Tundra battery. Did I mess up?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erick, Oct 28, 2020.
  1. Oct 28, 2020 at 4:43 PM
    Erick
    Erick [OP] New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
    My 2016 battery starting going out. (I think)
    My truck randomly wouldn't turn on for the last two days. The dash would not light up when I put the key in and turned. Nothing, no clicking or anything. The battery icon would lightly turn on but fade out.
    After about 5 minutes I gave up. I kept a close eye on the dash. The screens still wouldn't light up, but my rpm and mph gauge would slightly move with a very light clicking sound. Keep in mind that the key was not in the ignition.
    I went to go call a tow truck, before I did, I said what the heck, I tried sticking the key in the ignition once more and my entire dash lit up. So I turned the key and it started immediately.
    The crappy thing is that it reset my trip a, trip b and my maintenance. Fortunately, I had written them down a few days prior.
    Now, today... The same thing happened. At least this time I was parked in front of my house.
    I cleaned the battery terminals and wire brushed everything. It started a bunch of times. I grabbed my multi meter and did a diy test. It seemed fine. I went into my local advance auto, he said my battery was fine, but needed a recharge (he said it's at 500 and needs to be around 700). I told him that I just got done driving 150miles and it should be full.
    He then asked if he can test my alternator, I said sure, he then went and grabbed the newer tester, he performed the test, it tested fine. His new tester said that I needed a new battery.
    I then said fine, give me your best battery for my truck. He came back with https://www.oreillyauto.com/detail/...-24f/24rextj/4742602/2016/toyota/tundra?pos=1
    I used my buddies shop account and I was able to get it for 120 bucks. I went and swapped it in the parking lot and got my core fee of 18 bucks refunded to me.
    Now, I'm seeing people say that I should have got a 27F sized battery. The strange thing is that the little 24f battery out performs the 27f batteries they had.
    I'm SOL as of now, as I already installed the new battery. Is the little battery fine for this truck? Or do I need to go buy another?
  2. Oct 28, 2020 at 4:49 PM
    You pos OEM battery lasted 4 years??? Lucky.
    mountainpete likes this.
  3. Oct 28, 2020 at 4:51 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    OEM 27F 120.00 exchange , 800 cca excellent choice. OEM from 2013 lasted 6 yrs , and I only replaced for security , put old one in boat for back up , still holds full charge.
  4. Oct 28, 2020 at 4:52 PM
    I'm running with a Optima Red Top 35. Smaller size than 24F. Great battery. If you have lots of lights or a winch get the Yellow Top.
  5. Oct 28, 2020 at 4:58 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    My 2014’s stock battery lasted until 29 July of this year, replaced it with a stock battery from Toyota. Everyone’s experiences will differ.
  6. Oct 28, 2020 at 5:33 PM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    My wife’s went out on her Highlander this week after 5 years. I replaced it with a 24f. You should be fine. The difference besides size is the reserve will be shorter. What is your CCA? I think the 5.7 is 750.
  7. Oct 28, 2020 at 5:36 PM
    Erick
    Erick
    Thornton Colorado.
    The stock battery was 710. The new battery is 750.
    Black Wolf and Patch999[QUOTED] like this.
  8. Oct 28, 2020 at 5:37 PM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    You should be fine.
  9. Oct 28, 2020 at 5:52 PM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    Mine had a 24F in it when I bought it used (5.7, cold weather and tow packages). I just replaced it with a 27F (which Toyota says is standard with these options).
