Trying to figure my tow capcity
Discussion in 'Towing & Hauling' started by casper3941, Apr 3, 2020.
  1. Apr 3, 2020 at 8:06 PM
    casper3941
    casper3941 [OP] New Member
    Hey,
    I'm brand new here having a Tundra. I have a 2010 tundra crewmax 5.7l 4x4 platinum. My question is what's the towing capacity?
  2. Apr 3, 2020 at 8:40 PM
    Pyrite Tundy
    Pyrite Tundy New Member
    Failure2comply likes this.
  3. Apr 4, 2020 at 7:10 AM
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
    Tow Cap=10,100 lbs.
  4. Apr 4, 2020 at 7:24 AM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    This.
    We will run payload before towing capacity.
  5. Apr 4, 2020 at 7:25 AM
    thezoltar
    thezoltar New Member
  6. Apr 4, 2020 at 7:35 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    https://www.youtube.com/watch?v=qwFLOBrADBs
  7. Apr 4, 2020 at 7:48 AM
    r1-superstar
    DB
    UTAH
  8. Apr 4, 2020 at 12:34 PM
    Green Thunder
    Green Thunder Smooth in the Cruise
    Washington
    2020 Burnt Green TRD Pro
    Food crumbs and dog fur
    The manual will tell you your hypothetical max trailer, but they are never adjusted for all the different configurations you get from the factory. It’s good for ballpark, but if you want exact numbers:
    Step 1: Load your truck with fuel and whatever else you will be carrying.
    Step 2: Go scale your truck at a truck scale. Write that number down.
    Step 3: Find your GCWR. Should be listed in manual.
    Step 4: Do some math. GCWR - scaled weight = max trailer weight.
  9. Apr 4, 2020 at 12:49 PM
    LML 3500HD
    Moved to towing and hauling sub-forum.
    Plenty of great information in here.
    Tundyfundy and Pinay like this.
  10. Apr 4, 2020 at 2:03 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
  11. Apr 4, 2020 at 4:10 PM
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    My method is best, please follow exact directions. Add trailer, if truck moves, you’re good. Still not convinced, add bigger trailer, if the front wheels come up on acceleration, you’re good and looking like a boss. Finally, still not convinced? Add the biggest trailer you got, make sure the trailer axles are “U’d” with weight, now dump God’s Greatest Truck in drive and bury the throttle, disregard noise, did it move? Nope. Reinstall engine, transmission and differentials, be sure to use sturdy jack stands. You’ve officially located your Tundras tow capacity.
    Honestly about 9500lbs +/- , but we all say 10k to swing our Wing Wangs around.
  12. Apr 5, 2020 at 1:20 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    07 5.7 4x2 with tow package: 10,200 lbs on the original window car details. I believe 4x4 have lower tow capacity.
  13. Apr 30, 2020 at 7:09 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    Its crazy my 08 CM limited 4x4 had a tow capacity of 10,100. My 18 CM Platinum 4x4 has a tow capacity of 8,800. Same motor trans and axles. Not sure why in the drop of weight.
