Tundra 2007+ Coachbuilder Shackles
Discussion in 'Ekstrom Design' started by Coachbuilder1, Jul 3, 2015.
  1. Jun 21, 2016 at 4:55 PM
    #61
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    X2 :cool:
  2. Jun 23, 2016 at 5:45 PM
    #62
    JerseyTundra
    JerseyTundra New Member
    08 Silver Tundra DC Limited 4x4
    Bilstein 5100's all corners, AVS aero skin bug shield , Avs ventvisors, Husky x-act fit liners, Extang Trifecta signature series bed cover, TRD shift knob, TRD cup holder inserts, Front eyebrow LED lights with toggle kill switch.
    Hey Dave,
    I have 5100's on all four corners on my 08 double cab . What shackles would you recommend I put on back to get some rake back. Would a +2 work for me. Also would I have to make any other adjustments with the install of the shackles. Please PM me a price as well with anything you suggest.
    Thanks Marc
  3. Jun 24, 2016 at 4:35 AM
    #63
    allstar617
    allstar617 New Member
    Sy
    Boston,Ma
    2014 sunset bronze 1794
    Thule areoblade roof racks,Full Led conversion, rackarod lockable rod holders,Led bed lights,Lock'er down safe, 42" led light bar.......6112/5160 suspension lift Coachbuilder +3 shackles, shims and bushing set. Toyo open county AT2’s 295/65/20’s on stock black painted wheels..........
    Pm'd about shims and shackles to go with the bilstien 6112/5160 combo running stock 20x8 platinum wheels
    geno0506 likes this.
  4. Jul 12, 2016 at 1:45 PM
    #64
    Shoua
    Shoua New Member
    Hi there
    I have a 2016 Trd pro and I'm was wanting to give the rear about an 1" or 2" lift without having to shim the front. What would you recommend? Thanks in advance and can I get a pricing of all the item for me to accomplish the lift.
  5. Jul 13, 2016 at 11:41 AM
    #65
    allstar617
    Sy
    Boston,Ma
    +3 shackles should do the trick, but give David a call, easiest and fastest way to contact him
  6. Feb 1, 2017 at 5:24 PM
    #66
    geno0506
    geno0506 New Member
    Michael
    pm'd
  7. Feb 17, 2017 at 11:15 AM
    #67
    Sci-Fi
    Sci-Fi New Member
    Bill
    Walker, La
    07 Tundra SR5 TRD 5.7 Crew Max
    Interior LEDs, floor mats, more to come!
    This is my setup. Bilstein 5100 all around, Coachbuilder +3 shackles and 1 shim per side up front.
    Stock 20's running 305/55/20 and only had to roll skid pan in just a hair to stop rub at full lock.
  8. Feb 17, 2017 at 1:41 PM
    #68
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Whats the wheel offset
  9. Feb 17, 2017 at 2:08 PM
    #69
    Sci-Fi
    Sci-Fi New Member
    Bill
    Walker, La
    Believe they are +50.
  10. Mar 19, 2017 at 1:03 AM
    #70
    geno0506
    geno0506 New Member
    Michael
    Love the aggressive stance, may I ask what front setup with coil overs you have! What are the settings on the front and is yours a 3/1 lift!
    sbrannon02 and Coachbuilder1[OP] like this.
  11. Mar 19, 2017 at 1:20 AM
    #71
    geno0506
    geno0506 New Member
    Michael
    Nice, real nice!
    Would your front be considered a 3" lift now over a 2.5" as the PRO's are! I am thinking of buying a Toytec/Radflo 2.5 coilover with the 700lb springs and the rear Boss rears with reservoirs and adding a #2 CB shackles rear, do you think that would get me near a level if I set the fronts at 3" with minimal rear lift without having front higher!
    rons23 and SouthBoundSteve like this.
  12. Mar 21, 2017 at 1:31 PM
    #72
    Coachbuilder1
    Coachbuilder1 [OP] Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    The PROs sit 2" taller than stock and with our shims installed they provide 1" totaling 3" up front. if you go with the Toytec coilovers I'd recommend using 2 shims on the left and 1 on the right and set the coilover at 2.5" (with the same preload on each side) This way the extra shim on the left side will correct the left front corner lean. The PRO coilovers have the correction built in. Using our +2"s in the rear will get you as close to level as we dare get with a 26 gal fuel tank. if you have the 38 gal you may want to use our +3"s. The traction control needs .750"-1" of measurable rake in order to the truck to drive 100%. Hope this helps. :)
  13. Mar 21, 2017 at 2:19 PM
    #73
    geno0506
    geno0506 New Member
    Michael
    thanks a bunch!
    rons23 likes this.
  14. May 3, 2017 at 8:47 PM
    #74
    Pipusplace
    Pipusplace New Member
    Josh
    TRD PRO 17
    Can I get pricing on this but for the +3 and the shims
  15. Jul 12, 2018 at 10:55 PM
    #75
    xando
    xando New Member
    Oregon
    Tundra TRD OFF ROAD 2015 crewmax/ silver metallic
    @Coachbuilder1
    Me as well,plz!
