Tundra Chase lights? PODs or light bar
Discussion in 'Outdoors' started by Handbanana, Oct 9, 2020.
  1. Oct 9, 2020 at 10:24 AM
    Handbanana
    Handbanana [OP] New Member
    2018 TSS CM 4x4
    Trd sway front Trd sway rear Trd shift knob Nitto ridge grapplers OEM LED FOGS
    I’ve been wanting to install some rear facing lights also known as Chase lights. When backing up the trailer to a campsite and it’s pitch dark it’s hard to see anything so I want to install these chase lights to help. I’m not sure if I should go with pods or a light bar which one do you guys think would look cleaner. I will be controlling these from a toggle switch located inside so they don’t come on all the time I am in reverse and blind people. does anyone have any pictures of their set upI’ve got a set of rigid pods but I’m still torn between pods one on each end of the back window or a light bar by the back window mounted in the middle size Would very.
  2. Jan 12, 2021 at 3:23 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Looking for the same thing. just did a search for rear facing lights and there's not a ton of stuff there. I don't want to cut holes in the bumper for flush mounting lights. I like the pic you have but I have a cover on my bed so that will not work. I saw the evil mfg 3rd brake light that looks good but it requires drilling on both sides of the 3rd brake light and I can't bring myself to do it.
    Any other ideas?
    -Mike
  3. Jan 12, 2021 at 4:56 AM
    Handbanana
    2018 TSS CM 4x4
    I’ve already finished a install. I’m working on making a video to upload on YouTube.
    Njmike13 likes this.
  4. Jan 12, 2021 at 4:59 AM
    Handbanana
    2018 TSS CM 4x4
    Thumbnail
    pickeledpigsfeet and Njmike13 like this.
  5. Jan 12, 2021 at 5:03 AM
    coTony
    Tony
    Montrose, CO
    Do the lights rub the cab when off-roading and it flexes?
  6. Jan 12, 2021 at 6:59 AM
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
  7. Jan 12, 2021 at 7:08 AM
    Headlight Revolution
    Headlight Revolution New Member Vendor
    Atlanta, GA
  8. Jan 12, 2021 at 7:10 AM
    Handbanana
    2018 TSS CM 4x4
    Not sure just put them on but that’s where I put them. I wasn’t going to mount them to the inside of the bed on a bracket but this location looked better. I mainly using this to back up in dark loacations.
  9. Jan 12, 2021 at 7:14 AM
    Atlanta, GA
    If you're looking for a reverse light addition, have you seen this little guy? It's a mini light bar that bolts on with your existing license plate bolts and sits above or below your license plate. You wire it in with your OEM reverse light wiring so whenever you're in reverse, that light bar + your Reverse lights will power on!
    https://www.headlightrevolution.com/XTR-LP-Reverse-Light-System_2
    don3032 likes this.
  10. Jan 12, 2021 at 7:23 AM
    shakezoola
    shakezoola Not a new member
    Kansas City
    2019 Tundra TRD Sport MGM
    N-Fab MRDS Bfront Bumper w/ Rigid Industries Radiance PODS and Curved LED Light Bar TRD Skid plate Victory 4x4 Roof rack and hood mounts with Rigid industries Midnight PODS Alpine Halo9 ILX-F309TND Alpine PDR-V75 5-Channel amp powering 4x Image Dynamics component speakers Alpine S-A60M powering 1x 12" sub Fortin Remote Start with MyCar App Switch Pros SP-9100 Pop-and-Lock tailgate lock vLeds front turn signals w/switchback Center Console Safe Pedal Commander Diamond Back HD bed cover Swing Cases Driver/Passenger Katzkin Leather seats w/ heated front seats Bilstein B8 5100's Front and rear AMP Research PowerSteps Toyota TSS wheels w/ DuraTracs Toyota bed mat Bed light (LEDs) Blacked out badges Sport Antenna
    I'm curious if anyone uses this on their Tundra and has any issues with the back up camera image being washed out.
  11. Jan 12, 2021 at 7:29 AM
    Atlanta, GA
    With your camera being up on the tail gate handle, this isn't an issue at all! If it were closer to the lens, that would wash it out but the 1794 we had didn't have any issues with camera wash! The optics of the XTR really helps with this too. We even had the OEM reverse bulbs swapped out to LED as well.
  12. Jan 12, 2021 at 8:19 AM
    don3032
    don3032 New Member
    don
    Do these have an option to turn one or off with the reverse lights being on?
  13. Jan 12, 2021 at 8:31 AM
    Atlanta, GA
    If you wired it to a switch, sure! How it sits though is to be activated with your reverse lights at all times. Really just depends how you wire it!
    don3032[QUOTED] likes this.
  14. Jan 12, 2021 at 9:31 AM
    GianLaGatta
    GianLaGatta New Member
    Gian
    2019 white tundra sr5
    3in lift
    Do you have any rubbing problems? I was looking to do basically the same thing
  15. Jan 12, 2021 at 9:48 AM
    Handbanana
    2018 TSS CM 4x4
    The problem with these lights is that they only illuminate from the plates down so if you’re running Chase lights you have the option to turn them to the sides up and down which is the reason I position them in this location with that being said that little light bar is handy and bright and very inconspicuous.
  16. Jan 12, 2021 at 9:49 AM
    Handbanana
    2018 TSS CM 4x4
    If you’re worried about rubbing issues you can mount the light in another location I will not be off routing and if it rubs a little I’m not too worried. I believe as QHD makes a bracket that you can mount light pods on but they’re over priced for what they are in my opinion I made my own for about five dollars but I ended up changing my mind
  17. Jan 12, 2021 at 9:50 AM
    GianLaGatta
    Gian
    3in lift
    okay, sweet thanks!
  18. Jan 12, 2021 at 11:25 AM
    Handbanana
    2018 TSS CM 4x4
  19. Apr 9, 2024 at 9:56 AM
    Jays06
    Jays06 New Member
    Jay
    2006 Tundra Limited DC 4x4
    80%Fabrication rear bumper, front bumper, and sliders JBA UCA’s Front- Icon 2.5 coil overs with 700lb Eibach springs Rear- Icon 2.0 shocks & Icon AAL Siberian Poly LCA Bushings Poly Steering Rack Bushings JBA Poly UCA Bushings
    upload_2024-4-9_9-53-14.jpgT
    I made some brackets out of 3/16 stainless plate. I run them off of the auxbeam RGB 8 Panel. Was out last week with some buddies on some dirt trails kicking up a lot of dust and everyone said they could see the lights great through the dust. Also the lights were $35 for the set with combo lense
