Tundra engine recall - interesting news
Discussion in '3rd Gen Tundras (2022+)' started by katekebo, Jul 25, 2024.
  1. Feb 17, 2025 at 12:15 PM
    #4051
    sudobash
    sudobash New Member
    As long as they are providing a loaner, they are within the realm of what is stated in the recall documents released on NHTSA.
  2. Feb 17, 2025 at 12:15 PM
    #4052
    FrankG
    FrankG New Member
    Francois
    2022 Lunar Rock Sr5 TRD Off Road
    This statement doesn’t make sense. Let me put it this way. We have 3 full production years, 22, 23 and 24. Much more miles on 22 than 23 and even less on 24. 22’s are still reporting failure. So we don’t know how many will eventually fail. How can you say that’s the same as the rates on 24 if the rate for 22 is unknown? Do you know the current rate of failure on 22’s and can you share a ballpark?
    Nm6300'asl likes this.
  3. Feb 17, 2025 at 12:16 PM
    #4053
    sudobash
    sudobash New Member
    Yes, but unable to share that specific number.
  4. Feb 17, 2025 at 12:17 PM
    #4054
    FrankG
    FrankG New Member
    Francois
    Can you say if it’s over or under 5%
  5. Feb 17, 2025 at 12:42 PM
    #4055
    GamecockEng
    GamecockEng New Member
    2022 Tundra CrewMax Limited
    My truck is still running without any problems. I guess my truck is slotted for a different engine release phase.
  6. Feb 17, 2025 at 12:46 PM
    #4056
    sudobash
    sudobash New Member
    GX 550 Engine Failure
    Kap1 likes this.
  7. Feb 17, 2025 at 1:03 PM
    #4057
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I haven't kept up with this thread, so forgive me if this has been asked and answered recently.
    Is the current most informed speculation that the engine debris issue wasn't fully resolved until Nov 2024? And, has it been confirmed that hybrids do not have motive power after the engine failure occurs?
    If so, is there any indication that Toyota will expand the recall to include all Gen 3 Tundras up to 11/24, including hybrids?
    cartage1 likes this.
  8. Feb 17, 2025 at 1:04 PM
    #4058
    sudobash
    sudobash New Member
    Correct on all accounts.
    EDIT: Toyota HAS NOT given any indication of expanding the recall.
  9. Feb 17, 2025 at 1:07 PM
    #4059
    Matt2015Tundra
    2023 1794 CrewMax
    So, Toyota has hinted at expanding the recall?
  10. Feb 17, 2025 at 1:11 PM
    #4060
    sudobash
    sudobash New Member
    Helps when you don't read too fast.
    Toyota HAS NOT given any indication at expanding the recall.
    Apologies.
  11. Feb 17, 2025 at 1:28 PM
    #4061
    g4waldo
    g4waldo Professional Looking CSM Owner
    2023 Celestial Silver Metallic Tundra Platinum 4x4
    I would think the failure rate would have gone down even if not fully resolved. Are you saying that Toyota believes the failure rate post-2/23 builds may be at a similar failure rate as those involved in the recall? I'm sure there's a line in the sand where failure rate is enough to expand the recall versus not.
    Are they 100% sure of themselves that post-Nov builds are finally free and clear of debris forever?
    Also curious that if some recall engine assemblies were built before 11/24, do they believe those may also be affected by debris?
  12. Feb 17, 2025 at 1:40 PM
    #4062
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    I can not answer the other questions, but the recall motors are being assemble in a different "line" than the non recall motors. So hopefully those are clean motors.
    sudobash likes this.
  13. Feb 17, 2025 at 2:54 PM
    #4063
    sudobash
    sudobash New Member
    Dealerships are now reporting that the engine assembly for the recall is having post replacement failures.
    woods and cartage1 like this.
  14. Feb 17, 2025 at 3:03 PM
    #4064
    FrankG
    FrankG New Member
    Francois
    Oh ffs! Given that you can’t share much of your info and knowledge here, let me cut to the chase and ask you what I’m sure a lot of us are thinking. I’m over 100k km of problem free driving. Do I get my motor changed as soon as I can or keep going for as long as possible on current one? What are your thoughts?
    woods, cory15000 and sudobash[QUOTED] like this.
