Tundra 2007+ Coachbuilder Shackles
Discussion in 'Ekstrom Design' started by Coachbuilder1, Jul 3, 2015.
  1. Feb 21, 2016 at 6:18 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    After measurements?
  2. Feb 21, 2016 at 6:21 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    I got the 2 shims each side up front and +2's. I haven't installed yet though. I may exchange again pending measurements of +3's from @TRON
    TRON likes this.
  3. Feb 22, 2016 at 6:08 AM
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Sorry I dropped the ball guys, ill snap a pic of my notes and just post that today. been super busy with life haha
  4. Feb 22, 2016 at 6:10 AM
    TRON
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    I got the 2 shims in front if that's what you mean? I believe they're .5" each so about 1" lift each side up front with the 1.75" in back from the +3
    JROCK915[QUOTED] likes this.
  5. Feb 22, 2016 at 6:14 AM
    Dynocomp02wrx
    Dynocomp02wrx New Member
    Dion
    Arizona
    2015 Tundra TRD PRO
    TRON hi. Just wondering how much higher your back sits compared to the front ? Could you measure please. Debating on +2 or +3 shackles with 2 shims up front.
  6. Feb 22, 2016 at 6:16 AM
    TRON
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    For sure Ill grab my notes when I get off work in a bit, but the rear is noticeably higher showing off a true rake. Didn't think I'd like it but it does look awesome!
    Y0TA PR0, Medic and dcsleeper408 like this.
  7. Feb 22, 2016 at 9:28 PM
    JROCK915
    JROCK915 Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    I was just wondering about the rear. I read that you can get either 1.5" OR 1.75" out of the +3. You answered it. I'm having mine done Sat. Wanted the 1.75" out of them.
  8. Feb 23, 2016 at 12:43 AM
    TRON
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    Before measurements included the TRD Pro Suspension and 35" Toyo RTs with roughly half a tank of gas. After measurements include the Coachbuilder +3 Shackles (1.75"), and 2 (0.5") shims each side in front with alittle more than a quarter tank of gas.
    Driver Front
    Ground to Fender
    Before (38 1/2") After (40 1/2")
    Center Hub to Fender
    Before (23 3/8") After (24 1/4")
    Passenger Front
    Ground to Fender
    Before (38 3/4") After (40 3/4")
    Before (23 1/2") After (24 1/2")
    Driver Rear
    Ground to Fender
    Before (39 1/8") After (42 1/2")
    Before (23 3/4") After (25 3/4")
    Passenger Rear
    Ground to Fender
    Before (39 1/2") After (42 5/8")
    Before (24 1/2") After (25 3/4")
    JROCK915, dcsleeper408 and Cutter29 like this.
  9. Mar 20, 2016 at 1:37 PM
    patthis
    patthis New Member
    Pat
    Hi, can I get pricing for +2 shackles and bushings please. Thanks
  10. May 20, 2016 at 11:04 AM
    Mstraviator
    Mstraviator New Member
    VA
    2016 Platinum- TRD PRO shocks
    TRD PRO shocks, Coauchbuilder +3 shackles, shims and steering kit, 35" tires, 20" rims, TRD Exhaust
  11. May 20, 2016 at 11:06 AM
    Mstraviator
    VA
    Do the +3 shackles allow the Leaf springs to rub against the dual TRD exhaust?
  12. May 20, 2016 at 3:37 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Mine do not
  13. May 20, 2016 at 5:09 PM
    Mstraviator
    VA
    Thanks for the info!
    TruckyTruck likes this.
  14. May 21, 2016 at 4:32 PM
    jdm ctr '00
    jdm ctr '00 New Member
    los Angeles, CA
    2016 Tundra TRD PRO
    When my rear suspension is fully extended they do make contact. Coach told me it would make contact when i purchased the lift.
    Tundyfundy likes this.
  15. Jun 1, 2016 at 5:12 PM
    Phlonx
    Phlonx New Member
    White 2012 Tundra Limited RWD
    Can somebody point me to a picture and/or more info on the shims for the front?
  16. Jun 1, 2016 at 5:43 PM
    Phlonx
    Phlonx New Member
    I had this mediocre plan to lift/level my stock truck:
    -Bilstein 5100 kit (2.5" front lift, 0" rear)
    -1" block in the rear
    I was going to add a 1" block in the rear (mostly because I do tow here and there). But since @CaptTyler referred me to these shackles, I'm leaning this way.
    Also, I read about the shims I could use up front, which is exactly what I was needing because I'd like to lift just a tad more than the Bilsteins allow.
    Revised plan:
    -1 front shim (which should be a 1/2" lift)
    -+2” Shackles (1.25” rear lift)
    This way I should be OK running 34” tires without cutting anything major to avoid rubbing.