  16. Jul 13, 2018 at 11:41 AM
    #76
    Coachbuilder1
    David
    Salt Lake City UT
    PM sent.. thank you!
  17. Jul 13, 2018 at 11:42 AM
    #77
    Coachbuilder1
    David
    Salt Lake City UT
    ab1653 and Black Wolf like this.
  18. Jul 14, 2018 at 11:57 PM
    #78
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
  19. Oct 18, 2018 at 11:54 AM
    #79
    leon4x4
    leon4x4 New Member
    CA
    Has anyone setup 2 shims on driver's side and 1 shim on passenger's for 3" lift on 6112 set at 2.5 I want to use +2 Coachbuilder shackles and not sure, if it will set level or have a little rake.
    Rica25 likes this.
  20. Oct 18, 2018 at 11:56 AM
    #80
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    This is 2 on driver 1 on pass., bilstein 5100’s on top setting and +3 shackles on back. What coachbuilder recommended
  21. Oct 18, 2018 at 12:37 PM
    #81
    Coachbuilder1
    David
    Salt Lake City UT
    @leon4x4 We normally set the 5100's and 6112's up this way, thanks for pic @teedubbya this corrects the driver side lean and doesn't increase any preload. you may also want to consider using our +3"s over +2"s. the amount of rake is just enough the traction control is happy and doesn't visually look too tall in the rear. let me know if you need an hand with sizing or anything else. 801-635-4872
    Rica25 likes this.
  22. Jan 5, 2019 at 7:16 AM
    #82
    deuce5lefty
    deuce5lefty New Member
    Trent
    2017 4x4 SR5 TRD Off-Road Barcelona Red
    @Coachbuilder1 just to be clear on this. I am looking at the best way to lift & level my 17 CM TRD4x4. Don’t want to go over 3” for warranty purposes. If I’m reading this correctly, would the following be the setup you’re describing:
    -5100’s front on top setting
    -+3 shackles
    -2 shims front
    - also will do a differential drop
    Also, truck had firestone ride rite’s already installed, with the +3s are spacers typically required? 1”?
    Also, are there any issues with stock rear shocks when adding the +3s overextending them or any issues with the 5100s? Trying to figure out if all 4 corners are needed.
    Thanks in advance for the help
    Rica25 likes this.
  23. Jan 30, 2019 at 12:31 PM
    #83
    Rica25
    Ricardo
    Tulare
    If +2 shackels installed do I need the ABS and brake line extension?
    Coachbuilder1[OP] and Krewcial like this.
  24. Jan 31, 2019 at 3:14 PM
    #84
    jdm ctr '00
    jdm ctr '00 New Member
    los Angeles, CA
    2016 Tundra TRD PRO
    No
    Coachbuilder1[OP] likes this.
  25. Feb 1, 2019 at 9:19 AM
    #85
    Coachbuilder1
    David
    Salt Lake City UT
    Sorry for the late reply, with the famous driver side lean we all have using 2 shims above the driver side 5100 and 1 above the passenger side 5100 you'll level the truck left to right and be sitting at 3.00" Our +3"s will provide 1.75" in the rear and work great with the rear 5100's
    You will need to use our air bag spacer kit with your air bags just so they cycle properly, Ideally using a matched rear shock like the 5100's is best and will provide the same valving front/rear and are extended in length.
    https://shopcoachbuilder.com/collec...ilder-strut-coilover-shim-provides-50-of-lift
    https://shopcoachbuilder.com/collec...ilder-3-shackles-provides-1-75-of-actual-lift
    https://shopcoachbuilder.com/products/coachbuilder-airbag-spacer-kit-actual-thickness-1-50
  26. Feb 1, 2019 at 9:21 AM
    #86
    Coachbuilder1
    David
    Salt Lake City UT
    Nicely done!!!! Hows the ride quality now?
    Rica25 likes this.
  27. Feb 10, 2019 at 2:03 PM
    #87
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    PM sent. :thumbsup:
  28. Mar 7, 2019 at 8:54 PM
    #88
    ITOWJKS
    ITOWJKS New Member
    2018 Tundra Limited Cavalry Blue
    @Coachbuilder1, from where can I get the carrier bearing drop kit. Looked everywhere, can't find them (other than e b a y)? Also, do you sell the brake lines extension brackets? If so, what's included?
    Rica25 likes this.
  29. Mar 7, 2019 at 8:57 PM
    #89
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    ITOWJKS[QUOTED] and Rica25 like this.
  30. Jan 26, 2020 at 7:21 AM
    #90
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I am installing 6112's at the 1.3 setting and 5160's rear. I have CB +2 s in the garage. I will be installing 305/75R17 with 0 offset. My question is: Will +2 shackles have too much rake? Should I install a CB drop kit if I do the +2's?
    Should I down size to +1? Shocks goin on this Saturday. Thanks
