Tundra 2007+ Coachbuilder Steering kits
Discussion in 'Ekstrom Design' started by Coachbuilder1, Jul 3, 2015.
  1. Sep 22, 2020 at 12:50 PM
    #61
    Coachbuilder1
    Coachbuilder1 [OP] Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Usually with clearance issues around the coil its due to caster being set too high. If you have an alignment print out that would great, please post.
    TundraLaw likes this.
  2. Sep 22, 2020 at 3:43 PM
    #62
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Thanks. I will push out the alignment specs soon.
  3. Sep 22, 2020 at 3:47 PM
    #63
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    This is most recent. 6112s- driver side @ 1.9; passenger side @ 1.3. 5160s rear stock.
  4. Sep 22, 2020 at 3:59 PM
    #64
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Keith C @ DD Ind. is a buddy and helped me out. I ended up getting some MR 701 (BLK) and 29/70r17 Mickeys- Very satisfied with performance and aesthetics (it looks mean and the 8" DD exhaust sound vicious when I want it to.) I have reached out to you for guidance a few times and your help & guidance has been greatly appreciated- I tend to end up connecting with and dealing those who are masters of their craft- be it automotive, firearms, surfboards, blades... you are truly a master of your craft. Thank you! Ok man now Im gonna browse some Hellcats!
  5. Sep 22, 2020 at 4:00 PM
    #65
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    *295...:crapstorm:
  6. Oct 7, 2020 at 8:15 PM
    #66
    cweb99
    cweb99 New Member
    Here’s my alignment after getting a BCM and 35/17s. BFG KO2 with Icon Rebounds.
    I have Skyjacker 3inch strut lift, been running for a few years now. Toe is still and issue with my alignment and outside tire wear. Will CB steering kit help fix my alignment?
  7. Nov 22, 2020 at 4:35 PM
    #67
    Sil2875
    Sil2875 New Member
    Chad
    2015 Tundra Limited TRD Magnetic Grey Metallic
    Icon 3.0 front coil overs, Icon Delta Joint upper control arms, Icon 2.5 CDCV rear shocks, Icon add a leaf pack 1.5" lift, body mount chop, Black Rhino 20"x10" rims, Nitto Trail Grapplers 35" tires, RCI engine and transmission skid plates, AFE cold air intake, Addictive Desert Designs ADD Lite side steps, Addictive Desert Designs Stealth Fighter front bumper, Baja designs onx6 40" light bar, (2) S8 10" side light bars, Spyder Headlights with a HID reto fit all morimoto parts, Spyder rear tail lights, mat black door handles, color matching mirror caps, rear bumper color matching color end caps, all cab lighting changed out to LEDs, color matching TRD Pro grill and hood bulge, blacked out badging.
    CoachBuilder1
    Will these work with Icon 3.0’s? What benefit will they provide? Thanks
  8. Nov 22, 2020 at 4:52 PM
    #68
    cweb99
    cweb99 New Member
    It depends on the wheels you have. They require some offset. They helped with my alignment. I have 0.2+ camber now. You also get more travel, and they are much more beefier
  9. Nov 22, 2020 at 5:01 PM
    #69
    Sil2875
    Sil2875 New Member
    Chad
    Cool thanks. I have no offset on my wheels. 20x10 with 35” tires.
  10. Nov 22, 2020 at 6:12 PM
    #70
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    TRDren and Tundyfundy like this.
  11. Mar 24, 2022 at 12:39 PM
    #71
    cementsharktrd
    cementsharktrd New Member
    Demetrio
    2021 Cement Tundra TRD Off-Road
    7 inch bds coilover lift kit
    Is the install fairly simple?
    Coachbuilder1[OP] likes this.
  12. Mar 24, 2022 at 12:43 PM
    #72
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    It's one of the easiest steering/suspension mods you can do. Just make sure you try and eyeball the total length so you can drive to an alignment shop after.
  13. Mar 24, 2022 at 2:56 PM
    #73
    Coachbuilder1
    David
    Salt Lake City UT
    Each version varies slightly but all are very simple to install. install guide covers install adjustment when aligned and service.
  14. May 9, 2022 at 3:55 PM
    #74
    MI-FL off roader
    MI-FL off roader New Member
    Brett
    Merritt Island, Florida
    03' 4Runner 4.7 and 12' Limited 4Runner
    03' Dirt King LT- CaliFab LT Rear
    @Coachbuilder1 hello David, I was wondering (with material shortages and other logistic issues we have been experiencing in the vendor world recently) what your possible wait times are for a set of OE replacements? Ordered them Wednesday evening 5/4 and was just curious.
    I do realize this is a loaded question these days and completely understand things from your side of it.
    Thank You!
  15. Jun 8, 2022 at 11:20 AM
    #75
    Cthulhu
    BIG TIME shout out to @Coachbuilder1 for helping me get my steering kit installed!! Tip...even if you think you might not need an alignment because you didn't touch the inner jam nut...DO IT!! I kept mine exactly where it was, and on advice from David, I took it to get it aligned, and sure enough, my ride to the shop was sketchy as hell! The steering was SO loose. Shop got the toe back into David's recommended specs, camber and caster also, and now steering is right as rain. Thanks again David!! :thumbsup:
    Once these 275/65/R20's (34.1") give up the ghost, going to move to 17" +25 offset Method or Icon wheels, and trying to decide on either 35 x 12.5 or 35 x 10.5. Here's the stance right now with the TRD Fox suspension and the Coachbuilder TRD Pro kit (I LOVE the rake!!):
  16. Jun 8, 2022 at 11:40 AM
    #76
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Nice! You running spacers to accommodate the steering kit?
