Tundra engine recall - interesting news
Discussion in '3rd Gen Tundras (2022+)' started by katekebo, Jul 25, 2024.
  1. Aug 4, 2024 at 5:28 PM
    #661
    BaldMenace
    BaldMenace New Member
    2022 Tundra SR5 Double cab
    There's nothing wrong with the engine design. Plenty of power, reasonable economy. it's funny to watch the 2nd generation owning trolls try to come across as superior.
    Breathing Borla likes this.
  2. Aug 4, 2024 at 5:38 PM
    #662
    bluemoon737
    bluemoon737 New Member
    Jeff
    2023 Blueprint Tundra Platinum
    '23 Platinum owner here (first ever Toyota, time will tell if last), you can't ignore the engine failures and the recall impact on valuation. Way too early to say there isn't a design issue.
  3. Aug 4, 2024 at 5:54 PM
    #663
    Breathing Borla
    AZ
    fwiw that’s what Toyota said they evaluated and reported to the feds, design checked out again and it’s a manufacturing problem
    For my money , if it was a design problem, you would see a hell of a lot more actual failures, they have made how many gen 3 tundras now? 100s of thousands
    Kap1, bluemoon737[QUOTED] and Lee.M like this.
  4. Aug 4, 2024 at 5:55 PM
    #664
    BaldMenace
    I have a 2022 and it's been flawless in every way.
  5. Aug 4, 2024 at 6:21 PM
    #665
    bluemoon737
    Jeff
    Hey I just finished pulling a 30ft, 7000+ lb camper over 7200 miles on a trip out west. The truck did great, doesn't mean I'm not very concerned.
    szabo101, Kap1 and Nm6300'asl like this.
  6. Aug 4, 2024 at 6:27 PM
    #666
    WNY PAT
    WNY PAT New Member
    FWIW, I doubt any 2G owner is feeling good or superior about the plight of 3G owners. Maybe the few of you who can’t seem to manage your emotions when reading about the 3.4TT should start a “safe space thread” where you don’t have to read any opinions that might “trigger” you.
    And if it’s just a manufacturing issue, why the new bearings? And why are the failures still happening long after Toyota identified “matching debris” as the culprit? You’re telling me you honestly believe Toyota can’t figure out how to clear out machining debris on multiple assembly lines? I don’t believe that for a second, which is why I’m on the sidelines on replacing my current truck with a gen 3 until I know the problem has been fixed and reports of failures dry up.
  7. Aug 4, 2024 at 6:29 PM
    #667
    bluemoon737
    Jeff
    And Toyota said the issue was bounded to a specific production time frame and production plant. Yet engines are failing outside that time frame...again, until we see teardown of the "new" engines there is no way of knowing if something wasn't changed. Component selections are part of "design"...do the new engines have all the exact same components? Nobody here knows.
  8. Aug 4, 2024 at 6:34 PM
    #668
    Breathing Borla
    AZ
    I get it, they are looking at acceptable failure rates is my guess
    and fyi, the bearing part number was replaced
    bluemoon737[QUOTED] likes this.
  9. Aug 4, 2024 at 6:40 PM
    #669
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    The bearing part number change suggests differently.
  10. Aug 4, 2024 at 6:58 PM
    #670
    Lou1947
    Lou1947 New Member
    Tundra 1794
    My 22 1794 is on the recall list but so far I haven’t received the letter from Toyota. So far my truck has been bullet proof with no issues after 51,000 miles. Is Toyota planning to replace all the recall motors even if they haven’t blown? My guess is that they won’t replace the motor until it blows.
  11. Aug 4, 2024 at 7:01 PM
    #671
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    That’s the whole reason for the recall , to replace the engine “ before “ it blows .
  12. Aug 4, 2024 at 7:06 PM
    #672
    Hate when I have the perfect meme for the occasion but can't post it....
  13. Aug 4, 2024 at 7:12 PM
    #673
    BaldMenace
    That's not engine design that's a consumable component.
    szabo101 likes this.
  14. Aug 4, 2024 at 7:12 PM
    #674
    AZBoatHauler
    So.Arizona
    :rofl::rofl::rofl:
    only in a 3rd gen.
    DimSum07, Black Wolf, hagrid and 12 others like this.
  15. Aug 4, 2024 at 7:17 PM
    #675
    kirkb
    DFW
    I assume you are joking.
  16. Aug 4, 2024 at 7:36 PM
    #676
    Breathing Borla
    AZ
    that’s bullshit hauler, he put that on a tee for ya! Haha
  17. Aug 4, 2024 at 7:43 PM
    #677
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It’s always the guys who make comments like this
    Who say shit like this.
  18. Aug 4, 2024 at 7:52 PM
    #678
    AZBoatHauler
    So.Arizona
    Stars aligned.