  15. Feb 17, 2025 at 3:08 PM
    #4065
    sudobash
    sudobash New Member
    What phase are you in?
  16. Feb 17, 2025 at 3:18 PM
    #4066
    FrankG
    FrankG New Member
    Francois
    Dunno. Up in Canada. April 22 build.
  17. Feb 17, 2025 at 3:27 PM
    #4067
    sudobash
    sudobash New Member
    Let's see what can be found on the that subject.
  18. Feb 17, 2025 at 3:32 PM
    #4068
    cory15000
    cory15000 New Member
    Hit the nail on the head - thank you.
    I’m trying to keep up here but @sudobash are you saying that there are reports of failures on some engines that have already been replaced? Any idea if these would be short blocks or long blocks being replaced originally?
    Additionally, are you saying that the crated engines are being built on their own assembly line? And that the debris issue wasn’t likely resolved until Nov 2024 hence why we’re still seeing failures for all MY’s (‘22-‘25)?
    I’m looking at buying a used 2022 that has 63,000 KM on it (Canada) and am trying to wrap my head around all of this. It sounds like it’s a combination of poor QC and potentially design, and I’m hoping that it’s less of the latter. Can you comment on this? I know you can’t say specifics around failure rate but any ball park numbers?
    I originally thought this recall could be a potentially good thing when buying used. Lower prices and a guaranteed new engine but it doesn’t give me a whole lot of confidence hearing about post replacement failures. Any idea what Toyota is doing in these situations? Another replacement?
    TLDR: before it’s too late, should I avoid buying anything 2022+?
  19. Feb 17, 2025 at 3:33 PM
    #4069
    sudobash
    sudobash New Member
    Not seeing anything new that would allow a better answer. The remedy has been released to Canada, but not Phases have been presented as of yet.
  20. Feb 17, 2025 at 3:33 PM
    #4070
    sudobash
    sudobash New Member
    The Engine Assembly for the Recall Remedy is supposedly experiencing failures. This is per dealership communications amongst themselves.
  21. Feb 17, 2025 at 3:40 PM
    #4071
    cory15000
    I called one of the dealerships in my area and provided the VIN of the one I’m looking at. They said probably 5-6 months for this one with a build date of Aug 2022
    sudobash[QUOTED] likes this.
  22. Feb 17, 2025 at 3:43 PM
    #4072
    cory15000
    Dumb question. Are you referring to the actual action of assembling the engine or the replacement engines are failing?
  23. Feb 17, 2025 at 4:00 PM
    #4073
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Same type of failure?
  24. Feb 17, 2025 at 4:09 PM
    #4074
    2wheelsforfun
    2wheelsforfun New Member
    Foothills AB Canada
    woods likes this.
  25. Feb 17, 2025 at 4:34 PM
    #4075
    cory15000
    Yikes. Question still stands, do I avoid the 3rd gen entirely?
  26. Feb 17, 2025 at 4:37 PM
    #4076
    2wheelsforfun
    Foothills AB Canada
    No one can answer that except you.
    woods likes this.
  27. Feb 17, 2025 at 4:44 PM
    #4077
    cory15000
    What if I ask nicely? But fair. Curious to know what the overall failure rate is to date (I believe 94k sold in 2022, and 125k sold in 2023). The Google sheet helps paint a bit of a picture but I can only assume there are a lot more missing because 125 failed across over 219k+ sold isn’t as horrible as everyone is making it sound.
    Has anyone heard how Toyota is approaching the failed replacement?..
  28. Feb 17, 2025 at 4:46 PM
    #4078
    LionsFan20
    Josh
    24 Tundra
    IF true, Toyota requires matching part numbers on warranty claims. So IF a replacement long block failed, a long block must be replaced.
    sudobash and cory15000 like this.
  29. Feb 17, 2025 at 4:54 PM
    #4079
    cory15000
    That’s what I’d hope. Even if outside the 12 month period after replacement?
  30. Feb 17, 2025 at 5:01 PM
    #4080
    LionsFan20
    Josh
    24 Tundra
    It would be whatever Toyota is doing for warranty duration....if Toyota is only giving 12 months, then it would be up to the customer to purchase needed parts....HOPEFULLY Toyota will make long blocks available
