TUNDRA for overlanding????
Discussion in '2nd Gen Builds (2007-2013)' started by TOO-TUF, Apr 2, 2020.
  1. Apr 5, 2020 at 8:29 AM
    adv_mnd
    adv_mnd New Member
    Dave
    2008 White Tundra DC / 2019 Cav Blue Tundra CM
    Thats why I got the CFX-75 :cheers:
  2. Apr 5, 2020 at 8:45 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Any reason to spend more than $100-150 for an air compressor?
  3. Apr 5, 2020 at 8:51 AM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    yeah. Duty cycle and cfm
    viair 400p automatic is the lowest I’d personally recommend. Well worth the few extra dollars.
    also can’t go wrong with arb single or twin
    JimboSlice413 likes this.
  4. Apr 5, 2020 at 8:55 AM
    JLS in WA
    In terms of rear leaf springs vs a shackle lift, is there any difference in performance? Icon springs are $275 vs 200 for Camburg shackles.
  5. Apr 5, 2020 at 9:14 AM
    shellshock
    Iowa
    2019 TRD PRO
    Depends what you are wanting to accomplish. Shackles are only gonna add the length. Replacing the springs can change the ride as well to accommodate added weight or just to stiffen the ride.
    I replaced my leaf pack, it’s much beefier than the stock one
  6. Apr 5, 2020 at 9:24 AM
    JLS in WA
    I’ll have to pencil out the added weight. Topper, 10 gallons of gas, water, gear. I might be pushing the range where I should maybe go leaf springs instead. Either way, I want the 1.5” to help give a little more side clearance.
  7. Apr 5, 2020 at 9:33 AM
    shellshock
    Iowa
    2019 TRD PRO
    I went with icon RXT. They come with an extra leaf so you can adjust for up to 750+ lbs over stock.
    I’m running about 400 lbs constant over stock plus gear. I’m on option 2 and it is still a bit higher than my pro was from the factory.
    option 1 (up to 250 lbs) over stock would probably be sufficient for what you listed unless you want more lift or stiffness.
    JLS in WA[QUOTED] likes this.
  8. Apr 5, 2020 at 10:51 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
  9. Apr 5, 2020 at 11:34 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    I've used the 400p auto for a couple years now. Really nice compressor
  10. Apr 5, 2020 at 11:56 AM
    JLS in WA
    I appreciate the feedback. I never did much airing down with my Dodge. I also played with fire for a lot of years by not carrying a compressor and patch kit.
    shellshock likes this.
  11. Apr 5, 2020 at 12:32 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
  12. Apr 5, 2020 at 1:24 PM
    Taco-Blender
    AZ
    2010 DC 4x4
    Yeah, super comfortable and nothing really to set up and take down, which I really like.
    The whole mess comes out in 5 minutes when I need to use the truck as a truck.
  13. Apr 5, 2020 at 1:41 PM
    JLS in WA
    This was the one I was looking at. I may spring the extra hundred and get the 400P Auto. Quadratec has them for $256.
    I think I'll get some Maxsa traction boards, and other than figuring out some mounting systems, I should be pretty well set.
  14. Apr 5, 2020 at 7:55 PM
    NoRcptn
    NorCal
    2017 Platinum
    Super easy and a really inexpensive way to try stuff out. I like it.
  15. Apr 5, 2020 at 8:27 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Really love this bottom photo
    shellshock[QUOTED] likes this.
  16. Apr 5, 2020 at 8:31 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    You can also get some 4x4 or 4x6 boards for way cheaper than any traction boards. If you ever lose one in the muck or mud it's not a big deal and they're pretty tough.
  17. Apr 5, 2020 at 8:42 PM
    shellshock
    Iowa
    2019 TRD PRO
    I air down and up all the time. Check this out, makes it way easier. When it’s quick and easy, you are far more likely to do it.
    https://www.tacomaworld.com/threads/shellshocks-diy-inflator-deflator.613122/
  18. Apr 5, 2020 at 8:45 PM
    1794-BlackTundra
    1794-BlackTundra New Member
    Sergio
    2019 Black Tundra 1794 Edition CM
    Rhino Linings, Smittybilt 11500 Winch (Internal), BAKflip MX4, RotopaX, MaxTrax, ARB Simpson III tent, Old Man Emu suspension, TRD rims, Pioneer Platform with Rhino-Rack Backbone System
    Hello there! The reason I got my Tundra was with the purpose of overlanding.
