TSS/Pre Collision System Malfunction....
Discussion in '2.5 Gen Tundras (2014-2021)' started by SloppyJ, Aug 8, 2018.
  1. Feb 4, 2019 at 1:37 PM
    #151
    louisB
    louisB New Member
    Louis B.
    2018 Tundra
    The new sensor ( sensor # 4 ) and calibration done by the regional Toyota rep. lasted only 5 weeks, here we go again with "BRAKE WARNING" and PCS not working, called Toyota started the buy back, hopefully they will buy it back, this is my 11th Toyota in the house and maybe the last one !!!!!
  2. Feb 4, 2019 at 1:50 PM
    #152
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    Man, I really feel for you guys having these issues. Mine will occasionally go offline during inclement weather, but that's apparently normal. Once in a blue moon I get a "BRAKE!" alert, but that's so rare that I am not concerned. It's a bummer Toyota hasn't been able to iron this out. They have it on almost every other vehicle model, I'm not sure what the problem with the Tundras are. Unless the other models are having the same issues.....
  3. Feb 4, 2019 at 10:10 PM
    #153
    _bm27
    _bm27 New Member
    Los Angeles
    21 Tundra aka Tank
    PCS off light has come on/off approx 5-7 times, 3 times this past Sat alone. Message shows to clean sensor, goes away upon turning truck on/off, and on it's own. First time I noticed it, pulled over and checked information display where pcs said on but off indicator was on to right. My buddies 2018 also has same issue... Randomly will get BRAKE light flash & super loud beeps scaring heck out of me with no cars near.
    Have dealt with dlrs in the past and from reading here will get no where with them other then can't duplicate or some bs explanation. Really wish there was a way to deactivate the tss/pcs
  4. Feb 14, 2019 at 12:43 PM
    #154
    driverwannabe
    driverwannabe New Member
    Got the Take it to the Dealer rap today. Dealer said the front sensor was not communicating so they are replacing it. Truck has 7k miles and an 18.
    I've had intermittent weather related TSS messages where the cruise wouldn't work whenever on the highway and it was a wet day.
  5. Feb 15, 2019 at 7:48 AM
    #155
    stevep1794
    stevep1794 New Member
    2019 Tundra Limited 2WD - Cement
    Just did mine this morning. After reading all of this and having the same problem.. I figured the only way to get Toyota off their asses is to file with NHTSA
  6. Feb 19, 2019 at 7:07 AM
    #156
    amygriffin27
    amygriffin27 New Member
    Amy
    2018 Tundra white double cab
    Anyone else having an issue with their 2018 Toyota Tundra breaking on its own? I just bought my truck end of last year but hadn’t driven it much until now. My tundra only has 3000 miles on it and just in the last 3 weeks it appears the truck thinks I’m getting into a collision and the screen starts flashing break and beeps and the truck automatically applies the breaks. When this occurs I am not using the radar ready cruise control. My truck was just washed so it’s not due to dirty sensors. This issue happens while I’m driving down the road and no one is in front of me and it also happened while driving into a parking garage. Truck has already been to dealer twice with no error codes and dealer claims nothing wrong with truck. Anyone else have this issue?
  7. Feb 19, 2019 at 7:15 AM
    #157
    Welcome from NY.
    There are several posts about this, just do a search.
    I think it was the water near the sensor after being washed.
    Where are you from? The water could have been frozen if you are in a cold climate.
  8. Feb 19, 2019 at 8:39 AM
    #158
    amygriffin27
    Amy
    Thanks for your reply. The truck has only been washed 3 times since I bought it so that’s not it. I live in south Texas. I never drove it much before because I was working from home so it never got dirty.
  9. Feb 19, 2019 at 8:42 AM
    #159
    See if the software needs to be updated
  10. Feb 19, 2019 at 8:44 AM
    #160
    Go to the Toyota website and put in your VIN# , it will tell you of any recalls/updates.
    https://www.toyota.com/recall
  11. Feb 20, 2019 at 3:11 AM
    #161
    driverwannabe
    Yup the system failed in mine. Did false warnings for a few months, then the screen on the dash said the collision system malfunctioned and to go to the dealer. Just got the sensor replaced by the dealer today.
