Tundra engine recall - interesting news
Discussion in '3rd Gen Tundras (2022+)' started by katekebo, Jul 25, 2024.
  1. Dec 26, 2024 at 6:03 AM
    #2551
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Toyota dealers are lightweights. All the other major truck OEM dealers have one. Or more.
    DimSum07 likes this.
  2. Dec 26, 2024 at 7:37 AM
    #2552
    FrankG
    FrankG New Member
    Francois
    2022 Lunar Rock Sr5 TRD Off Road
    I think you guys are confusing 2 different pieces of equipment here. All Toyota dealers have multiple above ground hoists. That’s the 2 or 4 pillar thing that can lift the entire truck or just the cab if needed. The new part dealers are getting appears to be a taller “cherry picker” specially designed to be able to lift higher than the standard one all the dealers would also already have. That is to remove only the motor.
    Tidechaser and mrlittlejohn like this.
  3. Dec 26, 2024 at 8:29 AM
    #2553
    Fatone
    Fatone New Member
    Seems like if all the dealers had existing infrastructure to do engine swaps then Toyota would have avoided the extra money and time on deploying a new tool dealer network wide.
    I guess maybe there is the possibility dealerships had no standard lifts so that made standard instructions impossible. But step 1 "remove the cab" would not have needed additional instructions in volume truck service centers.
  4. Dec 26, 2024 at 8:52 AM
    #2554
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  5. Dec 26, 2024 at 8:52 AM
    #2555
    FrankG
    FrankG New Member
    Francois
    So supplying dealers with a new piece of equipment that expedites the process significantly and is less invasive than a cab off alternative in the face of 100k replacements doesn’t make sense to you? The cost of a new cherry picker becomes a good investment imho not to mention decreasing the potential for human error by simplifying the swap.
  6. Dec 26, 2024 at 9:34 AM
    #2556
    Toyota_Ed
    Toyota_Ed New Member
    Ed
    Hades - Panhandle of Texas
    1967 Stout - 2024 Tunra
    We're doing at first long block today, leaving the cab on here... we have 10 long blocks now in stock, waiting to see how this all goes
    Kap1, Ausfahrt, CajunTim and 6 others like this.
  7. Dec 26, 2024 at 9:47 AM
    #2557
    Gonefishingdave
    Gonefishingdave New Member
    Dave
    Central New York
    2024 MGM Tundra TRD OR Limited
    Bakflip cover, AVS vent visors
    Good luck! That customer was courageous to be number one
    cartage1 likes this.
  8. Dec 26, 2024 at 9:48 AM
    #2558
    Toyota_Ed
    Ed
    It's a used Truck from the VW lot, lol...
    Black Wolf, Lt. Dangle and raylo like this.
  9. Dec 26, 2024 at 1:02 PM
    #2559
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    Why would a man lift be needed for an engine swap? I’m a little lost on that one.
  10. Dec 26, 2024 at 1:56 PM
    #2560
    Fatone
    Fatone New Member
    You assume taking taking the hood off, disconnecting/reconnecting engine, and removing/inserting engine is harder than doing it all with cab off and full 360 access. That may not be a valid assumption.
    Taking the cab off if a big 3 truck is extremely common for repairs. I have cruised thru service lots with multiple cabs swinging in the air at once. One of the chief advantages of body on frame construction vs unibody is you can replace a whole lot of systems via cab off easier and better
    For example a frame on a unibody is a total. A frame bent truck the frame can be repaired.
    The most logical reason for time and money on custom tool is that some Toyota shops don't have lifts for the cab off or Toyotas cab off process is more cumbersome than the big 3.
  11. Dec 26, 2024 at 2:07 PM
    #2561
    FrankG
    FrankG New Member
    Francois
    Did you not watch the video that’s been posted twice on the previous page? That technician seems pretty excited with how easy the process actually is without removing the cab.
    Yes, I am assuming taking the hood off is simpler than taking the entire cab off since that is the only part of the process that’s different. Everything else still needs to be disconnected and reconnected. As mentioned above, the tech in the video seemed to think removing the engine with the cab on wasn’t a big deal. I’ll take his word over whatever you’re trying to speculate.
