TSS/Pre Collision System Malfunction....
Discussion in '2.5 Gen Tundras (2014-2021)' started by SloppyJ, Aug 8, 2018.
  1. Jul 26, 2020 at 5:17 AM
    #241
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I am by no means an engineer or knowledgeable about these kinds of things. BUT the one thing that sticks out to me is the thickness of the face plate that covers Each of the sensors. The AJT is much thicker than the jomax. I am
    Wondering if that has anything f to do with it. I have even thought about using the ajt mount (I think it fits nicer and leaves less adjustment) and the Jomax face plate to see if that would work
  2. Jul 26, 2020 at 5:24 AM
    #242
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Agree on the thickness. I’ve read people having issues with upgrading to the newer TRD Pro grille and using an after market TSS garnish/cover (bc the OEM one costs big $$$). Some covers work better than others and it seems to be the thickness of the cover is the difference. Makes sense at least...
  3. Oct 31, 2020 at 8:29 PM
    #243
    fbingha
    fbingha New Member
    Bakersfield, CA
    @Vin63 What was your resolution with this?
  4. Oct 31, 2020 at 9:14 PM
    #244
    Tundra Wookie
    Tundra Wookie New Member
    2019 Tundra SR5 TRD Sport
    Mine did it randomly and it turned out to be the front sensor that had water intrusion. Once they replaced the sensor no more problems. I could see what appeared to be water by the discoloring of the Toyota emblem around the edges.
  5. Nov 1, 2020 at 4:21 AM
    #245
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    If they get dirty, rains and or snows mine comes on then goes off after a little bit.
  6. Nov 1, 2020 at 4:33 AM
    #246
    shawn474
    MoCo, Maryland
    It depends how long you had your battery disconnected. If it was awhile it will take some time to “recalibrate”. Are you sure the lights or a wiring harness aren’t in the way?
  7. Nov 1, 2020 at 4:39 AM
    #247
    timsp8
    NY
    Old question, but disconnecting the battery shouldn’t make the light come on and stay on. I’ve disconnected my battery a few times and it didn’t come on. I haven’t read about that happening to anyone else either.
  8. Nov 4, 2020 at 11:03 AM
    #248
    GasGuzzler
    GasGuzzler New Member
    2019 Tundra
    6” Readylift AMP Research Power Step Sides Fuel Grenade wheels Toto Tire Complete Stereo Overhaul
    So the dealer just "Highly recommended" that I do the Toyota recall on my sensor. Now the f**ken yellow "OFF" light is always lit & I have NO Cruise control. Not even the standard Cruise. WTF TOYOTA? I told the dealer prior to doing the update that I want radar cruise so don't do it if it deactivates that feature. I had not had any problems with the system previously. He told me that he would show me how to "reactivate" the system after the update. Well guess what? Toyota apparently locked the feature so you canNOT turn it back on. My head is about to explode!:annoyed:
  9. Nov 4, 2020 at 11:23 AM
    #249
    There is no "highly recommend". There is either a recall that needs to be completed or there is not. Service departments are so damn lazy. I had an alignment done on my 2013 and asked if they did the ZPC. They didn't have a clue what I was talking about. I told them that if they were reading their shop manuals, they would know. Its required on every alignment. These are the same morons that tried to tell me that the 4.6 models didn't come with factory alarms.
  10. Nov 4, 2020 at 12:04 PM
    #250
    GasGuzzler
    2019 Tundra
    Yeah, their service writer "Highly recommended" it. Likely because I had told them no multiple times previously. So Frustrating.
  11. Jul 8, 2021 at 8:03 AM
    #251
    Mweeks64
    Mweeks64 New Member
    Mary
    Toyota Tundra
    Sitting here at the dealership with my 2019 Toyota Tundra
    Heading home from the funeral yesterday five hours away These lights on my dash start flashing! Pre-collision system malfunction and Trailer brake error! What the heck I’ve only had this vehicle little over a year. It’s going to take them 2-3 hours to even look at the truck
    Anyone else having this issue?
    Tundrastruck91 likes this.
