Tundra + Airstream: Initial Impressions
Discussion in 'Towing & Hauling' started by robatumd, Sep 1, 2020.
  1. Sep 25, 2020 at 7:03 AM
    #91
    betotundra
    betotundra Toyota for Life
    This is so sad and beyond my comprehension (I do understand the math behind it though), how could Toyota spec the tundra with such a low payload capacity? again, beyond my comprehension
  2. Sep 25, 2020 at 7:59 AM
    #92
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I've been told it was very class competitive in 2007.
    betotundra[QUOTED] likes this.
  3. Sep 25, 2020 at 8:16 AM
    #93
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The payload capacity is based on the weakest link of the Tundra. The weakest link for the Tundra is the rear suspension and the P rated tires. If Toyota had installed heavier leaf springs and LT tires the truck would have been rated with a higher payload number but doing so would sacrifice ride quality and fuel efficiency. Most looking for a 1/2 ton truck aren't concerned with payload and never look at the door jam for the rating. How it "feels" is the major concern.
  4. Sep 25, 2020 at 11:30 AM
    #94
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    Tires don’t do shit for payload rating from what I’ve read. They just handle the load better. Only a better rear suspension would’ve improved it. Regardless, I hope they address that weakness with the redesigned tundra.
  5. Sep 25, 2020 at 11:31 AM
    #95
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Also more to do with frame and not only suspension.
    That is the only thing I hate about the truck , payload is a joke
    aggie_tundra[QUOTED] likes this.
  6. Sep 25, 2020 at 11:35 AM
    #96
    betotundra
    I totally get you Mr Ruggybuggy, I've also read you saying something along these lines in other threads, I value your opinion as a frequent tower and specially as a former Toyota Tech guy. However that's a big compromise from Toyota in this competitive 1/2 ton market. Hear/read things like "My wife’s Mazda CX-9 has the same payload as my tundra had" is still incomprehensible, I don't think Tundra's weakest link is as weak or weaker than the weakest link in said SUV.
    On top of that if Tundra owners chooses to ad aftermarket higher rated tires and leafs that doesn't change formal/legal capacity of the truck. Might change it in "real life, practical application", but that does not saves your arse from being liable in i.e. an accident or a dispute with an insurance company. Please correct me if I'm wrong.
  7. Sep 25, 2020 at 11:40 AM
    #97
    betotundra
    I echo your sentiment on this matter.
  8. Sep 25, 2020 at 7:58 PM
    #98
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Never suggested you can legally do anything about increasing the payload. Suspension improvements and tires help when weight is added. LT tires have a stronger sidewall and higher psi which makes for a more stable ride.
    The frames on Tundras are definitely not the weak link. Rear leaf spring are and it doesn't take much weight before they are maxed out and riding on the bump stops. Most customers notice ride quality and aren't looking at payload number.
    Everyone talks about the legal aspect of being over payload but I've never personally heard of anyone being denied coverage or being charged unless you are grossly negligent. Enforcement officers would be very busy people if they stopped everyone with a half ton pulling a trailer because the reality is that most are over payload. Enforcement is looking for the obvious signs of overloading like lower rear suspensions and higher front suspensions, bulging sidewalls and obvious negligence like pulling a 12K 5th wheel with a half ton. Being a couple hundred pounds over payload on a Tundra won't even raise an eyebrow.
    https://youtu.be/h9gei7JoaOU
