TuFerLife's 2018 TRD Sport Build
Discussion in '2.5 Gen Builds (2014-2021)' started by TuFerLife, Dec 19, 2018.
  1. Jun 12, 2019 at 6:19 PM
    #91
    TuFerLife
    TuFerLife [OP] New Member
    Taylor
    Chattanooga, TN
    2018 Tundra TRD Sport 4x4
    3" Toytec Eibach coilovers with .5" coachbuilder shims and Coachbuilder +3 shackles, JBA Upper Control Arms, Fuel Assault 20x10 -18 offset on 35x12.50 Cooper ST Maxx, Amp research stepbars, JBA Long tube headers, custom mid pipes and TRD Replacement exhaust system by Dirty Deeds, TRD Black Chrome Tailpipes, Bullit liner spray in liner, S&B CAI, Katzkin leather with Degreez heated and cooling system, Husky floorliners, Coachbuilder roof rack with 13 Rigid pods and Switchpro switch, TRD skid plate, Pop-N-Lock, Auto Tailgate down mod, Rattletrap sound deadener in headliner and door panels. Kenwood DDX 9906XR headunit with full Tech 12 volts sound system and dash cam.
    Yezzzzir! You’ll have to come check it out soon. Business expense. :rofl::rofl:
  2. Jun 26, 2019 at 5:32 PM
    #92
    TuFerLife
    Taylor
    Chattanooga, TN
    JBA UCA’s got delivered today...
    00Tyler10 and Rockgate like this.
  3. Jun 29, 2019 at 1:45 AM
    #93
    TuFerLife
    Taylor
    Chattanooga, TN
    @Coachbuilder1 +3 shackles, 2 driver side and 1 passenger side .5” shims, and bumper shim kit showed up today.
    These things are stout!
    Can’t wait to replace my Toytec shackles with these monsters!!
    Toyotoholic and Erichudgins like this.
  4. Jun 29, 2019 at 5:11 AM
    #94
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Why are you looking forward to replacing the toytecs?
    TuFerLife[QUOTED][OP] likes this.
  5. Jun 29, 2019 at 5:21 AM
    #95
    TuFerLife
    Taylor
    Chattanooga, TN
    I haven’t had a problem with the toytecs, but these ones are offering more lift. Also, the feedback on these shackles has been impeccable. Since they’re so heavily constructed, a lot of people have said they’re getting reduced bed bounce.
  6. Jun 29, 2019 at 6:10 AM
    #96
    Danman34
    Danman34 New Member
    Danny
    More lift makes sense. Have you replaced your bushings already? I installed the polys a couple weeks after I put my toytecs in and the polys made a noticeable improvement. Combined with the 5160s, bed bounce is pretty much non existent.
  7. Jun 30, 2019 at 11:19 AM
    #97
    TuFerLife
    Taylor
    Chattanooga, TN
  8. Jul 26, 2019 at 6:03 AM
    #98
    TuFerLife
    Taylor
    Chattanooga, TN
    I need to update this post with some pics of everything, but got the full exhaust installed with the headers and TRD Replacement system. The thing is a beast now! (Although I really want to get it tuned.)
    Also got the UCA’s, and shims on the front. My front seems to be measuring about 25.5” from center of hub to fender now in the front.
    Still need to upgrade the shackles from toytec to coachbuilder, so hopefully I can do that this weekend.
    Ended up buying 20x10 assaults with a -18 offset. I always wanted that deep dish look, so I will be selling my 20x9 +20 assaults soon.
    This is a pic of me ceramic coating the new rims.
    Black@Blue19 likes this.
  9. Jul 26, 2019 at 6:24 AM
    #99
    Danman34
    Danman34 New Member
    Danny
    @TuFerLife If you installed headers you absolutely need to get it tuned. Your fuel trims are going to be all screwed up otherwise and you run the risk of running too lean and popping a piston.
    TuFerLife[OP] likes this.
  10. Jul 26, 2019 at 6:40 AM
    #100
    TuFerLife
    Taylor
    Chattanooga, TN
    Well that’s not ideal. I didn’t think there were very many tune options out for the ‘18’s right now. Guess I gotta start doing some research. :facepalm:
  11. Jul 26, 2019 at 6:46 AM
    #101
    Danman34
    Danman34 New Member
    Danny
    Yep. You’re moving a lot more air more efficiently out of the cylinders. Which means you’re pulling in more air. Your ecu cannot adjust your fuel trims enough to compensate for the added air. Fuel cools the cylinder. Without enough fuel and too much air, you get a really fast, really hot burn. This leads to burning up the cylinder heads and can grenade the motor. You need to physically go into the ecu to put in new fuel trim tables. This is where the tune comes in. Stock trim tables can not compensate enough.
    I would absolutely refrain from doing any wot or heavy throttle runs until you're tuned for the headers.
  12. Jul 31, 2019 at 7:24 AM
    #102
    TuFerLife
    Taylor
    Chattanooga, TN
    My fuel assault 20x9 +20 offset will be off the truck next Friday, if anyone has any interest in them...
    vanthesupreme likes this.
  13. Aug 9, 2019 at 11:44 AM
    #103
    TuFerLife
    Taylor
    Chattanooga, TN
    Been a busy few days.
    Went and picked up a complete @james@tech12volts systems from a guy a couple hours away...
    Ordered a Kenwood DDX9906XR and a couple pieces I was missing from JRT too.
    Took the 20x9 assaults off today, and got the 20x10’s installed.
    Body mount chop getting done on Monday, and installing the system Tuesday.
    Omohundro and Getmeacoors like this.
  14. Aug 13, 2019 at 7:52 PM
    #104
    TuFerLife
    Taylor
    Chattanooga, TN
    Got the body mount chop done yesterday, muchhhhh better.
    Started the audio install today. I was only able to get to the door speakers, dynamat, and subs... I’ve almost got the amp programmed as well.
    I’ll save the headunit and all the maestro stuff for another day...
  15. Aug 15, 2019 at 11:32 AM
    #105
    TuFerLife
    Taylor
    Chattanooga, TN
    All cleaned up, and I’m loving the look with these 20x10 assaults. But I suck at taking pictures!
    Rica25, Getmeacoors and Boerseun like this.
  16. Jan 20, 2020 at 8:31 PM
    #106
    Tom_Tundra_TN
    Tom_Tundra_TN New Member
    Tom
    2016 TRD CM
    TRD Exhaust, TRD Front&Rear Sway Bar, TRD Shifter Knob, BFG TAKO2, Toyota GBS, 3/1 Leveling Kit, K&N CAI, Leer 100XQ Topper, Tinted Windows, Tacotunes Upgrade, Bed LED Lights, Mirror Caps & Door Handle Color Match, BedRug, LED Interior Lighting, Tailgate Tundra fill, Toyota Step Rail, Katzkin Leather Seats, Leather Console, FRAC Harness, Stubby Antenna, Power Folding Mirrors, Autoloc One-Touch Window Mod, TRD Pro Wheels w/ Lug Nut Covers, Color Match Bumper Ends
  17. Jan 20, 2020 at 8:40 PM
    #107
    cook2kill
    cook2kill PNW
    Portland OR
    2018 CM
    I have nearly the same system and love it. You won’t be disappointed. I’m going on for BMC on wednesday as well. Nice ride!
