Tundra 5.7 Exhaust clapping noise
Discussion in 'Performance and Tuning' started by Youalreadyknow, May 3, 2022.
  1. May 3, 2022 at 5:30 PM
    Youalreadyknow
    Youalreadyknow [OP] New Member
    Kohen
    08 black tundra sr5
    My exhaust system is a front cat delete with a y pipe into a caver r muffler. Ever since I got rid of the 2 cats the truck sounded way better/Meaner especially at idle and in low gears but sometimes when I hit around 3k rpm it makes this awful clapping noise. I was wondering if anyone knows what exaclty causes this noise and how I can get rid of it. I have seen a video of someone that cut there rear cats and said it sounded like crap afterwards but he said adding a x pipe and then y piping it back after fixed the problem, does this seem like it would work?
  2. May 3, 2022 at 5:32 PM
    Youalreadyknow
    Kohen
    08 black tundra sr5
    I am trying to post of video of what it sounds like but it won’t let me post a video for some reason
  3. May 3, 2022 at 6:09 PM
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    Try linking to a youtube video.
    You should post a guide for this mod so if/when our cats get stolen we can just treat it as an exhaust upgrade.
  4. May 3, 2022 at 6:10 PM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    What size pipe?
  5. May 3, 2022 at 6:11 PM
    Youalreadyknow
    Kohen
    08 black tundra sr5
    Well I don’t know what to say about the guide, my front cats were complety clogged almost so I had to find a shop that would actually mess with the cats(most will not!) and from there it’s just cutting the cat out and replacing with some piping
  6. May 3, 2022 at 6:13 PM
    Youalreadyknow
    Kohen
    08 black tundra sr5
    Pretty sure it’s all 3in but there are many different parts so I wouldn’t doubt it maybe sum parts that haven’t been touched are the stock 2.5 but my muffler I got 3 inch and my exhaust shop had no trouble getting it on
  7. May 3, 2022 at 6:15 PM
    3” all the way may be the problem. Didn’t allow for much back pressure to even exhaust pulses. X pipe helps blend the two sides of the exhaust together, adding a Y pipe at the end might help with the clapping. But dual 3” all the way is too large for these motors.
  8. May 3, 2022 at 6:16 PM
    Youalreadyknow
    Kohen
    08 black tundra sr5
    I always figured the smaller exhaust pipes is what made a lot of that clapping noise and the bigger pipes were deeper sounding, and I already have the y pipe so are you saying to put an x pipe then y pipe it after the muffler?
  9. May 3, 2022 at 6:18 PM
    There’s a sweet spot for every motor. If you were supercharged, it would be different. A lot more air / exhaust flow. Too small is bad, too large can hurt low end torque. A reputable exhaust shop that builds custom exhaust should be able to match the system to your motor.
  10. May 3, 2022 at 6:22 PM
    Youalreadyknow
    Kohen
    08 black tundra sr5
    Eventually I’ll plan on getting some headers but that will probably in a couple years or something lol so I don’t really wanna complety change out my system but try to tweak it to get rid of that clappiness and it only happens when I’m really really on the throttle so that why I think an x pipe might prevent it but I don’t really wanna just go experimenting quite yet
  11. May 3, 2022 at 6:23 PM
    Youalreadyknow
    Kohen
    08 black tundra sr5
    What confuses me a little bit though is that most dual system trucks are the ones that make this terrible sound so I’m a Little hesitant to switch over to the duals if I were going for the x pipe
  12. May 3, 2022 at 6:45 PM
    X pipes are used to balance the exhaust system in a dual exhaust setup. True duals have a left side motor and right side motor system. The X-pipe blends the two together to equalize the back pressure and exhaust pulses. Most high performance setups have an H or X pipe to do this. I think these motors are usually plumbed with 2.25-2.5" pipe. If you Y into a single, that pipe could be 3". The Carver R muffler is also creating the sound in your system. You may get more pleasing results with a different version or different brand all together. Get a good set of headphones and go to youtube and listen to all the exhaust videos for your version of Tundra. Lots on there, it will give you an idea of what's available and what sounds good to you.
    FrenchToasty likes this.
  13. May 3, 2022 at 6:52 PM
    Youalreadyknow
    Kohen
    08 black tundra sr5
    Okay thanks for all the info. So are you saying the cavern r is creating the sound I don’t want? Or is the lack of muffler casing the sound because the cavern r is almost complety straight through. Do you think I would have better luck changing mufflers or changing over to duals with x pipe or something of that nature messing with the exhaust flow because I honestly love the way my truck sounds until it hits that noise which only happenswhen I’m trying to race or something like that so I don’t hear it all the time only full throttle
  14. May 3, 2022 at 7:04 PM
    Do the Youtube thing and see what YOU like. Everyone's taste is a little different. You don't like your current setup, sounds like something new is in order.
  15. May 3, 2022 at 8:06 PM
    Fish River Tundra
    Fish River Tundra New Member
    JD
    Nashville
    ‘16 Platinum
    3” exhaust system should be matched with long tube headers, otherwise you are headed for underperformance.
  16. May 3, 2022 at 10:32 PM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    Sorry that I’m late to the party.
    to get rid of it just make both banks of exhaust before the y pipe the same length.
  17. May 4, 2022 at 8:16 AM
    Youalreadyknow
    Kohen
    08 black tundra sr5
    Thanks for the info will definitely try this
  18. May 4, 2022 at 2:03 PM
    Youalreadyknow
    Kohen
    08 black tundra sr5
    how would I do this since that one side has to curve over which makes it way longer from the start
    4firemandan likes this.