    Can somebody confirm this all makes sense?
    Sci-Fi likes this.
  17. Jun 1, 2016 at 7:14 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    I agree 100%. Good plan. I did just one shim on the drivers side to help with lean but one on top of each strut won't mess with your ride at all. Should be spot on!
    :cheers:
    Phlonx likes this.
  18. Jun 1, 2016 at 7:30 PM
    ToyTec assembled OME front coil overs = no shims required. Shouldn't have to shim with correct setup. No lean at all. Zip. Nil. None.
    Jaydog likes this.
  19. Jun 4, 2016 at 5:15 PM
    #49
    Mstraviator
    VA
    I did the two shims and the +3. Looks great and is about 1" higher in the rear. Also did the steering kit. An excellent upgrade!
    tat2ude39 and dcsleeper408 like this.
  20. Jun 4, 2016 at 5:32 PM
    #50
    TheBeast The Beach
    steering kit ? is that a new product ? do you have more info ?
  21. Jun 4, 2016 at 6:24 PM
    #51
    Mstraviator
    VA
    Here's some information from Ekstrom Design. He has a thread on this site...
    "We have come up with a very heavy duty outer tie rod replacement kit. This kit is offered in 3 sizes and will cover the following applications. All applications mount to the top of the spindle except when using factory OE spindles.
    Factory OE Replacement with OE spindles. (bottom mount)
    CST & Maxtrac 2wd spindles (top mount)
    BDS & Procomp lifts. (top mount)
    Zone 5" lift. (top mount)
    Bulletproof 6"-8" & 10"-12" lifts (top mount)
    Kit uses machined 7075 Billet adapter sleeves with a black hard anodized finish.
    7/8" Cryogenically treated Heim joints.
    Stainless steel high misalignment shims.
    Tapered adapter collar (OE kits)
    https://www.tundras.com/forums/ekstrom-design.65/
  22. Jun 7, 2016 at 10:30 AM
    #52
    Skidmarks
    Skidmarks New Member
    Hey guys is there an online store to order the shims? I cant seem to find where to order them from?
    dcsleeper408 likes this.
  23. Jun 7, 2016 at 10:35 AM
    #53
    CaptTyler
    Tyler
    Not that I'be seen but not 100%. Best way would be to call him.
    Skidmarks likes this.
  24. Jun 7, 2016 at 10:53 AM
    #54
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Keith @dirtydeeds is an official vendor for @Coachbuilder1 I believe.
    Both guys will be happy to assist you and answer all your questions.
    zcarpenter92 and Skidmarks like this.
  25. Jun 21, 2016 at 9:33 AM
    #55
    JerseyTundra
    JerseyTundra New Member
    08 Silver Tundra DC Limited 4x4
    Bilstein 5100's all corners, AVS aero skin bug shield , Avs ventvisors, Husky x-act fit liners, Extang Trifecta signature series bed cover, TRD shift knob, TRD cup holder inserts, Front eyebrow LED lights with toggle kill switch.
    I have 5100's on all corners. Would +2 shackles get me to about stock rake? My truck almost sits totally level now with rear a hair higher. With CB +2's not only would it beef up the rear but tighten it up as well? Thanks for any help
  26. Jun 21, 2016 at 3:12 PM
    #56
    CaptTyler
    Tyler
    I have 5100's all around also with +2 shackles. My rear is almost exactly 1" higher than front. Exactly what I was looking for.
  27. Jun 21, 2016 at 3:28 PM
    #57
    JerseyTundra
    Thanks that is what I wanted to hear.
  28. Jun 21, 2016 at 3:30 PM
    #58
    JerseyTundra
    One other question does it ride any better with the shackles. Don't get me wrong I love how my truck rides now but any Improvement on that I would love.
  29. Jun 21, 2016 at 4:39 PM
    #59
    pinoyflayv
    pinoyflayv New Member
    2016 Tundra 1794
    TRD Pro Grill & Hood Bulge - TRD Pro Front Skid Plate - TRD Rear Sway Bar - TRD Dual Exhaust - TRD Pro Suspension - Fuel Krank 18x9 +20 Offset 5.75"BS - Toyo Open Country 35x12.50R18
    Shims 2 on each coilovers, +3 Shackles, Polyurethane bushing kit, Carrier bearing drop kit. Loving this new setup, thanks David!
    ShimsHDR.jpg DSC04324.jpg Coachbuilder1first.jpg Coachbuilder1Second.jpg Coachbuilder1Third.jpg
  30. Jun 21, 2016 at 4:43 PM
    #60
    JerseyTundra
    Very nice indeed.
    pinoyflayv[QUOTED] likes this.
