Tundra 2007+ Coachbuilder Steering kits
Discussion in 'Ekstrom Design' started by Coachbuilder1, Jul 3, 2015.
  1. Feb 4, 2019 at 1:53 PM
    cn314
    cn314 New Member
    2014 Black LTD DC
    Just wanting to check with anyone running this kit now, has anyone tried clearing 17" rims? Icons? Methods? If it clears what BS worked for you? Thanks!
  2. Feb 4, 2019 at 2:06 PM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Icon Six Speeds clear
    831Tun likes this.
  3. Feb 8, 2019 at 9:49 AM
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    Will this work with the Icon 3.0's in the front?
  4. Feb 8, 2019 at 11:59 AM
    Coachbuilder1
    Coachbuilder1 [OP] Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Yes, We just need to be sure the caster isn't set too high.
  5. Feb 10, 2019 at 5:01 AM
    azTony
    Tony
    Sun Lakes, AZ
    There are compromises in the alignment to make sure the rear of the tire does not rub the frame so adjusting it the opposite way to clear this would not be the best thing I did I don’t think
    Coachbuilder1[OP] likes this.
  6. Feb 13, 2019 at 10:23 AM
    azTony
    Tony
    Sun Lakes, AZ
    Are there trucks with Icon 3.0's and 35's that run these that do not rub the frame or have interference with these?
  7. Feb 13, 2019 at 10:50 AM
    Coachbuilder1
    David
    Salt Lake City UT
    We have setup trucks using the 3.0 Icons and our Steering kits, its def tight but will work. When you have a few mins give me a call and will go over your build. 801-.635.4872
  8. Feb 13, 2019 at 11:01 AM
    What the!?
    What the!? New Member
    2017 Pro
    Sounds like it’s group buy time on these!
  9. Feb 13, 2019 at 12:25 PM
    Coachbuilder1
    David
    Salt Lake City UT
    There ya go again, Another Great Idea!!!
    How many would like to see a group buy offered on our Steering kits? We build kits for every 2007+ Tundra.. from stock, lifted up to 12" and long travel. Let's hear it !!!
  10. Feb 13, 2019 at 12:29 PM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    are the steering kits compatible with 8" ready lifts? also, PMd you about some shims ;)
  11. Feb 13, 2019 at 12:39 PM
    Coachbuilder1
    David
    Salt Lake City UT
    Yes, I'll send a reply back on your PM shortly. thanks!
  12. Feb 15, 2019 at 3:34 PM
    azTony
    Tony
    Sun Lakes, AZ
    If it is really that “tight” with 35’s and the Icon 3.0’s then I do not see what benefit I would get. I would have to have someone that knew what they were doing with the alignment which is not that easy of a deal
  13. Feb 25, 2019 at 5:00 PM
    cn314
    cn314 New Member
    2014 Black LTD DC
    Just finished up with my full kit from @Coachbuilder1 and it all went smooth. For anyone interested his kit is compatible with 17" rims. Im running ICONs with a 25mm bs and I still have about 1/2" clearance at full lock. 35x12.5r17 (34.5x12.5 true) Toyo AT2s will clear with removal of the mud flaps and possibly no cmc. You can get more clearance in the front fender by moving and heating/rolling the plastic to get some room for a full tuck at lock. Sorry for the poor image quality, all I have is my old iPhone.IMG_2115.jpg IMG_2129.jpg IMG_2124.jpg IMG_2126.jpg IMG_2120.jpg IMG_2121.jpg
    DW707 likes this.
  14. Mar 8, 2019 at 11:34 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I’d would by if they cleared my coil overs. I’m running 6112 at 1.9 with shims. 275/70/18.
  15. Mar 8, 2019 at 11:48 AM
    Tundyfundy
    Bay Area, CA
    Just spoke with David, he’s willing to help us out on these things for a group buy. I’m in, anyone else?
  16. Mar 8, 2019 at 12:28 PM
    Coachbuilder1
    David
    Salt Lake City UT
    If possible give me a call and will gladly go over your build. The alignment specs we use are very specific to each application allowing full cycle in either direction but also positioning the tire in the center of the wheel opening. If we kick the caster up too high its no fun to drive and will notice the truck will have a mind of its own on the payment. if you're strictly off road we can get away with higher caster numbers but does decrease the amount of space we have ti work with between the coilover and steering. There is def a sweet spot we aim for.
