Tundra Billet D-Rings Now Available!
Discussion in 'Charvonia Design' started by Charvonia Design, Jun 3, 2024.
  1. Jun 3, 2024 at 8:15 AM
    Charvonia Design
    Charvonia Design [OP] Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Over the summer we launched our Billet D-Rings for Tacomas, and ever since then we have been getting requests to make them for 3rd-gen Tundras.
    After countless hours of working on the best mounting solution, they're now ready!
    Billet Tie Downs D-Rings follow the same design language and color scheme as our current Bed and Rail Tie Downs, so you can complete the look with these CNC machined Billet D-Rings.
    Third Generation Tundras did not come equipped with factory D-Ring mounting points, but they're easy to add by drilling two 5/16" holes and using our reinforced mounting plates.
    -SHOP NOW FOR TUNDRA D-RINGS-
    What You'll Get With This Kit:
    Two Billet D-Rings
    Reinforced Mounting Plates
    Grade 10.9 Torx Shoulder Bolts
    Easy to use Mounting Template
    Tools Required:
    T45 Torx bit
    Torque wrench
    Centerpunch
    Drill with 1/8" and 5/16" drill bits
    Isopropyl Alcohol or other mild solvent
    Light grease such as White Lithium Grease​
  2. Jun 4, 2024 at 12:34 PM
    RobertD
    Robert
    DFW, Texas
    Thats only for the 3rd gen Tundra, right?
  3. Jun 4, 2024 at 9:28 PM
    Charvonia Design
    Keith
    Huntersville, NC
    We think they will fit 1st and 2nd Gen as well but have not tested them yet. The threaded plate that goes under the bed is 1” wide by 3” long if you want to measure the ribs on your bed.
  4. Jun 4, 2024 at 10:06 PM
    RobertD
    Robert
    DFW, Texas
    Does it only go on the raised portion or can it sit in the valley? I slide stuff in my bed too much to have something sticking up.
  5. Jun 4, 2024 at 10:15 PM
    Charvonia Design
    Keith
    Huntersville, NC
    The D-Ring is wider than the valley, I don’t think it would fit that way. However, you could also install them on the bedsides or the rear wheel wells.
