Tuff Country 5” lift for 06 Tundra?
Discussion in '1st Gen Tundras (2000-2006)' started by 06Tundra1984, Apr 29, 2021.
  1. Apr 29, 2021 at 9:56 PM
    06Tundra1984
    06Tundra1984 [OP] New Member
    Drazen
    Tuff country lift 5” for 06 tundra double cab anyone know if it’ll be fine or if it’s worthless?
  2. Apr 30, 2021 at 4:54 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'd avoid it, but I think a few on here have something similar. Maybe they'll chime in.
  3. Apr 30, 2021 at 5:23 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    It's fine. I installed a 5 inch Tuff Country on a 2002 with no issues. It's still on the road today..
    theblurry1 likes this.
  4. Apr 30, 2021 at 7:31 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    There are two versions of this kit. One with a spindle spacer should be avoided. The nicer version with a replacement spindle is not bad.
    Hbjeff and des2mtn like this.
  5. Apr 30, 2021 at 8:23 AM
    06Tundra1984
    Drazen
    I was thinking about doing just a icon stage 2 3” lift, with front and rear bump stops, diff drop, and like a 2” body lift, icon uniball uca, then maybe change the shocks if there’s better shocks than icon
  6. Apr 30, 2021 at 2:50 PM
    tyler-brown
    tyler-brown New Member
    Canada, B.C.
    2001 AC Tundra V8 LTD 4x4
    5" tuff country lift 2.5" Eibach front coil overs SPC upper control arms 33x12.5's JBA long tubes Jba mid pipes Jba full exhaust & muffler Dirty deeds 12 hole injectors Front hitch receiver
    I believe the 4.5" does not come with the heavier spindles, the extra .5" warrants the spindles, ha.
    I opted for the 5" (with the spindles) about 8 years ago and have had no issues. I mainly use my truck for hunting,fishing, trail riding and 4x4ing. Gets beaten up. Fits 33x12.5 with 1.25" spacer on the stock toyota rim back spacing
    Forgot to mention, 2001 access cab
    theblurry1, bmf4069 and Hbjeff like this.
  7. Apr 30, 2021 at 5:26 PM
    06Tundra1984
    Drazen
    Would you recommend the 5” I heard mixed things about it and I want 35s I was gonna do a icon stage 2 with front and rear bump stops, diff drop, and 2” body lift with a icon uca would that fit 35s yoh think or should I just do the icon with 33s
  8. Apr 30, 2021 at 6:39 PM
    tyler-brown
    Canada, B.C.
    Hard for me to recommend anything man. We all have different wants and needs and budgets. I know if I wanted to do 35's I would need alot of trimming. Or more back spacing, which would be the easier fix. Which I think would have to be done anyways.
    I have since put on spc upper control arms, which gained more articulation, but wouldn't help with fittings 35's.
    bmf4069 and des2mtn like this.
