Tundra 2001 4.7 L left cam move 8 teeth
Discussion in '1st Gen Tundras (2000-2006)' started by Mike Hammons, Mar 17, 2025.
  1. Mar 17, 2025 at 1:13 PM
    Mike Hammons
    Mike Hammons [OP] New Member
    My payments
    Tundra 4.7 L 2001
    Tundra 2001 4.7 L During water pump and timing belt change. Left cam gear moved 8 teeth forward. Was wondering if I could just move Cam back? Or any recommendations somebody might have. Thank you
  2. Mar 17, 2025 at 1:18 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    When did you noticed that it moved? After you pulled the tensioner pin and rotated the crank?
  3. Mar 17, 2025 at 2:07 PM
    There's a sticky thread for that: https://www.tundras.com/threads/timing-belt-master-thread-sticky.107240/
    See page 1 reply #27 and again with page 2, reply #39 for a video showing how to jump back the necessary number of teeth.
    Meanwhile, make sure you understand the correct timing marks, since a lot of people aren't clear on how to properly set time: https://www.toyoheadquarters.com/threads/toyota-2uz-fe-timing-belt-marks-4-7l.335/
    FrenchToasty likes this.
  4. Mar 17, 2025 at 2:17 PM
    Mr Badwrench
    Mr Badwrench New Member
    It "kicked" on you is what happened I am guessing. Assuming the belt is removed, just move it back into position but DON'T rotate it. If you pull your spark plugs out, it will make aligning everything (cams and crank) much easier.