    Also, if you look at said video, the truck is on a hoist. Seems like they have to remove the wheels to get it low enough to pull the engine. Now here I also assume that the transmission and some other parts like motor mounts can be unbolted from below while it’s on the hoist you claim most dealers don’t have.
  12. Dec 26, 2024 at 2:14 PM
    #2562
    Fatone
    Fatone New Member
    To each his own I guess
    Happy new year
    Kap1 likes this.
  13. Dec 26, 2024 at 2:20 PM
    #2563
    FrankG
    FrankG New Member
    Francois
    Same to you
  14. Dec 26, 2024 at 2:27 PM
    #2564
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    There are far more disconnections and reconnections to be made, if you take the cab off. No way that method would be faster, or easier.
    Cherry picking just the engine, just like that video showed, is by far the best way to do it, IMO.
    It's clear some of the posters on this thread have never done engine swaps.
    Tidechaser, raylo, BoulderGT3 and 6 others like this.
  15. Dec 26, 2024 at 2:43 PM
    #2565
    Toyota_Ed
    Ed
    Yep, our shop techs have decided to do with the cab still ON the trucks.
    Black Wolf, kirkb, Mr Rick and 4 others like this.
  16. Dec 26, 2024 at 6:51 PM
    #2566
    timmytumdra
    timmytumdra New Member
    2023 Army Green SR5 TRD Off Road
    Posting in this thread, my truck was manufactured after the listed February 2023 affected dates, but had the short block, fuel lines, etc. rebuild done for its previous recall. Had the recall completed before purchase and helped get the price down, just wondering why it a) was involved and b) seemingly wasn’t part of the engine swap. Some of my mechanic buddies have said they might’ve taken that short block out to inspect and compare it with earlier produced/affected ones. CarFax for it is clean with the recall notes, but nothing to cause concern. Will be posting about it through the year, as I can’t really find anyone else with the short block remedy completed. Bought it CPO so it’s under their CPO warranties after the recall was closed out.
    Mr Rick likes this.
  17. Dec 26, 2024 at 8:20 PM
    #2567
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Engine blew on your truck and got the standard/pre-recall remedy, most likely.
  18. Dec 26, 2024 at 8:22 PM
    #2568
    timmytumdra
    Would that not show on a CarFax or just labelled clean under the fact that there was a recall? Any cause for concern, mechanic in the family has advised to trust toyota and enjoy the discounted truck
  19. Dec 26, 2024 at 8:34 PM
    #2569
    DRP
    DRP Old Member
    Dave
    Your truck wasn't in the recall so it got the short block. Not sure why it doesn't show in Carfax. I would agree with just drive and enjoy.
  20. Dec 26, 2024 at 8:54 PM
    #2570
    FrankG
    FrankG New Member
    Francois
    How do you know it had a shortblock replacement? The fuel line was a recall, shortblock was not.
  21. Dec 26, 2024 at 9:33 PM
    #2571
    timmytumdra
    It’s stated on the CarFax that it has the replacement done, but the carfax itself is “clean” no sign of previous damage so I assumed it was a pre recall maybe. Not worried about it too much bc of Toyotas gold CPO warranties
  22. Dec 27, 2024 at 5:32 AM
    #2572
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    The engine blew, owner traded it in, dealer did the work, resell with new short block. There is no way they would have pulled it that far for an inspection. Weird that it doesn’t show as that. If you have the 100k Toyota used car warranty, and it runs good then enjoy it!
    Kap1 and timmytumdra like this.
  23. Dec 29, 2024 at 10:17 AM
    #2573
    Tundra-G
    Tundra-G New Member
    2022 Tundra Ltd 4x4 TRD Off-road
    A similar situation happened with 2014-2015 Porsche GT3s, where they had defective engines. Porsche replaced the engines and gave customers 10 yr / 100k mile warranty.
    This is how it should be, my 02 cents.
