Tundra for RAM?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ultra1988, Dec 26, 2020.
  1. Dec 29, 2020 at 10:07 AM
    #181
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Toyota transmissions are tuned the same. It's painful to try to get my wife's Corolla to drop out of 4th, regardless of how slow you're going or how hard you step on the gas.
  2. Dec 29, 2020 at 10:38 AM
    #182
    Go to sequential shift mode. The only time I'm not in SS mode is cruising on the hwy.
  3. Dec 29, 2020 at 11:08 AM
    #183
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    In a 2013 Corolla? o_O
  4. Dec 29, 2020 at 11:12 AM
    #184
    In town, why not?
  5. Dec 29, 2020 at 11:52 AM
    #185
    BWinter
    BWinter New Member
    Central California
    2018 White 1794, TRD Off Road, 4x4
    I think most diesel engines in California pickups in my opinion appear to be reliable. However, when I researched diesel pickups I was more than a little concerned about the current "emissions war" on diesel engines in California. In my opinion, the environmentalist have the diesel engine in their sights. In addition, though the engines have been reliable the smog equipment on them has been a problem. I have a number of friends with very expensive repair bills the dealer would not cover. The worst case so far is a friends Duramax generated a $10,000 dollar smog system repair for California required equipment. I am unsure how wide spread the issue is but these three owners are not amused. I decided the Tundra would be a good choice for me. While my 1794 is not state of the art it works for me. My wife's 2020 Lexus is pretty techie but I turned about half of it off.
    Elevatormatt likes this.
  6. Dec 29, 2020 at 12:03 PM
    #186
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Because it doesn't have such a thing. My options are Drive, 3, 2 and L.
  7. Dec 29, 2020 at 12:10 PM
    #187
    well.....that does change things a bit
  8. Dec 29, 2020 at 12:26 PM
    #188
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Those emission stuffs are very finicky - used to work at a company and all we had were diesels (6.7 PSD) and about half had emission issues at some point. Our fleet department was pretty picky on doing maintenance so 99% of trucks were serviced at 8k km intervals, only the odd time we'd be out on shift and have to extend it. And yet we were still at probably a 40-50% emission issue rate within 100k kms. And at times it was impossible to get to a dealer within the 100km limp mode - then it's a fun drive at 30 km/h for the rest of the trip; we had a crew that had to do a 300 km trip like that.
    If the hybrids work well in the F150 and Tundra that could spell the end for diesels. Diesel engines are still good enough when compared to gas engines for heavy hauling that it's worth the risk with the emissions. If the electric motors can close this gap fleets will much prefer spending the premium engine cost on a hybrid system over diesel. Not to mention the good PR the companies will get from moving to electrics.
    JLS in WA and Cpl_Punishment like this.
  9. Dec 29, 2020 at 3:27 PM
    #189
    Great points for sure. There will be a paradigm shift eventually but not as fast as some certain folks think. Bazzion of tons of freight are being moved across our country now by diesel powered semi's, not to mention rail. Rail engines are already an electric/dino combo.aka hybrid. Our infrastructure has to be in place to provide charging stations. I won't mention the enormous amount of rare earths that will be needed to be mined to provide the amount of reliable batteries to pull off such a feat. Emphasis on mines. You can't pull rare earths out of your ass. Being "green" isn't so easy when you think about it. Going green is a good thing by all means but we have to be pragmatic about how we get there. My 2 cents.
    Terndrerrr, Istvank11, PLC721 and 4 others like this.
  10. Dec 29, 2020 at 4:22 PM
    #190
    belanger9
    Edmonton, AB
    A bunch
    It'll be interesting when one of the big 3 (my bet is on Ford since they're doing it on half tons) go to hybrid in the HD market - I don't see electric as an option for fleets, at least where I work. The shift away from diesel is already happening in the fleet market - company I work for would have been 75-80% diesel, but now it's 90% gas, diesels are either old trucks (2014 or less) or the few F550's, all new F350's or less are gassers. So it'll be 2 to 3 years before we get a good read from Ford and Toyota (based on rumors) on how the hybrids do hauling loads, then they have to transfer that tech to the HD market, so that puts it around 3-5 years before hybrids are even in them, and that's if they work well hauling.
