Tundra engine noise
Discussion in '2.5 Gen Tundras (2014-2021)' started by UserNameTaken, Jan 3, 2020.
  1. Jan 3, 2020 at 1:05 PM
    UserNameTaken
    UserNameTaken [OP] New Member
    I have a 2015 Tundra 5.7 and ever since I bought it two years ago it has made this clicking/diesel truck sounding noise. I've searched this forum and I've seen some threads that say this is normal but I have a real hard time believing this sound is normal. I've taken it to the dealer three times and each time they say they can't replicate it, which I also find hard to believe because it now makes this noise 75% of the time. This video I've uploaded to youtube is old but I can't figure out how to upload a newer one. The noise is much louder now. Do you guys think this sound is normal?
    https://youtu.be/Rd-I7J0UWD8
    tinman10101 likes this.
  2. Jan 3, 2020 at 1:08 PM
    rznhales
    rznhales New Member
    Randy
    Southern Utah
    2014 Tundra Crewmax Limited TRD
    Bilstein 5100's
    My '14 sounds nothing like that so I'd say not normal
  3. Jan 3, 2020 at 1:36 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Does it change with RPM? Sounds “tinny” like heat shield or something as opposed to a knockin’ motor.
    TRD-tv, vhstejskal and Max Power like this.
  4. Jan 3, 2020 at 1:48 PM
    UserNameTaken
    No its just a constant noise that's intermittent. A buddy of mine seems to think it's an EGR valve.
  5. Jan 3, 2020 at 2:13 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Is it for sure from the engine bay?
    Given the 'tinging' sound, makes me think it's a loose heat shield or factory skid plate? :notsure:
  6. Jan 3, 2020 at 2:26 PM
    15whtrd
    15whtrd Mr. Blonde
    I had a truck that made it sound like that and it was the pre-cat falling apart until it finally fell into the catalytic converter. But it was quite a few years older than your truck is right now. I would check the heat shields as others have said.
    P-Factor likes this.
  7. Jan 3, 2020 at 2:28 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    what is a constant intermittent noise?
  8. Jan 3, 2020 at 2:29 PM
    15whtrd
    15whtrd Mr. Blonde
    Also the dealer says they can’t replicate it is a total cop out. I hate that they do that. My passenger window clicks a little when rolled down a few inches going over rough roads. They had my truck for three hours. Saw them driving it around. Came back and said they couldn’t replicate it. Bullshit! They freaking drove it to get lunch for themselves while joy riding. I should’ve made them go for a ride along with me
    I say take your truck back to the dealer and request to be standing there while the mechanic looks at it.
  9. Jan 3, 2020 at 2:31 PM
    15whtrd
    15whtrd Mr. Blonde
    LOL! I guess that would mean it’s constantly intermittent? Like the noise is reliable enough that it will be there most times consistently ha ha ha ha
  10. Jan 4, 2020 at 5:39 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Sounds like a heat shield on a cat to me. When they're not tight they'll often have a rattle noise like this at certain engine speeds and it'll sometimes change with temperature. Toyota shields usually have a couple bolts holding the shield halves together. I've had luck with either putting a slight bend in one or adding washers to space them apart.
    There's shields on the headers too so it might be up there. Maybe tap on each heat shield when cold with a wood dowel. That will usually show which one it is straight away.
  11. Jan 4, 2020 at 5:51 AM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    Came to post that it sounds like a heat shield. On my 2010 4Runner, a heat shield gradually came loose and made a very similar sound. It started sort of quiet and as time went on, got louder as the shield got looser.
    YsoSeRiouS! likes this.
  12. Jan 4, 2020 at 6:26 AM
    ryanw4x4
    ryanw4x4 New Member
    Ryan
    South West Washigton State.
    2011 SR5 Trd OFF-ROAD
    following, mine does it everyday.
  13. Jan 4, 2020 at 7:34 AM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    19, Limited, CrewMax, Off Road, Cement Gray
    None Yet
    @UserNameTaken . I have a 2019 with 5k miles now. I bought it brand new. I have the same noise . Its a light diesel clicking noise. Most people don't hear it , but I do because I'm OCD. Welcome to the OCD club . I only hear it when I'm looking for it.