  24. Dec 29, 2024 at 10:54 AM
    #2574
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    Porsche was confident they had a permanent fix, Toyota not so much it seems.
  25. Dec 29, 2024 at 10:55 AM
    #2575
    Breathing Borla
    Northern Illinois
    that’s a little unfair at this point , it’s barely getting started
    I know your all down on this , I get it , but let’s not go overboard just yet
  26. Dec 29, 2024 at 11:01 AM
    #2576
    WNY PAT
    WNY PAT New Member
    Western New York
    Yes, I know I’m more cynical about the whole situation than you are. If Toyota was so confident they had a permanent solution to whatever is going on, why the lack of an extended warranty then? Maybe 10/100K is unrealistic, but certainly 5/60 from the date of the installation of the long block assembly would be fair. You guys bought a truck with a 5/60 powertrain warranty and the engine was defective. Toyota is replacing the defective engine with an engine they claim has been fixed, that new engine ought to be covered 5/60 as well IMO. You guys paid for that coverage.
    GODZILLA, shorenetworks and szabo101 like this.
  27. Dec 29, 2024 at 11:06 AM
    #2577
    Fatone
    Fatone New Member
    Amen.
    Shorting the customer on the extended warranty for a full power train replacement (engine or tranny) is bottom shelf customer service. Fairly unheard of. Even Detroit does it
    Many like me will just ride engine 1 until it drops and keep the freebie engine coupon in our hip pocket. There is no motivation to do otherwise so Toyo will be tracking and reporting on this recall and swapping engines into the next decade
    Teddyk1 and Tidechaser like this.
  28. Dec 29, 2024 at 11:59 AM
    #2578
    Breathing Borla
    Northern Illinois
    we talked about this before.
    Im not so sure yet that the customer confidence portion is even going yet, they are just underway (barely) with the replacements, so give it some time before we 100% concluded there will be no extended warranty.
    lets just chill for a few and see what happens here for a bit
    That said, how is anyone not getting the 5/60 they paid for, everyone is in fact covered for that amount of time. Im not saying Toyota shouldn't do more to improve the optics, but nobody is getting shorted for the warranty they got when they bought.
    Tundrastruck91 and FrankG like this.
  29. Dec 29, 2024 at 12:08 PM
    #2579
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    What is Toyota paying you? We need to know
    :tumbleweed:
  30. Dec 29, 2024 at 12:23 PM
    #2580
    Pathfinder21
    Pathfinder21 New Member
    2022 Tundra Platinum - Crewmax 5.5'
    Wondering how the first ‘22 Tundra engine replacement is coming along? Any hiccups that were unexpected?
    I visited my dealership after Christmas to have them record my old engine number and they said they are ordering the new replacement engine. My ‘22 has mfg date of Feb2022 and said mine is part of phase 1 recall.
    Service rep said all of my fluids are replaced with new (radiator, turbos, oil, a/c refrigerant). I was surprised to hear that the existing engine oil pan is being reused. Can you confirm if that is standard practice for all these recalls? Are they going to change out the Transmission fluid too?
    Swapping out the oil pan seems odd to me and allows a chance of oil leakage around the gasket after spending hours pulling and replacing a motor. Guess Toyota is worried the steel oil pan could be damaged in shipment? Or they are thinking it makes it harder for old motor to get reused? From the engine swap video circulating on YouTube and here on Tundras.com, it looks like the crated engine rests on the lower crankshaft housing, hope that doesn’t cause issues while shipping these motors to the dealerships.
    I told the Toyota dealership service rep that I wanted to have a new alternator/a/c compressor/radiator fan drive belt instead of using my old one from the original engine. I’ve got approx 55K miles on the original motor, might as well replace it with a new engine going in.
    Also want them to install a new A/C filter/dryer since they are going to have to break a/c lines to pull original motor. Having that line open for multiple days is not good for moisture getting in. I’m willing to pay for these parts so I can get a good clean install from the get go. If there is anything else I should replace during this service, please let me know as I want this to be the best experience possible.
