 55MPH AND that's when I saw 18.5mpg.
    That was the only way to get 18.5 mpg for me otherwise it's always been 9.5-10mpg
    Les7311, Sunnier and geno0506 like this.
  11. Sep 26, 2017 at 10:08 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    13.5 mpg freeway,11 in town..but ain't no substitution for cool!!!
    geno0506 likes this.
  12. Sep 26, 2017 at 10:14 PM
    geno0506
    geno0506 New Member
    Michael
  13. Sep 26, 2017 at 10:14 PM
    Welcome to the site. I know some people don't really care about fuel economy, but like you, I do. I have other expensive habits, so throwing money out the door has never made sense.
    Is this your first truck with a healthy V8? Pretty typical fuel economy of 13-15 in traffic and 14-18 mpg on the highway with a stock truck, and a reason I no longer DD trucks. It is a personal choice, but some of us drive anything that doubles the fuel economy ratings of a truck. So what is your actual hand calculated MPG?
    However there are things you can do bud. Here is a list:
    -Alignment. I know it is new, but the toe in/out specs are pretty liberal on these trucks. I liked having my toe in at the minimum of .06*, and total of 12* or so. I spec is 24* total which is way to much for a street driven truck. Now if you were doing the fast stuff off road, we would have a different conversation.
    -Tire pressure. The recommended tire pressure is 30 psi front and 33 psi rear. Put 38-40 psi in all 4 tires. That alone will help you out a lot.
    -After the break in period, I have usually always dropped all differential & transfer case lube oil and put fresh new synthetic lube oil in.
    -If you have a flex fuel truck, it could need a flash, especially if you are below 11 mpg on a stock truck.
    757TUNDRA, Wrongside and geno0506 like this.
  14. Sep 27, 2017 at 4:20 AM
    Sunnier
    Sunny
    San Diego, CA
    Word.
    Everything you write cracks me up!
    There's a ton of wisdom on this site. On many important topics, not just trucks. This is a perfect example.
    Drafting!
    I'm thankful for good advice on many topics, including whatever the OP asks.
    My 2017 5.7 DC is stock, about 1700 miles done. I've never reset and the best I've seen is 12.4 after 30+ mile trips. If I don't do one of those every 3 or 4 days, it starts to drop. That's based on the truck's computer reconning; I haven't bothered to pencil check it.
    smslavin[QUOTED] likes this.
  15. Sep 27, 2017 at 5:00 AM
    I getting 12 with 35's that's without a boat behind it.
    Sunnier likes this.
  16. Sep 27, 2017 at 5:45 AM
    niru316
    niru316 New Member
    2017 Tundra TRD Pro CrewMax
    Best mpg I've ever gotten was 19.8mpg on a 324m drive all highway... That was going and coming... still had about a quarter of a tank left when I got home also which was nice!
    Worst mpg is probably right about now at 10.8 all city driving... the hard part is gas is high in FL right now haha $2.65 tough pill to swallow... I know gas prices are higher in different areas too... but dang!
    I try to make good driving habits... like being easy on the gas pedal... keeping it under 2k rpm when off the line... but its so boring... But when I gotta hit it... I hit it HARD! Lol but I watch my gas gauge drop in front of my eyes... and ask myself was it worth it... HELL YA BROTHER!!!!! LET ER RIP TATER CHIP!!! Love hearing her ROAR!!!
    RICKSTUNDRA and Sunnier like this.
  17. Sep 27, 2017 at 6:20 AM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    ~3.10 a gallon in CA.
    We also have a .15 cent tax going into effect in November.
  18. Sep 27, 2017 at 6:25 AM
    onetohunt
    onetohunt New Member
    Marvin
    2016 Magnetic Gray Tundra TSS
    I get about 17.5 on the highway on trips in the Ozark hills. I get about 14.5 in the city. No complaints on either of these. I'm running 285/55/20's.
  19. Sep 27, 2017 at 6:28 AM
    #49
    niru316
    niru316 New Member
    GD!!!
  20. Sep 27, 2017 at 6:42 AM
    #50
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Gas quality has a lot to do with mileage. I was filling up at a local RaceTrac and noticed my mileage started slipping. I was making a lot of highway runs on family business (3 hour round trip in light traffice) and it started taking more and more fuel for each trip. I switched to a local Chevron station and the mileage went back up. I didn't check the MPG, just the amount I had left after a round trip. I'll stick with Tip Tier stations from now on. http://www.toptiergas.com/licensedbrands/
    NoMoTaco, ColoradoTJ and Sunnier like this.
  21. Sep 27, 2017 at 6:50 AM
    #51
    gan
    gan New Member
    Rgv Texas
    2021 Black Tundra Pro
    Mine had 1700 miles and I average about 13 but that is usually around town driving, the 4-runner I had before would get about 14/15 around town so not much better and with way less power.
  22. Sep 27, 2017 at 7:18 AM
    #52
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    JUST SEND IT!
    geno0506 and niru316 like this.
  23. Sep 28, 2017 at 2:49 PM
    #53
    Lexaris1
    Lexaris1 [OP] New Member
    2017 tundra sr acess can long bed 4x4
    I'm getting about 11 mpg I k ew they were bad I have a couple of friends with some and they say they get about 14 and drive harder than I do. I drive like a grandma. Never really rushing to go anywhere
    ColoradoTJ likes this.
  24. Sep 28, 2017 at 2:50 PM
    #54
    Lexaris1
    Thanks for all the replies hopefully t gets alittle better. Just came from being a ford owner and I'm never going back
    Sunnier likes this.
  25. Sep 28, 2017 at 2:53 PM
    #55
    Flex fuel vehicle?
    Running 87 octane?
  26. Sep 28, 2017 at 3:24 PM
    #56
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Do you have a speed and odometer calibration done?? Cause if you don't the mileage might be a lot better than you think.. the miles traveled is very inaccurate when you put 35-38's on truck... I did a round trip the other day and mine was off So I'm getting that done next
    Sunnier likes this.
  27. Sep 28, 2017 at 3:25 PM
    #57
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    @Lexaris1 not to be a dick or anything but if you wanted better fuel, you guild have got a Tacoma... Tundras are gas guzzlers with some serious power... 1-2 mpg better if you drive easy but hats about it...
    Y0TA PR0 and geno0506 like this.
  28. Sep 28, 2017 at 3:46 PM
    #58
    geno0506
    geno0506 New Member
    Michael
    Also the Tacoma doesn't do much better then the Tundra in gas for 3.5!
    RICKSTUNDRA and NoMoTaco like this.
  29. Sep 28, 2017 at 4:07 PM
    #59
    SullyMoto19
    Tyler
    Houston, Texas
    I haven't calibrated.. I mean, honestly I don't really care what I get.. gotta get gas regardless and I didn't get it for mpgs lol :anonymous:
    Jsena[QUOTED] likes this.
  30. Sep 28, 2017 at 4:41 PM
    #60
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    True, I'm gonna do mine tho and check it.. it's about 50-90 off a tank. So that's like 1-2 mpg better than ju thought it was getting.. 10mpg is more like 12mpg