  12. Feb 28, 2019 at 6:12 AM
    #162
    dekeray
    dekeray New Member
    2018 limited 4x4
    Trd rear sway bar
    My 2018 limited crew max started doing this a week a go, and has been ongoing daily. Pictures and documenting - here I go. This sucks! I did open the hood last night and look down at the sensor behind the emblem (assuming that it) and it looked like they tried to put a drip loop of sorts on the wiring harness attached to the sensor. Unfortunately the loop is at the same height as the sensor and the loop is so tight it looks like it could kink the individual wires in the harness. I would think that if the cable attached/approached the sensor from below and if they put some silicon sealant around and covering the connection it could help the problem. Otherwise - off I go on this expanding wild goose chase.
  13. Mar 1, 2019 at 3:38 AM
    #163
    Dannyo
    Dannyo New Member
    I’m going on a week in the shop now on my 18 CM. i got a trailer brake error that came on at first then the per collision malfunction light. they saying it’s the brake ecu that’s causing the problem waiting to hear back. It was coming in yesterday.
  14. Mar 1, 2019 at 4:00 AM
    #164
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Press and hold the cruise button and the old school cruise control will turn on.
  15. Mar 29, 2019 at 11:17 AM
    #165
    Scottydoo13
    Scottydoo13 New Member
    Scott
    2018 tundra
    So i have been dealing with the same problem for a while now had the sensor replaced twice this time around they said they finally have a fix it turns out that condensation is getting into the sensor housing and causing the collision sensor in the grill to malfunction.. toyota now has a kit to seal it and will replace at no cost. That sensor not only controls the safety system but the cruise control as well Expect a recall notice soon!! I hope this helps
  16. Mar 29, 2019 at 4:57 PM
    #166
    Cjames17
    Cjames17 You gotta wanna
    Indiana
    2019 Black SR5 TRD Sport CM
    I had my first issue with this problem this past weekend. While in cruise on the interstate in a light rain the cruise control kicked off and wouldn't re-engage. Very frustrating as the truck has less than 1k miles on it.
    Called my dealer and found out that there is a service campaign that just was activated. Here are the details:
  17. Mar 29, 2019 at 5:00 PM
    #167
    Cjames17
    Indiana
    So I would suggest looking up your vin or calling your dealer to see if you are affected by this.
  18. Mar 29, 2019 at 8:14 PM
    #168
    hudrock
    hudrock New Members only jacket
    So Cal
    25 MGM Limited
    Good to hear they are finally officially addressing this issue
  19. Mar 29, 2019 at 8:51 PM
    #169
    Kolelt
    Kolelt New Member
    Of topic. But is it me or does the newer speedo looks awful? It’s the same as the older year but the lay out !!!!!
  20. Apr 13, 2019 at 6:46 PM
    #170
    thornjude89
    thornjude89 New Member
    South Louisiana
    2019 Tundra Black SR5 Crewmax 4x4
    Stock
    2019 tundra crewmax sr5... 800 miles... been having for 3 weeks now and no issues... hopefully they don't come fingers crossed... sorry for you guy's issues I know Toyota can do better then give people the run around.. miss the 90's way before technology took over!
  21. Apr 15, 2019 at 6:18 PM
    #171
    BDelz72
    BDelz72 New Member
    2019 Tundra SR5 Sport
    Lifted 2.5” Front 2” Rear 275 70 18
    I’m sure by now you all know that any of us running a larger tire than stock or a lift are SOL!! No recall and no fix for us!!
    Called corporate numerous times and they refuse to budge.
    I have to concede that the Manual does say not to use the PCS with tires larger than stock or a lift. Who the hell would have thought a company would put a system in a truck that many people choose to modify rendering the safety system unsafe according to Toyota?
    I did get them to admit that the capability to do the recall including calibration does exist on a truck above stock height. It can absolutely be done but they advised the dealers not to do it. So it’s not that they can’t, they just won’t because Corporate put all of the responsibility on the dealer. If you can find a dealer willing to do it good luck!