  19. Aug 4, 2024 at 7:54 PM
    #679
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Why not? Think you'll tick off the mods? :D
  20. Aug 4, 2024 at 7:55 PM
    #680
    Pretty much. The staff here can get a little grumpy.:anonymous:
  21. Aug 4, 2024 at 8:14 PM
    #681
    Kap1
    Kap1 New Member
    San Francisco, CA
    So far, no credible sources have any better theories on what may be causing these failures.
    So yes, believe it or not, poor machining and debris could be the real issue here. Yes, robots in both plants in Japan and Alabama screwed up machining and didn't check engines that they were producing... Until few hundred thousand units were made and installed into the new trucks.
    I didn't believe it either until Ryan posted photos of the old short block he bought which was not milled correctly, holes were not drilled fully, and also had bunch of debris in it.
    Maybe few of the parts they changed also could be beneficial...
    But as you can see, all failures are absolutely random. I think what happens is piece of debris can get de attached inside of the engine and maybe get stuck in the bearings or maybe not - this is why it's all random and some engines go 100k miles while others 12k miles.
    j-utah and Breathing Borla like this.
  22. Aug 4, 2024 at 8:16 PM
    #682
    Breathing Borla
    AZ
    stop , stop, stop. We are all going to dump this shit and buy 2021s. The tundra will no longer be made and Toyota sucks now and is going out of business
    DimSum07, PermaFrostTRD and brtnstrns like this.
  23. Aug 4, 2024 at 8:21 PM
    #683
    Kap1
    Kap1 New Member
    San Francisco, CA
    The funny part is all of the wind noise in my truck is gone, probably stuffed by dirt, and I don't even notice the rear diff whistling anymore. Used to it
  24. Aug 4, 2024 at 8:33 PM
    #684
    winchester44
    winchester44 New Member
    2016 1794 4WD
    And
    Exactly what car care nut was talking about and all those still having issues post short block replacement. If it didn’t have metal shavings in the block before, it darn sure will spending a few weeks on the floor of that shop.
    I’ve seen a more organized kindergarten art class…
  25. Aug 4, 2024 at 8:38 PM
    #685
    winchester44
    2016 1794 4WD
    You’re doing it wrong.
  26. Aug 4, 2024 at 8:41 PM
    #686
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Yes to both in my case. Well it’s actually in the app.
    hinkle[QUOTED] likes this.
  27. Aug 4, 2024 at 8:51 PM
    #687
    winchester44
    2016 1794 4WD
    Well said. I’m still not convinced the bad components in Japan didn't come from Alabama though. No QC review to production was mentioned in Japan, onlyAlabama.
    Amazing how many armchair engineers are calling Toyota bald face liars saying they made up the bad machining to cover up a design flaw. I mean it’s Toyota….not Boeing.
    BaldMenace and Kap1[QUOTED] like this.
  28. Aug 4, 2024 at 9:33 PM
    #688
    Austintaco
    Austintaco New Member
    Patrick
    Austin, TX
    2021 Lunar Rock TRD Pro, 2003 Tacoma DC TRD, 1984 SR5 4runner with 1uz, 85 Supra
    285/75/18 Duratraks, 5.29’s and Powertrax in the rear, Eibach Pro lift coils, JBA UCAs, RAS and CB Plus 3, AT transmission cooler, RAGO dash plate, Boost Tow mirrors
    Just a general statement as a Toyota fanboy that is new to the Tundra club. I hope that Toyota continues to work with owners of the 3rd gen trucks, but even with replacing engines, the hassle will probably make many owners sell. That might be good for everyone that has been complaining about the cost of new trucks. Maybe the Toyota tax will take a hit for a second and allow people who work for a living to buy the truck they wanted but could not afford. I’m trying to look at the bright side. Hopefully, Toyota nips this in the bud, and moves on, but there will be many customers that will still be the ones to endure trips to the dealer, loaner trucks and delays.
    FrenchToasty and Tundrastruck91 like this.
  29. Aug 4, 2024 at 10:54 PM
    #689
    brtnstrns
    brtnstrns New Member
    2024 Tundra Platinum HV; 2022 Polestar 2
    lol this is what I’m doing. Lots of people trying to spend a bunch of time and money heading off the problem even though it’s pretty clear it’ll either happen to you or won’t.
    I’ll stick with whatever oil change intervals Toyota tells me to do and worry about a blown engine if/when it happens. Changing the oil three times before 5000 miles? Meh!
    BaldMenace likes this.
  30. Aug 5, 2024 at 1:03 AM
    #690
    MrKABC
    MrKABC Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    Miller Cat Shield, Sumo Springs Blue, Diode Dynamics Stage Series hidden light bar.
    I hope he is! :thumbsup:
    Tundrastruck91 likes this.