  14. Jan 4, 2020 at 7:35 AM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    I bet if others listen carefully, it will be there
  15. Jan 4, 2020 at 7:45 AM
    Professional Hand Model
    Hand Protectors
    You crawl under truck and listen/observe while noise is happening?
    TTund16 and 15whtrd like this.
  16. Jan 4, 2020 at 8:44 AM
    P-Factor
    P-Factor New Member
    Agree. I also had a failing catalytic converter that sounded very much like that.
    15whtrd[QUOTED] likes this.
  17. Jan 4, 2020 at 8:54 AM
    UserNameTaken
    OK, yeah I see how that doesn't make much sense, lol. What I mean is that it doesn't make that sound all of the time, but when it does it doesn't change with the rpms. It sort of comes on softly then gets louder.
    I agree. I had it there yesterday and explained the problem. I also had them change the oil. They called me 45 minutes after I dropped it off and said they couldn't hear it. When I went to get it I walked out, started it up, and let it run for 30 seconds before it started making the noise. When the service advisor heard it he was "oh, there it is". He told me they let it run for 20 minutes, bullshit. Then he tells me his techs are at lunch from 11am-1pm. Bullshit, a national chain dealership isn't going to close their shop for 2 hours. I'm gonna call the service manager on Monday and see if they can't straighten this out. They really hate bad reviews to Toyota.
    Leo's first and 15whtrd[QUOTED] like this.
  18. Jan 4, 2020 at 8:59 AM
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    Maybe heat shield is loose
  19. Jan 4, 2020 at 9:09 AM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    have the same exact issue. i think its the heat shield too but havent had time to investigate. thanks for the suggestions everyone!
  20. Jan 4, 2020 at 9:36 AM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    On my 2019, when it does make the noise, its only on idle. If I slightly press the gas to increase RPM just slightly, it goes away . It's only sometimes and only on idle
  21. Jan 4, 2020 at 10:35 AM
    Max Power
    I don't mean to beat the heat shield theory to death, but when I had a heat shield go on my 4Runner, it was sort of like that at first as well. I'd only hear the noise a little, and it was always worst while idling. As time went on and the shield got looser, the noise was louder and more frequent, but at certain RPMs would shut up. After things got bad enough, the shield was removed completely. The truck ran fine after that, it didn't make any difference.
  22. Jan 4, 2020 at 11:52 AM
    UserNameTaken
    I did some more youtube research and my engine sounds exactly like this. I would guess it's the timing chain tensioner. I wouldn't think I would have this problem on a 15' with 55k miles.
    https://www.youtube.com/watch?v=J0AGvBGzEE8
  23. Jan 5, 2020 at 4:56 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    I hope not, there's 4 chains to diagnose
  24. Jan 21, 2023 at 3:45 PM
    tundra13_22
    tundra13_22 New Member
    2013 Toyota Tundra Rock Warrior
    stock, BFG KO2
  25. Jan 21, 2023 at 3:48 PM
    tundra13_22
    stock, BFG KO2
    I have the same noise with my 2013 Tundra! Just drove my truck at it started when I stopped at a red light. Sometimes it happens when I start it but mostly at idle after I drive it somewhere. I have been under the truck looking for loose heat shield but the noise isn’t coming from there. Definitely an engine noise, especially when I lift the hood. I would bet it’s a chain tensioner.
  26. Feb 6, 2023 at 12:49 PM
    RCSB 4x4
    RCSB 4x4 New Member
    2011 Tundra RCSB 4x4
    Hey! My 2011 makes the same noise! Did anyone ever conclude whether or not it is indeed the cam chain tensioner and or guides?
  27. Feb 6, 2023 at 12:58 PM
    AZBoatHauler
    So.Arizona
    Try some 5w-30
  28. Feb 6, 2023 at 1:22 PM
    RCSB 4x4
    RCSB 4x4 New Member
    The noise was worse when I was using 5W-20. It became much less frequent when I switched to 0W-20. Also, the noise is more prevalent when the ambient temperatures are lower, so I always concluded that thinner oil helped.
    k0diak8o8 likes this.
  29. Feb 6, 2023 at 3:42 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  30. Feb 6, 2023 at 4:54 PM
    RCSB 4x4
    RCSB 4x4 New Member
    O.K. After looking through those posts I can see this is indeed a common issue.
    k0diak8o8 and 1UP like this.