  11. Dec 29, 2020 at 4:33 PM
    #191
    OH tundra
    OH tundra 21 Pro lunar rock
    If I was to do it all over again I would not purchase a diesel, I think 90 percent of daily use can be done with a gas HD truck for most people. Prior to these systems that choke out diesels it was much smarter to purchase a diesel for many reasons. I don’t believe that it’s worth owning a diesel unless absolutely necessary for daily use. I have a friend that purchased a brand new 75k ram 3500. At about 80k miles the truck needed about 15k worth of work to the motor. Most of the problems were related to the systems designed to keep these things cleaner. I’m not sure that these trucks will offer the same longevity that they did 15 years ago. If I ever decide that I need a HD truck again I will put my money on a gas HD before spending 70k on a diesel.
    equin, Black Wolf and Cpl_Punishment like this.
  12. Dec 29, 2020 at 4:33 PM
    #192
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Gas motors have gotten as powerful as a diesel from not that long ago. I can definitely see fleets wanting to save money on the initial purchase
  13. Dec 29, 2020 at 4:58 PM
    #193
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    The primary problem with this shift is that most diesels will get 14 mpg empty or loaded, while the gas engines will drop to 9 mpg (if you're lucky) when you're working then.
    Dalandshark likes this.
  14. Dec 29, 2020 at 5:04 PM
    #194
    OH tundra
    I completely agree that the benefits of having better mpg in a diesel is a big incentive over gas. I also think that the added cost of diesel fuel will keep those savings close to a gas truck. It was super shocking that my Chevy 3500 that could tow 35000 pounds and had a payload of 5800 pounds got better mpg than my tundra. It’s amazing what they can accomplish with these machines.
    Cpl_Punishment likes this.
  15. Dec 29, 2020 at 5:05 PM
    #195
    belanger9
    Edmonton, AB
    A bunch
    That's where I'm curious what the hybrid system will do. Will it be 9 loaded but 20 empty, will it improve loaded at all? Electric vehicles provide enough power but for fleet applications they have to be able to do 300 km of driving loaded AND idle all day, while it's -40 out. That's why I think the first HD's that are electric drive will be like locomotives with an onboard generator.
  16. Dec 29, 2020 at 5:29 PM
    #196
    How about a 1200 trip, forced rest after 8 or 10 hours for good reason, 100 degrees outside, and you have a load of frozen chickens to keep frozen while idling for hours??? The only way is with an onboard generator and dino in the tank. I still will pass on a RAM though.......:puke:
  17. Dec 30, 2020 at 2:07 AM
    #197
    Travalan
    Travalan New Member
    Travis
    Own a Ram rebel, zr2 duramax, 96tahoe, and a ford f150. Im looking to trade ram for a pro soon so I get the concerns but my ram rebel has not been as bad as everyone told me it would be. Runs good rides great. Air ride adjustable, adds 2 inches for off road drops for economy on highway. I run 34.5 inch KO2 tires and see 12-14 in town/ 15-17 highway. Zr2 has 32 inch tires duratrac 18-20mpg in town short trips. Highway we can see 30- best 37 mpgs and love it on and off road!
    Want the Toyota to be my last big truck purchase until debt is all gone.(or I haul a huge camper for hunting, fishing, etc. not likely as I wanna be debt free when I retire in 8-10 years.
    Fuel economy get a mid size truck that you can rack up the miles on and not worry as it can or will be replaced.(my ZR2 will never ever be replaced, upgraded but never replaced its that damn good!)
    Or get a smaller diesel optioned truck for work and play. Ram ecodiesel has had emissions issues but platform is solid, runs strong and new updated version is even stronger and efficient(third choice if Toyota dealers don’t stop shady deals on trucks)
    Second is AT4 2500 diesel or AT4 6.2, only after the tundra trd pro because its kinda a dream to have a Toyota truck and especially one that fits my lifestyle so well!
    Have owned lots of vehicles but will likely never go back to a small car over an SUV or Truck. I have seen way to many accidents with small cars that just didn’t hold up to crash rating standards. You get mpgs for sure no doubt but cant speak to safety.
    Top versions of new trucks have more moving parts, turbos, superchargers, hybrid assist, hybrid duel system and full electric cars trucks and SUV’s.
    1. Truck that produces mpgs and has a solid engine will likely be a mid sized truck. Small four banger, v6 option or diesel.
    2. Full size truck that produces mpgs and has actual solid drivetrain. Turbo v6, diesel, or a v8 cylinder deact/hybrid system.