    One thing I have learnt over this past year it's, the obvious... it's Big, wide and heavy!
    Sometimes this reality makes some terrains (soft or slippery mud) more challenging for the truck!
    Don't get me wrong, I totally love it and it's mighty power!
    This it's my set up! Here you can check better pics
    https://www.instagram.com/p/B73zB6AHRNy/
    I'm planning to get, in a few months, ARB Air Lockers for front and rear...
    So far... ARB Bull bar, ARB RTT, ARB awning (and awning walls), ARB on-board High performance Air compressor twin, ARB Elements Fridge, OME Nitro charger sport suspension, KB Voodoo rack, Rigid light bar, Rhino Rack Pioneer Platform, Maxtrax, Rotopax... :facepalm:I'm sure I'm missing something else...
    EDIT: Now I remember... Black Toyota Pro Grille, black mirror covers, black bumper covers and black door handles. Power tailgate Lock. Wireless Charging Tray. :hattip:
    I totally love this beast... But, when I need a lighter footprint, you can check it's companion on Instagram...
  19. Apr 5, 2020 at 8:59 PM
    #49
    shellshock
    Iowa
    2019 TRD PRO
    It’s out in Colorado this past fall. A lot of it was over 12,000 feet. The trail was more than we bargained for but we all made it back in one piece. I nicked a slider but aside from that I was good. The guy in the blue Tacoma bashed up his skids pretty good.
    Krezz[QUOTED] likes this.
  20. Apr 7, 2020 at 10:33 AM
    #50
    JLS in WA
  21. Apr 7, 2020 at 10:38 AM
    #51
    shellshock
    Iowa
    2019 TRD PRO
    Could. It’s gonna be super slow though.
    you want a compressor that clips to the battery terminals, you can’t pull much power through a 12v plug
  22. Apr 7, 2020 at 2:56 PM
    #52
    Taco-Blender
    AZ
    2010 DC 4x4
    Yeah, .5 cfm is not a lot of output. You could end up pretty drunk by the time you're done airing up.
  23. Apr 7, 2020 at 3:20 PM
    #53
    NoRcptn
    NorCal
    2017 Platinum
    this just came through in my email. Haven’t listened to it yet, but it discusses , ground tents, RTT, Habitats.
    https://overlandjournal.com/podcast/
  24. Apr 7, 2020 at 4:10 PM
    #54
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Beautiful rig! :thumbsup:
  25. Apr 7, 2020 at 4:14 PM
    #55
    1794-BlackTundra
    Sergio
    Thanks bud!
  26. Apr 7, 2020 at 5:14 PM
    #56
    shellshock
    Iowa
    2019 TRD PRO
    Exactly. The viair and arb single are 2-3 cfm. That’s the difference between being done in 10 minutes or 10 minutes a tire..
    JLS in WA likes this.
  27. Apr 7, 2020 at 7:07 PM
    #57
    JLS in WA
    I’ll give this a listen. I really doubt I’ll buy anything for a year or two. More than anything I just use my backpacking air pad and a sleeping bag under the canopy.
    I’ll buy one of the Viair 400P pumps and some traction boards and that’ll get me by for now.
  28. Apr 7, 2020 at 7:12 PM
    #58
    JLS in WA
    I did spring for one of these. With the 26 gallon tank I have a feeling this will stay in the back quite a bit.
  29. Apr 7, 2020 at 7:12 PM
    #59
    NoRcptn
    NorCal
    2017 Platinum
    I did that for years. It’s a simpler and easier way to go, and probably still my favorite. Taking the other three family members with me outgrew my comfy arrangements.
  30. Apr 7, 2020 at 7:19 PM
    #60
    JLS in WA
    We’re on the downsize side of family life. We’ll be down from three kids at home to one in the next couple of years. Might just save the money for a 18’ travel trailer LOL.
    NoRcptn[QUOTED] likes this.
