Trying to change struts...what did I do to my cv axle???
Discussion in 'Suspension' started by The Adversary, Oct 12, 2021.
  1. Oct 12, 2021 at 7:09 PM
    The Adversary
    The Adversary [OP] New Member
    still looking!
    2016 Tundra SR5 4WD w/6" lift.
    I removed the drivers side strut, popped the new one in, got everything lined up, then tried to jack up the knuckle to connect it to the upper control arm. As the knuckle went up, it started moving out and away from the control arm. See first picture below.
    I took the new strut back out and tried to jack up the knuckle without the strut. The same thing happened....out and away with no chance of connecting the control arm and knuckle. I also noticed that the hub was substantially toed in.
    I finally noticed that my cv boot was all stretched out. See the second pic below for the drivers side (bad) and the third pic below for the passenger side (good).
    Any idea what I did here?
  2. Oct 12, 2021 at 7:31 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    If its hanging down at full droop, then the CV will be at its limit, which is expected.
    Is the jack positioned directly under the lower ball joint? If it is, try jacking it up from below the sway bar mount on the LCA instead.
    Sunnier likes this.
  3. Oct 12, 2021 at 7:38 PM
    The Adversary
    still looking!
    Unfortunately I just got the same result. No amount of finagling can get the knuckle pushed towards the upper control arm.
    Could I have pulled something apart in the axle?
  4. Oct 12, 2021 at 7:45 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    When it’s lowered can you push the spindle towards the upper ball joint? Or work the cv back and forth until you can get it to move inwards
    Sunnier and The Adversary[OP] like this.
  5. Oct 12, 2021 at 7:50 PM
    The Adversary
    still looking!
    Yes! When it's lowered it lines up right underneath the upper ball joint and I can move it inwards much more easily.
  6. Oct 12, 2021 at 7:51 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    The inner joint of the CV is pulled apart, which doesn't mean it's hurt. Rotate the CV while pushing on it and it'll slide in. There's some bearings that ride in channels and they just need to line up to slide in. The CV is designed to do this so it can plunge in and out as the suspension cycles.
  7. Oct 12, 2021 at 7:56 PM
    The Adversary
    still looking!
    Is there a particular height I should do this at or will keeping it dropped low work best?
  8. Oct 13, 2021 at 5:41 AM
    The Adversary
    still looking!
    It's in!!! Thank you kind sirs.
  9. Oct 13, 2021 at 6:23 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
  10. Oct 13, 2021 at 5:11 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    First mistake was disconnecting the spindle from the uca. You need to leave that connected and disconnect the spindle from the lca. That way there really isn’t any concern of the axle being pulled out from the weight of the hub. Keep that in mind for future reference.
    equin and excelsuspension like this.
  11. Apr 10, 2024 at 8:28 PM
    Rastamatt
    Rastamatt New Member
    Having the same issues. I have tried moving it back and forth. It will not go. Any other ideas?
  12. Apr 10, 2024 at 8:45 PM
    2mchfun
    Engage 4x4 to keep the internal from spinning freely. Then gently align and guide it.It is splined and will need to be rotated just enough to slip in.Patience is key.
    equin likes this.
  13. Apr 21, 2024 at 5:32 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    That's how I did my 6112s, disconnected the LCA, not the UCA. However, I'll be replacing the 6112s with Fox 2.5s in the future along with new UCAs. What would be the best way to do that? Disconnect the LCA first from the spindle, remove the 6112s, then disconnect the UCAs with the LCA's still disconnected from the spindle?
