TSS/PCS help
Discussion in '2.5 Gen Tundras (2014-2021)' started by whitd82176, Jan 13, 2021.
  1. Jan 13, 2021 at 3:46 PM
    whitd82176
    whitd82176 [OP] New Member
    Whit
    2018 Tundra
    hopefully an easy question for the group, recently purchased a new emblem for my front grill, ever since adding it, my PCS light comes on. my question is, i assume that is the sensor behind the emblem mount on the front grill. Would the wrong/cheaper emblem cause this issue? as i did not spend the hundreds of dollars from toyota to replace, and purchased online for about half $$$.... the emblem appears correct and mounts fine, snaps in place, but ever since adding it back, the PCS comes on. i just removed it this evening to see if my problem goes away, but from the threads, this sensor appears to be a headache.... any help or suggestions is appreciated!!
  2. Jan 13, 2021 at 3:49 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    The sensors seem to be really picky with replacement emblems/garnish covers, the only consistent way to ensure it works is the OEM one though some have had good luck with the one from MC auto parts. I haven’t swapped mine yet because I’ve been waiting for a consistently good option that isn’t $300