    3. Solid running truck full size or otherwise but lose mpgs for longevity and or simplicity. V8 no hybrid/turbo/cyl deactivation(or in my case I just tune it out and leave it the f alone and it negates lag, wierd shifts, odd exhaust drone and vehicle shutter.) For instance had a 2014 gmc Sierra lifted 35 inch tires. After it lagged, shifted awful, droning (oh maybe you should have regeared for tires). Tuned the engine and trans for good measure, not a hot tune but a smooth powerful tune on a 5.3 with direct injection. Ran great saw 12-14mpg in town 17-18 on highway when I was not smashing the go peddle. Towing a huge metal car trailer with a old f100 long bed with a cushman golf cart in the back from new mexico to Indiana I was 6-8mpgs but it was never a struggle. Dont know the exact weight of trailer but it was likely a hair passed 8.5k(trailer/truck on trailer old/cushman scoot golf cart all old and solid steel and heavy!)
    Hard to find a balance of mpgs vs reliability. Or just buy what you want and can afford and enjoy it as lifes too short! Rant over...
  18. Dec 30, 2020 at 9:34 AM
    #198
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    The death of the diesel engine began in the early 2000's with the introduction of the EGR coolers. From there all they have done is throw more emission equipment on the engines hindering their ability to breathe properly. In my opinion if you need a diesel, that is fine. Just make sure that you "fix" the engine properly once out of warranty.
    Keep in mind that the manufacturers point to the environmentalist saying "they forced us to do this to the engine". Meanwhile they are more than happy to collect 7-10k in repairs for failed emissions equipment at 150k miles.
    Cpl_Punishment and PLC721 like this.
  19. Dec 30, 2020 at 2:59 PM
    #199
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    Ferries and many Busses have been diesel electric for a long time too... and as far as the mineral mining for batteries - its okay because the mining is happening in other countries where we don’t see it! And when the batteries are all used up, we can send them back there for “recycling”. :facepalm:
  20. Dec 30, 2020 at 5:00 PM
    #200
    daria
    daria N+1 Staff Member
    @PLC721
    Front or rear track bar?
    We were not impressed with the front. Rear was great.
  21. Dec 30, 2020 at 5:09 PM
    #201
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Front... I’ve also been told I should have bought the Icon front
    I think you asked in the wrong thread haha!
  22. Dec 31, 2020 at 8:37 AM
    #202
    ssnyt
    ssnyt New Member
    2019 Tundra Pro
    op, i was in the same boat as you. i own a 2006 tundra and know the gas mileage it gets and the new one is worse. that being said, i did the math and the tundra even with its poor gas mileage is still the better buy than the ram.
    i bought a used pro with 18k miles. the rebel i was looking at was $60k with the air suspension. the real world mileage of the rebel is 18-19. the real world mileage of the pro is 13-15. do the math yourself and you will see the cost of gas is negligible compared to the time you spend at the RAM dealer for warranty repair and other nonsense.
    i am a mopar guy and it was hard for me to come to the conclusion that the hemi just wasnt worth it.
  23. Dec 31, 2020 at 8:40 AM
    #203
    ssnyt
    ssnyt New Member
    2019 Tundra Pro
    the at4 1500 was what i was going back and forth with before buying my pro. reliability won me over.
  24. Dec 31, 2020 at 8:41 AM
    #204
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    IG: PLC721
    AT4 with the 6.2 was real tempting to me
    Terndrerrr and Cpl_Punishment like this.
  25. Dec 31, 2020 at 8:46 AM
    #205
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    I wonder how much this can tow, drop a 5th wheel on this thing and let her rip down the highway
  26. Jan 1, 2021 at 8:05 PM
    #206
    Rica25
    Ricardo
    Tulare
    Question for the Ram guys. So my son just purchased a 2021 Ram Rebel I could not convince him to buy a Tundra. So he is wondering what is a good exhaust system with no drone?
  27. Jan 1, 2021 at 8:31 PM
    #207
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    No drone? He shoulda got a Prius then!
  28. Jan 1, 2021 at 8:40 PM
    #208
    Rica25
    Ricardo
    Tulare
    Ba muffler has no drone and its bad ass sound
    bleach likes this.
  29. Jan 1, 2021 at 8:42 PM
    #209
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    I don't need any muffler for a real bad ass sound, especially after beans or cabbage.:D
    Rica25[QUOTED] likes this.
  30. Jan 1, 2021 at 9:15 PM
    #210
    belanger9
    Edmonton, AB
    A bunch
    Get a regular Ram single exhaust, any others I've seen around are even louder than the stock Ram dual exhaust that comes on the Rebel.
