Tundra 200k Mark
Discussion in 'New Member Introductions' started by Kokok67, Sep 21, 2020.
  1. Sep 21, 2020 at 1:13 PM
    Kokok67
    Kokok67 [OP] New Member
    2007 tundra
    Hi folks. Asking for help. My 2007 4.7 Tundra just hit the 200k mark and these issues start popping up:
    VSC - flashing
    skid light - on
    ABS light - on,
    engine light - on.
    brake light on my tail lights turn/remain on (soon as my ignition is on).
    Codes showing are:
    C1201 - (1) Brake boost sensor circuit range/ performance, (2) Engine control system
    P0724 - (1) Brake switch B input circuit High
    What I have done so far and all checked good:
    - changed/adjusted the brake light switch
    - changed both tail/brake lights
    - checked for short using test light and pulled all fuses one at a time
    - checked for bad fuses
    I'm just a weekend mechanic and my knowledge/capabilities ended here. Please help on what else I could do. This truck is my work truck and I don't have the funding to pay a mechanic. Have any of you folks had this issues? Thanks.
    Prostar 190 likes this.
  2. Sep 21, 2020 at 1:55 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
  3. Sep 21, 2020 at 2:02 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! You found the right forum to ask. You'll have plenty of responses soon enough.
  4. Sep 21, 2020 at 3:06 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  5. Sep 21, 2020 at 3:13 PM
    Welcome from NY.
  6. Sep 21, 2020 at 5:31 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Welcome!
    Try to do a reset real quick. Remove the negative terminal for a few minutes and see if it comes back.
    If it comes back let us know. Sometimes the ecu just get finicky. I never have any of this issues come up with my 4.7 ever, 255k when I traded it in.
  7. Sep 21, 2020 at 5:52 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This ^^^. I like to recommend 15 minutes of battery negative cable disconnection. And wrap it with a rag. Don't let it find a ground.
    BravoDeltaRomeo likes this.
  8. Sep 21, 2020 at 5:53 PM
    Welcome from Ohio
  9. Sep 21, 2020 at 6:04 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  10. Sep 21, 2020 at 10:14 PM
  11. Sep 22, 2020 at 3:42 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    welcome from so cal