  12. Jul 8, 2021 at 8:43 AM
    #252
    Photoweekender
    Photoweekender New Member
    Queens, NY
    2022 Tundra Limited DC TRD OR 4x4 Army Green
    TRD Pro Skid Plate Tonneau cover - OEM Talons Garage cat plate Emblem blackout Solar panel on tonneau cover
    I have the same issue with my 2020 Limited. Started around 13k miles and it comes and goes without any discernible pattern of events. I am at 17.5k now.. No solution yet. Truck drives great at all speeds with the light show... with no cruise control or BSM. Lights almost always go away with a restart. I have also experienced the lights disappearing shortly after, if they come on with starting the engine.
    Planning to take a long drive and go to dealer on Saturday with the hope that the lights come on so dealer can at least try to diagnose the issue.
    Mweeks64 likes this.
  13. Jul 8, 2021 at 8:57 AM
    #253
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    This is not common, and I hope the dealer can quickly find the cause. Welcome tot he site from LA (Lower Alabama)!
    Mweeks64 and Photoweekender like this.
  14. Jul 8, 2021 at 9:47 AM
    #254
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome!
  15. Jul 8, 2021 at 9:57 AM
    #255
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Any other errors? If you had a 4WD and ABS light at the same time it’s likely not related to the pre-collision system.
  16. Jul 8, 2021 at 10:08 AM
    #256
    Welcome from NY.
    My sensor went bad about 1 month ago and was replaced under warranty. I was told they never had another person with this issue.
    Hopefully they figure it out quickly. See if they will put another sensor in to see if the problem goes away. Maybe you have a defective sensor also.
    Black Wolf likes this.
  17. Jul 8, 2021 at 10:30 AM
    #257
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Mine came on while driving in some heavy sand down the beach in 4WD. Didn’t have TRAC, etc. disabled so that may have had something to do with it. Reset after key cycle and hasn’t come on since. Only other time PCS has come on was once in heavy rain. Hopefully dealer has your back and it should be covered under warranty.
    Saltyhero13 likes this.
  18. Jul 8, 2021 at 10:31 AM
    #258
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Clean ur Toyota badge
    MoneyMan55 likes this.
  19. Jul 8, 2021 at 10:38 AM
    #259
    mountainpete
    I have had this happen with snow and even a coat of bugs while driving across the prairies. Wash, wipe and restart.
  20. Jul 8, 2021 at 10:41 AM
    #260
    mountainpete
    A general comment: the Toyota pre-collision system is, in my experience, much more resilient than Honda. For example, with the Toyota, if you get a big bug splatter over the camera you can just spray it off and the light will go away. With Honda, you can clean it off perfectly but the system won't restart until the engine cycles off and on again.
  21. Jul 8, 2021 at 10:45 AM
    #261
    shawn474
    MoCo, Maryland
    Did you happen to swap your grill or install a lift recently? If there was rain or dirt, it could be that as well. Some people have had malfunctions that needed recalibration too. Either way should be covered under warranty unless you changed the grill or installed a lift.....
  22. Jul 8, 2021 at 11:00 AM
    #262
    2mchfun
    Probably too many bugs on the sensor or something else silly. Technology is crap, bring back a basic truck and give me a third pedal!
  23. Jul 8, 2021 at 6:44 PM
    #263
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Mweeks64 and 2mchfun[QUOTED] like this.
  24. Jul 8, 2021 at 8:54 PM
    #264
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
  25. Jul 9, 2021 at 3:29 AM
    #265
    Mweeks64
    Mweeks64 New Member
    Mary
    Toyota Tundra
  26. Jul 9, 2021 at 3:32 AM
    #266
    Mweeks64
    Mweeks64 New Member
    Mary
    Toyota Tundra
    The dealership said it is a recall and it has something to do with the ECU (Engine Control Unit) and the fuel pump. They ordered the part and they gave me a vehicle to drive until it’s fixed
    mountainpete and 2mchfun like this.
  27. Jul 9, 2021 at 3:32 AM
    #267
    Mweeks64
    Mweeks64 New Member
    Mary
    Toyota Tundra
    Lol right
  28. Jul 9, 2021 at 3:34 AM
    #268
    Mweeks64
    Mweeks64 New Member
    Mary
    Toyota Tundra
    No haven’t done anything new with truck! Just drove 5 hours away for a funeral. This is crazy
  29. Jul 9, 2021 at 3:36 AM
    #269
    Mweeks64
    Mweeks64 New Member
    Mary
    Toyota Tundra
  30. Jul 9, 2021 at 3:36 AM
    #270
    Mweeks64
    Mweeks64 New Member
    Mary
    Toyota Tundra
    We tried everything nothing helped