    David 801-635-4872
  17. Mar 8, 2019 at 12:30 PM
    Coachbuilder1
    David
    Salt Lake City UT
    Thank you posting :) those darn 17"s with a +25mm offset are snug but am SO HAPPY to see we cleared. Great job!!! Hows the ride and handling now?
  18. Mar 8, 2019 at 12:31 PM
    Coachbuilder1
    David
    Salt Lake City UT
    Our Steering kit will def clear your 6112's and compliment this system. Thanks for calling in :)
  19. Mar 8, 2019 at 1:17 PM
    #49
    matrdguy
    matrdguy New Member
    Pete
    'The Notch' Western MA
    MGM 2016 Tundra Platinum 1794 Edition
    18" TRD Wheels, Falken Wildpeak AT3 275 75 18, Westin Bed Rug with Linex, Window Vents, TRD Sway Bar, Bilstein 6112/5100 CB +3 shackels, CB Shims, Chrome Tailgate Letters. More To Come....
    David, I believe I spoke with you a couple days ago....and I asked you if these would be good for 6112 Top setting lift. You mentioned they would not work with stock Toyota wheels ( I have the 18" TRD wheels)
    Was I mis understand you ... cause that can happen to an old bastard like me... or am I correct..? and these are just for aftermarket wheels.
    Sorry to ruffle your feathers... but just checkin
  20. Mar 8, 2019 at 1:24 PM
    #50
    Coachbuilder1
    David
    Salt Lake City UT
    Thank you for posting, Yes, We do need a bit of a offset in order to add the steering kit when using 17"-18" wheels. ( I should have mentioned this in my post.. sorry for the confusion ) 17" Wheels require a 25mm offset or less and 18"s require a +30mm offset or less. We can also accomplish this by using a 1.25" wheel spacer, We carry Bora.
    The above applies when using OE spindles.
  21. Mar 8, 2019 at 2:11 PM
    #51
    cn314
    cn314 New Member
    2014 Black LTD DC
    Everything is perfect! As you can see there is a slight forward rake and I may want to try the 1" shackles soon to see if that gets me more level. No VSC issues with this setup right now and the turning really is super smooth. I had to have my alignment shop swap the steering ends so it gave me a chance to feel the before/after with them. The stock ends bind at full lock and you can feel the wheel pulling back, that is all gone with your ends and the smoothness was greatly improved! Every part in your kit serves a purpose and I highly recommend anyone running your parts to go with the full setup.
  22. Mar 28, 2019 at 3:56 AM
    #52
    ENDISNEAR
    ENDISNEAR New Member
    2007 Toyota Tundra SR5
    Damn, I might be interested in a group buy if it came down to it.
  23. Jun 2, 2019 at 9:08 PM
    #53
    Ponkus
    Ponkus New Member
    Anything come out of the group buy? Also, do y'all know if this helps prevent the dreaded steering rack seals failure? I'm about to replace mine, dealer claims my rack is bent, so wondering if having more angular rotation would help prevent it from happening again.
  24. Aug 8, 2020 at 10:51 AM
    #54
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, 6112/5160, MR 701's, TOYO R/T Trails 285/75/17
    Hey David. Just to confirm what I have taken out of this thread- The steering kit will fit with 6112s (drivers side 1.9; passenger side 1.3) no shims;
    17s with 0 offset? Thanks and take care.
  25. Sep 21, 2020 at 1:21 PM
    #55
    Jcabanit75
    Jcabanit75 New Member
    Did that also help with alignment out side wear and the tierod hitting the coil over spring
  26. Sep 21, 2020 at 1:22 PM
    #56
    Jcabanit75
  27. Sep 21, 2020 at 1:55 PM
    #57
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    you need more caster.
    osidepunker and Tundyfundy like this.
  28. Sep 22, 2020 at 12:43 PM
    #58
    Jcabanit75
  29. Sep 22, 2020 at 12:44 PM
    #59
    Jcabanit75
    Would this help
  30. Sep 22, 2020 at 12:48 PM
    #60
    Coachbuilder1
    David
    Salt Lake City UT
    Yes, we clear with 17" wheels and offsets of +25mm or less.
    Jcabanit75 likes this.