  17. Jun 8, 2022 at 12:20 PM
    #77
    Cthulhu
    No, I have factory 20” Limited wheels on it, which is OK when you look at the description on Ekstrom Design’s webpage for the steering kit.
  18. Jun 8, 2022 at 1:27 PM
    #78
    FISHN43
    FISHN43 New Member
    Ohio
    I forgot the 20” wheels allow for extra room.
  19. Oct 4, 2023 at 12:47 PM
    #79
    DW707
    DW707 2007 Tundra Driver / Cool dude
    07 Silver Sky DC
    07 Tundra DC. BDS 4.5 inch lift. Icon alloy Rebound 17" rims. 315/70 R17 Sony AX7000.
    Well I got in on a group buy for this steering kit, and as much as I hate to admit it left it on the shelf in my garage until today when I tried to have it installed. I was pretty surprised that there was a significant clearance issue; the wheels and tires are not even close to fitting once this is installed. I have a 4.5" BDS Lift with 17 inch Icon Rebounds and BFG 315/70 r17 tires.
    Pretty disappointing, I had a shop trying to put this on while I was doing some other service work. Now it looks like I'm out the money for the steering kit, the labor for the install, and the install required boring out the knuckles to a bigger hole so not sure how the original setup is going to work out once it is re-installed. Thoughts or suggestions? Just found this out I'm pretty frustrated right now.
  20. Oct 4, 2023 at 1:19 PM
    #80
    Coachbuilder1
    David
    Salt Lake City UT
    Its def close, the flat washer installed under the lower misalignment spacer needs to be installed below the knuckle before the lock washer. this will increase clearance.. not by much but will help. When you have a min liv e me a ring and we'll go over options. David 801.635.4872
    bulldog93 and texasrho83 like this.
  21. Oct 5, 2023 at 9:00 AM
    #81
    DW707
    07 Silver Sky DC
    Update; I did have a good conversation with David from Ekstrom who answered when I called him. We discussed options to make help make this fit, which include moving that washer, possibly modifying the bolt, or just going to wheel spacers. Kind of seems like some spacers might end up being the answer, which I'm not thrilled about but I would like to reap the benefits of this steering kit. The guy I had doing this install for me has a small shop and only works on Toyota's. He made a video of the install, and even though I was kind of pissed about it NOT fitting (I paid him an hour of labor to put it on and take it back off) ... I told him to go ahead an post it. Free advertising for Coachbuilder and here's a little free advertising for Toyota Maintenance YouTube channel. This guy hooked me up for a timing belt and water pump replacement for about half the cost of what every other shop was quoting. He made a video of that job too. Looks like I need about a half inch more offset to fit the steering kit. Recommendations for wheel spacers?
    bulldog93 likes this.
  22. Oct 5, 2023 at 9:10 AM
    #82
    coTony
    Tony
    Montrose, CO
    I have been on the fence about this kit and have asked questions about this on a 3.0 Icon coilover and a secondary shock with 17" rims. I was told it would fit but would need some alignment adjustments. After seeing this picture there is no way this would fit because I would have the same interference with the wheel/tire. I came close several times but it is not very much room in there.
    Thanks for the pic!
  23. Oct 5, 2023 at 9:11 AM
    #83
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    David is very responsive & helpful. I had a few conversations with him over the years about his shackles & steering kit, and he took a lot of time with me over the phone to help out. :thumbsup:
    bulldog93 and Coachbuilder1[OP] like this.
  24. Oct 9, 2023 at 12:27 PM
    #84
    Coachbuilder1
    David
    Salt Lake City UT
    If you're using the stock spindles, your 17"s are +25mm or less, You're not using Camburg UCA's you'll clear, Even with the 3.0's. The pics above DW707 posted he's running a BDS 4.5" lift. The spindles have the knuckle located higher, Joint has to be installed above the knuckle and its positioned about 2" in towards the truck. The stock spindles install on the underside and are inside the wheel. Hope this helps.
  25. Oct 9, 2023 at 1:17 PM
    #85
    coTony
    Tony
    Montrose, CO
    Understood your description about what parts you have and should not have but when you described DW707's install I did not understand how the stock spindle located the knuckle higher and positioned 2" closer to the truck. I believe several pictures are required on the install, this pic looks like a commercial shot with the name being in focus and not necessarily the rest. That pic kind of looks like the arm is mounted below the knuckle but really hard to tell. This bolt is in the opposite direction as the OP's pic but if it was the same then the bolt would be rubbing the tire. I apparently am missing something
  26. Oct 9, 2023 at 1:28 PM
    #86
    Coachbuilder1
    David
    Salt Lake City UT
    I found a better angle and replaced the original pic. Are you using UCA's and or aftermarket spindle?
    coTony[QUOTED] likes this.
  27. Oct 9, 2023 at 3:12 PM
    #87
    coTony
    Tony
    Montrose, CO
    Stock spindle, gusseted and Icon billet UCA’s
  28. Oct 9, 2023 at 3:20 PM
    #88
    Coachbuilder1
    David
    Salt Lake City UT
    Nice, You shouldn't have any trouble clearing. We have alignment specs in the lower portion of the steering kit listing in RED. Use those specs.
    The 3.0's use a very long coil and will need to keep your caster from exceeding +3.0 degrees
  29. Oct 18, 2023 at 8:33 AM
    #89
    tysonjunior
    tysonjunior New Member
    2020 Cement CM
    I have 3 inch coilovers. Does it help the vague feel over bumps you get?
  30. Oct 31, 2023 at 11:44 AM
    #90
    Coachbuilder1
    David
    Salt Lake City UT
    Yes, You'll eliminate any bump steer by increasing the travel in the steering but would say most noticeably the dampening in the joints will eliminate that shimmy in the steering wheel.