    I don’t see winning this argument with them on the recall because of what the manual states. So my next course of action is to try and get the system deactivated permanently. It’s usually off for days at a time so it’s easy to forget to turn the damn thing off. If I forget and the system starts to work it could throw out an unexpected brake warning on me and cause an accident. I now have a safety system on my brand new 19 Tundra thats part of a recall and I can’t get it fixed unless I have my truck dismantled. The least they can do is deactivate it. It’s more unsafe to leave it as is. It’s not required by any laws to be on the truck so it really shouldn’t be an issue especially since it should be shut off whenever it’s being a truck...like having it loaded or towing. It’s a very flawed system and has no business being on the trucks. It’s actually made them less safe IMO.
    LT75 and thornjude89 like this.
  22. Apr 15, 2019 at 6:29 PM
    #172
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I agree! Would rather have it disabled so it doesn’t cause an accident. Plus the annoying loss of the center of the dash when it goes out. It is strange that they would rather not fix it and let a malfunctioning system go untouched. Seems like a bigger lawsuit for the later rather than fixing it.
  23. Apr 15, 2019 at 6:49 PM
    #173
    BDelz72
    BDelz72 New Member
    Yes!! That’s the point I’m going to attempt to make with them. I’ll keep you all posted.
  24. Apr 25, 2019 at 6:18 PM
    #174
    Novakiller
    Novakiller New Member
    19 Tundra Trd Sport
    K and N intake, TRD exhaust, 2in leveling kit, so far
    I have a 19 trd sport. I've had this same problem since 300 miles.(now 3000). System goes down after washing, during rain, or driving into the sun. Toyota dealer blamed my 2"leveling kit. Said that they should not have performed tsb repair on sensors because of it, but did anyways. My hero. Now I have have some piece of foam on the sonar sensor behind my grill, as well as the light on my dash.
  25. Apr 29, 2019 at 7:53 PM
    #175
    2018Tundra in Hawaii
    2018Tundra in Hawaii New Member
    Cement2018 8inlift(Readylift)
    My truck has the same dam thing main even had the same window and it lighted up red flashing BREAK in red and now this Toyota told me it’s because it’s lifted it was doing this kind of crap before it was lifted yeah rite get real.
  26. Apr 29, 2019 at 8:00 PM
    #176
    Welcome from NY.
  27. Jun 17, 2019 at 6:43 AM
    #177
    Golfcart
    Golfcart New Member
    Thread Revival!
    My truck is at it again... typically its only been the psc sensor "visit dealer" issue, but this time ive lost cruise control entirely, pcs, and lda warnings on my dash..
    This makes the 4th time ive gone in for these sensor issues and its quite annoying. You'd think they would have this sorted out by now
  28. Jun 17, 2019 at 11:34 AM
    #178
    Rlynch356
    Rlynch356 New Member
    Apex NC
    2019 Tundra TRD Pro
    is there a way they can disable the system completely? something to consider once the warranty runs out.
  29. Jun 17, 2019 at 8:00 PM
    #179
    evn86
    evn86 New Member
    Just to share my experience and hopefully fix with you guys.... I put a leveling lift in the front of my Tundra when I first bought the truck and never had any issues with the PCS sensor. 5k miles later I take it in for the complimentary maintenance and they performed the recall on it as well. After I took it home that day is when I started getting the PCS unavailable alert so after a few weeks of that I bring it back to the same dealership for them to fix it. They said they were unable to fix the issue because it was due to my lift... which made no sense to me since it was working fine before they messed with it. Anyway I was going to be moving to a new state in a couple of weeks so I said screw it I’ll just take it to a dealership down in Florida when I move. I take it to the dealership in Florida and they laughed when I told them the last place blamed it on the lift, they took a look at it and saw that the last place performed the wrong recall on the sensor. Apparently there are 3 levels for the recall. On the recall paper it says Recall B was performed and Recall A was needed. Also they had to order me a new sensor in order to put the correct recall on it. I’ve only driven the truck 10 miles but so far no issues with the PCS light coming on.
    Soooo if any of you are having the same issues, you might want to ask your dealership which recall or update they performed.
    Here’s a copy of the paper they gave me.
    Max Power and silverhack like this.
  30. Jun 18, 2019 at 5:40 AM
    #180
    Golfcart
    Golfcart New Member
    Thanks for the info evn
    I recently moved from Tampa florida up to indiana and have to drive about an hour to the nearest dealership. Going to stack up on as much info as i can before i make the drive for the next(#4) repair on this sensor system
